Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The cold water will not flow properly - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • 1,998 Answers
Check the cold water vavle do a test on that side of the valve for power if you have power to the valve then replace the vavle
Posted on May 04, 2010
How do i repair bellera #r560vs kitchen faucet reduced/low cold water flow have installed newfaucet valve
Turn off the hot & cold water supply lines at the shut-off valves.
Yo need to use the correct replacement cartridge for the faucet you are fixing
The cartridge replacement procedure requires using food grade silicone lubricant around the base of the new cartridge and around the threads of the bonnet.
Then you must properly align the 2 bumps on the bottom of the cartridge with the inside body of the faucet.
Insert and tighten down the bonnet that holds the cartridge in place to where it is snug- do not over tighten the bonnet!
Then reinstall the trim piece and lever.
Slowly, fully open the hot and cold water shut-offs and check for leaks at the shut offs, sink handle, and spout.
If you are using the Watts brand floodsafe supply lines, turn the hot and cold water shut-offs, on slowly. Rapid flow and pressure may activate the floodsafe valve within the supply line, causing little to no water flow to the faucet.
Feb 23, 2015 | Plumbing
Cold water not coming in the washer, only hot
Does the cold water actually flow from the tap when you turn it on? Sometimes plumbers mess up. Otherwise, you've probably got a bad switch, or possibly a bad timer.
Dec 31, 2014 | Washing Machines
I installed a dhc tankless heater, but when I open only the hot water everything is ok, but when I open the cold water at the same time the heater turns off.
Hi and welcome to FixYa, I am Kelly.
What is happening is that your cold water flow is greater in volume (gals per min) than your hot water. So when you open the cold water it is mixing with the hot water inside the faucett or shower plumbing and actually reverse flowing back into the hot water heater plumbing. The reverse flow slows the water flow sensing turbine inside the heater and it is thinking that there is not any water flow. (There isn't actually due to the equalization of water pressure when you open the cold water faucett) Since this is a safety feature of the tankless heater to keep it from overheating, it shuts off.
Somewhere in the hot water plumbing there is a major restriction. It may very well be the internal plumbing of the tankless hot water heater or the flow detector design.
There are 2 ways to correct this. The easy way would be to restrict the available cold water flow. You can do this by installing another shut off valve inline with the cold water plumbing and just not open the valve all the way. You would have to adjust the setting so that the hot and cold water can be on at the same time and the hot water heater stays on. The hard way is to locate the hot water flow restriction and eliminate it.
It is possible.... if you have a flow restrictor in a shower head or a screen in a faucett areator that they are partially clogged. Clean any flow restrictors and screens then see how the hot water heater performs before you start modifying plumbing.
Thanks for choosing FixYa,
Kelly
Apr 10, 2011 | Stiebel Eltron DHC-E 8 Tankless Electric...
On our Model LAT9635AAE washing machine when cycle is on cold/cold the water fills at a very slow flow. If (while water flowing on cold) the water temp switch is switched to warm and back to cold the cold...
You have a bad fill (mix) solenoid valve. The valve in the solenoid is hanging up and by switching it back and fourth between hot and cold its just working its way to the proper position..You were on the right track.....
Sep 16, 2010 | Maytag Washing Machines
Why doesn't cold water flow into the washer through the Smartwater filter? When my Maytag Performa's Wash/Rinse temperature dial is set on Cold/cold no water flows into the tub. But when I set it on...
Hi .. I would first check the supply valve at the washer to be sure that it is open. if it is open , you can check the flow by shutting it off, removing the supply hose, opening the valve slowly and observing the flow. You might need a small bucket here. If you have water flow here at the washer supply valve, then the problem is inside the washer control.
Apr 18, 2010 | General Electric GE SmartWater Household...
The cold water comes out slow . I have already taken the hose off of the back of the washer and the water flows good there. When cold/cold is used the water comes out very slow. When cold/hot is used the...
you need a water valve sounds like you may have hard water and the valve has clogged try switching the hoses on the rear of the washer and see if that corrects your problem
Jan 07, 2010 | Kenmore Washing Machines
The cold water fill just trickles, I removed filter it was not clogged, hot water runs fine. I checked water flow at faucet, I checked for kinked hose. Did not find any obvious problem. Is there a check...
Good day,
The washer has a dual valve, Hot and cold. The cold side has failed. Valve needs to be replaced. Very common problem.
Before changing, turn off cold water supply, remove cold water hose at the machines valve, and turn on to check for proper pressure.
Dec 04, 2009 | KitchenAid KAWS850L Top Load Washer
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
No cold water flow
TRY CHANGING THE COLD WATER TAP IN THE MACHINE.
Oct 13, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
