Question about Whirlpool Calypso GVW9959K Top Load Washer
Won't pump out water
I have no clogs in the line or kinks i think it is a bad water pump moter or wp moter relay or maybe it's in the brains not getting the signel to the relay how can I test the moter or relay. I also checked the pump for clogs and it was clean
  • 1,998 Answers
Remove the pump use an external jumper wire usually u can cut an extension and hook to terminal ends on it plug them into the pump then into the outlet to test the pump
Posted on May 04, 2010
Water won't drain.how do I know if drain hoses are
The problem is more likely a clogged pump or maybe a clogged drain line. If the machine worked at all, that would eliminate wrong connection of the drain line as a cause
Mar 25, 2013 | Washing Machines
Washer won't drain
the drain hose is on the back. it's generally the biggest hose on a washing machine and in most cases black. it could be kinked or clogged. once you locate the hose it's held on with a clamp. undo the clamp and it pulls right off. if no clog or kink there follow the hose to the drain usually on the wall and look there. I doubt it would be or else you would have water all over the floor so my guess is it's not even leaving the washing machine. Also something to keep in mind is that it could be the pump that draws the water out.
Jul 14, 2012 | GE Spacemaker Washer and Dryer Electric...
Lg wm2455h is not draining: i have taken out and cleaned pump filter and that did not correct the problem. I place the machine on the drain and spin cycle and i can hear the pump hum, but doesnt drain. ...
most likely you have a bad pump and it needs to be changed out or something is still stuck in the impellar,stick your finger into the pump and feel around the impellar,i've found under bra metal pieces stuck in there,elastics and string rapped around it and coins lodged in between the impellar and wall of the pump,if the pump is bad or something is stopping the impellar from spinning it will hum,power is going to the pump but the motor isn't spinning.
Nov 12, 2011 | Washing Machines
Won't spin out water but pump works
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
1.A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
2.If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.3.Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
4.Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
5.If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Thank you for using FixYa and please don't forget to rate me.
thanks,
Reymond
Oct 18, 2011 | Maytag Washing Machines
Won't drain. Water sits in bottom during all cycles. Water back up to sink.
Run your garbage disposal and sink water for a few minutes in case there is anything clogging the drain. Also look under your sink in case the drain hose is kinked. That hose might also be clogged but is a difficult job - maybe pro help is needed if you are not comfortable doing it yourself. Last option is that the pump is bad and must be replaced
Jul 08, 2011 | Dishwashers
Whirllpool DU8108WKU0 Water remains up to heating elements. Cleaned drain, cleaned drain float and drain line is not kinked.
hi this sounds like either bad drain pump or the pump is clogged, does it make any noise when your trying to drain it? If it does its probably clogged if not its either bad or its not getting any power to the drain pump, the former being more likely, the pump is located on the side of the main sump assembly underneath the dishwasher.
Sean
Mar 27, 2011 | Dishwashers
My dishwasher won't fill with water
There can only be these reasons:
1 Water valve shut off
2 Door not locked in
3 water relay/solenoid valve broke or inoperable
4 Plastic lines kinked for supply
5 Filter for water clogged.
I'm thinking number 3 or number 5 Hope this at least gives you some things to look at.
Jan 08, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
My washer is flashing the letters ND and dinging a bell. It won't finish its cycle.
not draining in the amount of time the brain thinks it should. Check for clogged filter and pump kinked misaligned hose
Jan 23, 2010 | Washing Machines
Leak out of the from of the ice machine - flashing p1
P1 means a problem with your drain. Most of the time its a kink in the line. Double check your drain line or it could even be a bad drain pump.
Mar 18, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Whirlpool Calypso GVW9959K Top Load Washer Logo
110 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
