Question about WYSE Winterm V90L Thin Client Desktops (902141-04L)
How do i reset CMOS setting on V90L - WYSE Winterm V90L Thin Client Desktops (902141-04L)
    Problem Solver:
  • 17 Answers
There is a jumper that you remove that says cmos. there should be 3 pins. move the juper to the other side of the 3 pins, turn on the computer, then shut it back off, and put the jumper back to where it was.
Posted on May 11, 2010
Hallo
Wie viel Vollt muss die Batterie haben.
Posted on May 19, 2014
I started my pc with no software and os loaded and I got the message: WARNING: CMOS checksum Error My motherboard is: DH61BE and the bios ver. is BEH6110H.86A.0020.2011.0218
This is an error that occures when the BIOS has lost the CMOS settings. This usually happens if the CMOS battery has drained completely.
The solution is to first try to reload CMOS settings. you can do this by pressing DEL at startup and getting into BIOS. then find the "reset to defaults" setting and reset the CMOS settings. This should solve the problems.
If that doesnt help, then you would have to change the CMOS batter on your motherboard. This is a quite simple task. It is a standard battery and is quite cheap.
Also some motherboards have a CMOS battery connector jumper, refer to your motherboard manual and check if you have this and reset it.
These are all simple tasks, but get someone to help you if you don't feel comfortable doing it yourself.
--------- Please rate the answer if it was helpful. Thank You!
May 22, 2011 | Computers & Internet
Tip
How to reset the bios password using PC CMOS Cleaner.
Burn the PC CMOS Cleaner iso ..using ImageBurner or Nero
1.Start up
Insert PC CMOS Cleaner CD, Set BIOS to boot from CD/DVD-ROM.
The first page presents to user is : PC CMOS Cleaner is ready to run.
PC CMOS Cleaner will try to decrypt the encrypted password store in CMOS and list the possible results in the list box:
BIOS type : the type of the BIOS.
Possible passwords:
possible passwords store in current computer. The passwords are listed between '' .
3. Reset the BIOS to default state
If the possible passwords do not work. PC CMOS Cleaner will try to reset the BIOS to the default state.
This action will blank the BIOS password. You may also lose all your previous settings.
There are two choice for you:
Choice 1: Reset password (try to keep date and time)
This choice will try to reset the BIOS, but keep the date and time.
Choice 2: Reset bios (all setting will be set to default, password will be erased)
This choice will reset all data in BIOS to default state.
Please try the Choice1 before Choice2.
on Jan 12, 2011 | Microsoft Windows XP Professional
"Reset you're cmos/bios jumper to
HI,
No need to worry. There are many known ways to reset / remove / bypass the password:
  • By removing the CMOS battery
  • By using the motherboard jumper
  • By using MS DOS command
  • By using software
  • By using Backdoor BIOS password
Now I'll try to explain each method one by one:
A. By Removing the CMOS Battery:
Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
C. By Using MS DOS Command:
This method works only if you have access to the system when its turned on because this method requires MS DOS. Open Command Prompt from Programs menu and provide following commands one bye one:
debug
o 70 2E
o 71 FF
quit
NOTE: The first character in the above commands is "O" and not the number 0.
After providing the above commands, restart your system and it should reset the CMOS Settings along with the BIOS password.
If you are curious to know how it works? then let me explain the above commands:
In this method we are using the Debug tool of MS DOS. The "O" character present at first in these commands, outputs the values to IO ports. The number 70 and 71 are port numbers which are used to access CMOS memory. By providing FF value we are telling CMOS that there is an invalid checksum and it resets the CMOS settings as well as BIOS password.
Jan 08, 2011 | Intel DG31PR Motherboard
I need to reset password on my Acer 4230, and I can't find the cmos battery to remove
The CMOS battery looks like a small circular disc
http://www.tccycling.com/misc/5672inside.jpg
Just remove the connector hold for 30 seconds and plug it back in. Thats all.
Jan 27, 2010 | Acer TravelMate 2300 Notebook
I need to reset the CMOS Password for my acer extisia 4230
for that you need to open back cover of laptop .
Then find motherbord there.
Pull CMOS cell from motherbord for 10 minutes then refix it .
Also you can clear cmos with jumper find jumper near cmos cell named "clear CMOS " it has 3 pin
Set jumper i 2-3 position then power up 1 time then again set jumper in 1-2 position then it not ask for password.
Let me know if you need more assistance.
Thanks.
Oct 21, 2009 | Acer Extensa 5620-4020 Notebook
Cmos password reset for acer aspire 4736z
On most acers it is two pads or a small jumper hidding under the ram.
With the laptop OFF remove the ram and check for J3 its is usually a bit more distinctive than the normal green pcb
You need to short that jumper out for a second or so
re-install the ram and boot up
You should now be able to get into the bios
Aug 21, 2009 | Computers & Internet
Cmos settings issue - Gigabyte MB
Reset the Cmos and it will revert to the default settings. You can then gradually bump up your settings until you find a stable platform and performs the way you would like. Hope this helps.
May 23, 2009 | Computers & Internet
Reset Cmos Settings for Acer Computers
There might be a jumper on your motherboard that's labelled CMOS, or reset... you just have to move the jumper to the other pin combination, power up your PC, then turn it back off and replace the jumper.
If you can't find a CMOS jumper, try unplugging your computer and removing the battery on your motherboard for a few minutes. When you turn it back on, your CMOS should reset to factory defaults.
May 07, 2009 | Computers & Internet
Jumper settings
There is no jumper settings, it is just a small bridge aside the bios Chip. you bridge the two pins and power to reset cmos.
A much easier way is removing the Cmos coin shaped battery from motherboar for few seconds, and put it back, this will reset Cmos the same .
Oct 05, 2008 | Toshiba Satellite A135-S4527 Notebook
TravelMate 530 CMOS Battery
You BIOS setup at the time of bootup should have a reset to factory settings. However if it requires a password you may have trouble getting into it.
Some notbooks have a battery you can pull off the motherboard to reset it back to factory settings. It usually is a small lithium battery.
Aug 27, 2008 | Ricoh Aficio 1035 Copier
WYSE Winterm V90L Thin Client Desktops (902141-04L) Logo
382 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
