Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Repair screen the tv in the upper left hand corner looks streaked. I 've cleaned it with a soft cloth. When the screen is bright it's very noticable. I feel like it's getting bigger. Can it be repaired
  • 129 Answers
Good day.
its not a problem with the screen but with the internal parts. It could be a cause of a malfunctioning parts along the horizontal section. Capacitors are ussualy the culprit. Have it checked by a technician.
chris
Posted on Mar 26, 2008
Canon dr 9080c
Clean the Upper Reading Unit Glass with a soft cloth and isopropyl alcohol.
You may need to clean the shading plates by opening the top cover all the way and holding down the green start key until the shading plates extend.
Clean these with a soft cloth and isopropyl alcohol also.
Do not bend or tear these.
The clear stop key will retract the chading plates.
Apr 25, 2013 | Office Equipment & Supplies
I accidentally cleaned my samsung led monitor with windex. there are streaks all over the monitor. i used a soft cloth to try and clean off the streaks and it did not work. Is there anything I can do to...
Hello mrm552,
The best possible case is to use to a proper tv screen cleaner, ex. monster screen cleaner. The solution comes with a cloth. Spray the cloth with the solution first with one or two sprays. Then in a circular motion wipe the screen. You can get this solution at most electronic stores where they sell TV's. Hope this helps, good luck.
- Joe
Aug 28, 2011 | Samsung Televison & Video
I have a shadow on the screen in the bottom right hand corner what could the problem possibly be.
It sounds like something has fallen or crawled into your tv. Unplug unit and remove the panel on the rear bottom. Now remove the upper part of the rear cabinet if you cannot see the problem. You will probably find something on the lense blocking the light. This would be a good time to clean the lenses. Using a soft cloth and windex, spray the cloth then gently clean each lense using a circular motion. Do not wipe until dry as you may scratch the lense. Do not spray the lense as you will cover critical components with corrosive cleaner. Do not push hard or disturb any lense adjustments. Reassemble unit and your tv should look as good as new. Let me know how this works out. hardrocko@hotmail.com .
hardrocko
Feb 01, 2010 | Philips Magnavox 51MP392H Rear Projection...
Tearing Blue streak from top left.
The convergence amplifier responsible for blue is dying. Soon blue will be off all over the screen when it fails completely. Only solution is to have the convergence output IC's replaced.
May 27, 2009 | Sony KP-53S65 53" Rear Projection...
Projection tv - Hitachi
sounds like you need to do convergence.
Feb 21, 2008 | Televison & Video
Green dot in upper left-hand corner of screen.
you can try demagnetising your tv screen
Jan 13, 2008 | Emerson EWF2004 20" TV
My tv is not as bright as it should be
no don't use window cleaner it will cause bad streaking. Just use water with a damp soft cloth and dy with soft cloth.
Dec 30, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Streaking inside of screen
Philips screens tend to be very tough to remove as if you are not careful on removal of the screen frame bolts then the whole screen will come falling off.
Mar 19, 2007 | Philips 44PL9523 44 in. Rear Projection...
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
