I've got my printer working fine now, on its own. But, it will not take the command from the computer. Should I reinstall. I did change the port to the Printer USB, but I'm not sure if that's right. It's like this, is there a specific port to use on the rear or what? It's the HP 8050 with the driver only.
  • Beverly H May 03, 2010
    Okay, as it turns out the specific make and model was shown as the 8000 Series, however I also have the installer for the 8050 only in my installers, so will go through the entire installation again and make sure it all matches. BBL with results. Thanks.
  • 6,993 Answers
reinstalling will surely make the resolve the problem, but before you go through the stress of reinstalling you can try the steps below.
Go to control panel on your computer, click on the printer icon, your printer name and model should be seen there, right click on the icon and select, "set as default" amongst the list. Then try again.
If that doesn't work, attempt to print a page, when the printer dialogue box option pops out, check printer name and make sure your printer make and model is selected then press OK and see if it will print.
If it still does not print after trying the above steps, you can then go ahead and re-install the printer.
Firstly, uninstall the present printer driver, restart your computer, then begin the installation.
You can use USB.
Good luck.
Posted on May 03, 2010
  • Walesarumi
    Walesarumi May 04, 2010
    Okay, after the installation, do run a test page and don't for get to uninstall the previous installation, restart the system, before you begin the new installation.
    I wish you good luck.
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <thebestoffools@discussions.microsoft.com> wrote in
message news:E7A27E3E-81E7-46CC-B38E-C63AA474A239@microsoft.com...
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
TSP 700 printer on 32 bit windows 7. It doesn't stop printing and the paper just keep coming out. I've tried to reinstall driver and swapped the printer with the same model with another comput
Check if interface at the back of printer is interchangeable to the type of port your computer will support it. Direct USB to USB or direct connection is recommended to avoid future issues.
Oct 04, 2012 | Star Manufacturing Star TSP700 Receipt...
It seems like the computer and printer are not communicating. I do all the moves on the PC but when I command "print" nothing . I've checked all the cables and even changed USB ports, still...
hi,
  • Is the printer properly installed?
  • Have you set it as your default printer?
  • On the start menu, click on printers and faxes.
  • Is the printer checked[ticked]? Right click on the printers icon and select properties.
  • Check the printers connections by clicking on ports.Had you used same ports connection?
  • If not set them right.
  • Click on print test page.
  • Restart your PC and try printing now.
Sep 16, 2011 | Lexmark Office Equipment & Supplies
I have a HP Deskjet F4400 All-in-one series. Under the icon for it, there is a box that says the printer is stopped. I can click on it and it will say "Start" but below there is a line that...
Hi rjrust958,
The easiest way to correct this problem is by uninstalling and reinstalling the software and driver of the unit. Please visit this link for the updated driver of HP Deskjet F4400 All-in-One Printer series. For additional information on how to uninstall/reinstall software and drivers please visit this link.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | HP Office Equipment & Supplies
I have an HP Laserjet P2035N that worked just fine until I moved it from home to my office. When I hooked it up to my laptop, which it has been before, it said the printer was offline. I've tried...
network printer is connected to check network connection. (cable, plug, etc.), if everything is ok not a problem to the network printer port on ferl can happen and if it is installed USB port, possibly connected to a another USB port
May 25, 2011 | HP P2035N LaserJet Monochrome Printer
My computer doesn't send picture to be printed to my hp photosmart 8450. I have Windows Vista and it worked before. Now why does it show an error in the printer info and also, this printer is set as...
If there is something wrong with the printer, you should get a error message describing the error.
Does the printer have a blinking orange light after you give the print command? Then there is an error in the printer. If you have documents in the print queue, delete them. Remove the printer cable. Shut the printer down, shut the computer down. Reconnect the cable and turn everything on again.
If there is still a problem there might be something wrong with your printer.
If you don't have a blinking light after the print command on the printer, then try changing the printer cable. If not working, try another USB port. If still not working, reinstall the printer.
Sep 21, 2010 | Dell Office Equipment & Supplies
My HP Laserjet 1020 printer does not give printout from a remote computer. Even the print command given by local host computer does not work. The print commands given earlier does not get deleted when...
First you clear the pending print job
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer. if still you fail to print follow this steps to troubleshoot the issue.
first you make sure your printer is working fine just remove the test print form going to printer and faxes option just right click on it and give test print if it is print that means your application have some problem from where you removing print out if test page is not coming then you need to reinstall the drive of printer.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | HP LaserJet 1020 Printer
Printer won't resond to command from computer
restart both printer and computer then report back if any changes
Nov 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Cannot print from computer. printer will print test pages, though
How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
If Printer is connected USB than try different USB Cable and try different USB Port on the computer
If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
Oct 16, 2009 | HP Color LaserJet 3500 Printer
Hp 1400 does not print from print command by computer
sir reinstall your printer software and drivers or follow my commands go in your start>printers and faxes>and right click on your printer>properties>ports and select your port and apply
Jun 03, 2009 | HP PSC 1410 All-In-One InkJet Printer
22 people viewed this question
k24674
