The blue light is flashing beside the menu button but i am unable to turn the tv on when i press power i've tried unplugging the tv and nothing happened?
Ur power supply board is dead.Replaced the power board will solved this problems.Tries websites like Sopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
First when you power up the computer press F8 key then enter in enable vga mode. If you are able to enter then go to start menu->control panel->display property ->settings. Change screen resolution to 1024*768 then apply and ok. But if you are not able to see safe mode and other menu. Then open cpu cabinet . Refix RAM memory. Pull cmos cell from motherboard for 10 minutes. Reattach all connection harddrive. Open processor fan and processor remove dust from all parts. Make sure motherboard is not ground with cabinet. Remove PCI cards if any. After all above still same then change RAM then try. Let me know if you need further assistance. Thanks for using FixYa.
The following steps should be able to correct the problem: 1) Unplug the TV or remove AC power from the TV 2) Count to ten and then plug in the TV 3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel 4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons. 5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons. 6) The TV’s lower left Blue Power LED will come ON. 7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time. 8) Press the [Mute] button on the TV remote twice 9) Unplug the TV or remove AC power 10) Count to ten and plug the TV in 11) The TV power should automatically come ON and the blue power LED with be ON 12) Wait 40 seconds and the TV picture should appear 13) You can now continue using your TV. 14) If the picture does not appear, power on the TV manually: · If the LED begins flashing, unplug and power ON a second time. · If the LED begins flashing again, power ON the TV without unplugging If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you. If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control. 2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote 3) Scroll down to "system info" and select [OK] button on the remote
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER Press the WAKE UP/SLEEP button on the remote control until “SLEEP TIMER” appears. To view the time left for sleep timer press the WAKE UP/SLEEP button twice, then press the MENU button on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
