Question about SanDisk Sansa E280 MP3 Player
Wont turn on past start up screen
Only shows start up screen then turns off and then repeats start up screen over and over again
  • SanDisk Master
  • 13,433 Answers
Here are instructions on how to use recovery mode procedure to make the mp3
player turn on. Do the following steps:
1. Turn player off. Hold the power button down for 20 seconds to make sure
it shuts down then put the "Hold" switch ON. The Hold switch is located at
the top part of the mp3 player.
2. Now hold the "Record" button while you connect it to the computer. Keep
holding it until it finishes installing the new device.
Posted on Mar 28, 2008
Even after resetting i can't can't get past the start up screen
try booting up in Safe Mode. turn off your computer and once it's fully shut down, turn it on again. while it's booting up, hit the F8 key repeatedly until you hear some beeps or the screen prompts you to enter Safe Mode or Start up Normally. choose Safe Mode. hopefully, that will enable you to get past the start up screen. if so, you can try to diagnose the problem. the first step you might try is is checking msconfig to see what items you can de-select in Services and Startup. for further suggestions, please post more details including the operating system you're running and what happens when you try the suggestions above. good luck!
Oct 19, 2014 | Computers & Internet
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
Android Tablet wont turn on.
CONNECT TO POWER SUPPLY .... PRESS ON BUTTON (20 SEC) THEN ... WITH OTHER HAND / FINGER KEEP TAPPING SCREEN .... REPEAT UNTIL TAB WAKES UP
Jul 22, 2013 | Google Android 4.0 7 inch 1080P Video...
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
Samsung v5 wont start up
Setup? Why is it even going into a Setup? Did you try to reinstall windows and somehow cancelled or the system crashed in the middle of it? Maybe you mean start up? Let's assume it won't get past Start up. Turn off the laptop and turn it on again then immediately start hitting the F8 Key until you see a screen that will allow you to boot into SAFE MODE. When you see that screen scroll down and you should see an option that says something like Cancel or Stop Automatic Restart On Boot. Take that option and that will allow you to see why the machine keeps restarting. Afterwards turn it off again and repeat the steps previously defined to get to SAFE MODE. Take the Safe Mode option and let it boot into windows. Windows will look bigger and darker in Safe Mode, that's normal. Now click Start/Programs/Accessories/System Tools/System Restore. Run System Restore and restore it to a day and time before you started having this problem. System Restore does not destroy your data, documents, music, pictures or videos, so it's safe. However, System Recovery destroys all data, docs, music, pictures and videos and sets your system back to the point where you first purchased it. Depending on your operating system you might have a different way to get to System Restore, but it's on your system. If the restore points are damaged and will not let you get to a previous date and time then you will need a system disc to get into the recovery console and type the following command: chkdsk /r Check disk will run well over an hour and you will see the percentage toggle from high to low but that is normal. Let it run until it finishes then reboot.
Mar 20, 2012 | Samsung V25 2600XPP (NV25NP0SJM/SUK) PC...
Stuck on start screen
take out the memory card and the battery, place battery back in and turn on the power again.... it did the same to my phone as well....
Apr 28, 2010 | Nokia 5230 Cell Phone
Help!!my cookie just shows LG logo!!
I have the KP501, too. Well, as I know, there is no difference between KP500 and KP501...it's the same OS...My Cookie doesn't want to turn on. When I try to turn on the phone it shows just the LG logo, more not. A few seconds later it turns automatically off and than 3 seconds later it turns on again....I don't know how is this happening...searching for help!!! please help me.... :S
Aug 03, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
The monitor turns off and on repeatedly.
Is it desktop or laptop computer?
If its desktop the data cable might be loose on the back of the desktop computer.
Apr 26, 2009 | Acer Computers & Internet
Phone wont turn on-please read details
its the battery problem it has got freezed due to humidity.replace the battery or keep it neaR any heat area,.do not heat the battery it is very dangerous.just keep it near heat area.or charge the battery again and check out.
Dec 15, 2008 | LG VOYAGER VX10000 Cellular Phone
Laptop wont start properly
Have you tried starting in safe-mode?
hit F8 when windows is loading for safe mode.
Nov 18, 2007 | Acer Aspire 5100-5033 Notebook
SanDisk Sansa E280 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
