Question about Kodak EasyShare V570 Digital Camera
Cam sayes camera error#e45 see user's guide what do i do to fix it
Solution for me: Strike the camera a few times. Error gone.
Seriously - I got this error on a very humid day. The error seems related to the lens moving mechanism. My V570 is 4 years old, not really worth the expense to fix. So .. a couple of hard smacks, and ... back to life.
Posted on May 18, 2010
  • kbibb03 Apr 17, 2011
    I was about to go buy a new camera when i saw this solution. i layed a soft cloth on my desk, layed the camera face down, and smaked it flat down about 5 times and it WORKS!!!! THANKS!
eagle338
  • 4889 Answers
SOURCE: camera error # e45
If it is under warranty i advice you give it for service as this is a pretty complicated procedure to get it fixed.
This error is caused due to the failure of lens alignment system.Try following the procedure below..
it may be the lens contacts or grit in the gears
open it up on the side of the lens you will see a row of thin gold coloured contacts that report the lens position back to the cpu sometimes these get dirty or bent.on the side of the lens is a motor, look where the gear meets the lens and use a pin to flip out any grit that is stuck in the teeth.
Its very unlikely the lens is "out of alignment" this just cant happen unless its been dropped or bashed, in which case it may be broken.
Also i have heard some people bashing the camera a couple of times to get it working..
hold the camera and bash the edge next to the lens against the palm of you hand as hard as you can, one I did have to get a little more medieval on and bashed aginst a bit of carpet on the bench.. but it worked... might be worth a go if the next step is the bin...
Posted on Nov 01, 2007
mads_aye
  • 58 Answers
SOURCE: my camerais say error #e45
if you get this error message and it's telling you to see the user's guide - the user's guide will actually just tell you to do powercycle
with several powercycle (removing batt> putting it back in after 10 seconds> turn cam to auto) it may work again
if not, it needs repair
the user's guide doesn't have this defintion as it's an engineer code, only the repair center can determine or resolve
Posted on Feb 13, 2008
lock123
  • 6831 Answers
SOURCE: i have kodak ls443 get error message camera error
Hello
Firstly, at the link below you can download a updated softcopy of the manual for free.
http://www.retrevo.com/s/Kodak-LS443-Digital-Cameras-review-manual/id/200dj378/t/1-2/
As for the error code you are getting, "error 45" is a lens related problem of LS443.
If the lens is not stuck, you may try to download the firmware from the Kodak site and update the one in your camera.
As the lens is already stuck, there is no choice except to send the camera back to Kodak for servicing.
Hope this can steer you in the right direction.
Kind regards
Andrea
Posted on Dec 23, 2009
lock123
  • 6831 Answers
SOURCE: KODAK Easy Share V530 (Error # E45)
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
lock123
  • 6831 Answers
SOURCE: Error E45 See user guide Kodak Easy Share LS443
Hello
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
Como corregir un errror E45 en una kodak V570
The bad news is that this error means the lens alignment of your camera is messed up and it will take repair service to fix it. The cost of this might be equivalent to replacing the camera.
kodak-easyshare-v570-error-e45-users-guide.
Jul 28, 2011 | Kodak EasyShare V570 Digital Camera
Camera error # 45
download the camera user guide and then solve your problem.
here is your link
http://www.user-guides.co.uk/download/kodak/kodakeasyshare/kodak-easyshare-v570-error-e45-users-guide.html
download.
thanks.
amanagni
May 11, 2011 | Kodak EasyShare V570 Digital Camera
My Kodak V705 has Error #45 lcd cant come so that i can take pictures?says see user's guide what should i do?
Hello and Welcome to FixYa!
The Actual reason stated my Kodak behind this error is the e45 error denotes that it's time to repair your camera. It's also indicative of a lens retraction. It could be that your battery is long in the tooth and doesn't have enough capacity anymore to adequately power the camera. Lithium Ion batteries do lose capacity over time and going on 3 years, a simple replacement of the battery could solve the issue.
Also try to turn off the Cam, remove the memory card/any accessory attached to the Cam, remove the battery, clean the contacts, then reinsert the battery and turn on the Cam. Absent that, a repair is required.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Aug 08, 2010 | Kodak EasyShare V705 Digital Camera
Camera error #e45 kodak digital camera v610
Hello :
This means the lens alignment of your camera is messed up and it will take repair service to fix it. The cost of this might be equivalent to replacing the camera- Better to call KODAK and see what they're willing to do for you.
Not supported solution is to smack the side of the camera . That helped some people with the same error .
Please read this useful link carefully : Kodak cam errors forum
I hope this will help .
please don't forget to rate !
Apr 06, 2010 | Kodak EasyShare V610 Digital Camera
When i swich on it says camera error ''E45 see users guide.
E45 error code indicates the lens of your camera is already defectived. You need to contact Kodak at 1 800 235 6325 ext 12. Your camera needs repair
Feb 03, 2010 | Kodak EasyShare Z700 Digital Camera
I have kodak ls443 get error message camera error e45 and it says see users guide. i have looked in users guide but cannot find andy info re error e45
Hello
Kind regards
Andrea
Dec 23, 2009 | Kodak EasyShare LS443 Digital Camera
Error #E45
For this problem try the following:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Oct 02, 2009 | Kodak EasyShare V610 Digital Camera
My camerais say error #e45
Feb 08, 2008 | Kodak EasyShare LS743 Digital Camera
Kodak EasyShare V570 Digital Camera Logo
1,039 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
