Question about Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television
Mistubishi vs60603 Eleven years old, just got fuzzy when you hit the guide button on cable. Not as bright as before either. But still able to watch . any Ideas?
  • Mitsubishi Master
  • 8,617 Answers
Change the coolant in the tubes also polishing the mirror does wonders for brightness levels. dont use windex, just a damp soft cloth then dry
Posted on Mar 26, 2008
TV Stuck on Video
hit input button u dont have orgibnal remote for tv so go to the tv hit ch down button to u see it chage the inputs to video 2 3 whatever your cable is on dvd ect ok
Jan 27, 2008 | Televison & Video
The tv gets really fuzzy and changes color after watching it, but i think it has something to do with the wire ports because if i hit menu while its all fuzzy, and when the menu comes up it looks normal,...
check cable connections:
1. cable from wall to tv or to pvr. properly connected?
2. yellow,red and white in correct ports?
3. if HD, use green, blue and red to respective ports.
4. is remote properly sync to tv?
5. if no 3 above, get HDMI cable and connect to pvr.
Aug 12, 2013 | Westinghouse LTV-32w3 HD Television
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
36'' Admiral fuzzy picture model GOJ 12390
you'll have to take the back off the tv and on your right you'll see two black button on the flyback transformer one over the other the other the top button is for the focus you can bright or darken the image on your screen don't be afraid it will not bite as long as you don't touch nothing but the button with a phillips screwdriver and don't have the kids around when you are doing it
Jan 15, 2009 | Televison & Video
Broken TV
the solution to fix you tv is replace broken video cable tv obviosly cant find an input.
Aug 25, 2008 | RCA F32650 32" TV
are you watching with using time warner cable or an HDTV converter box? because if you are....on the bottom of your cable remote..on mine its the # button..above it says aspect...press that a couple of times and there are different zooms and stuff.
Jul 21, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Funai tv
Open the back cover and check any fuse blow in Y Sustain board or Z Sustain board. If you do find the fuse gone, replace the board. Good luck!
Jan 25, 2008 | Funai F42PDME 42 in. Plasma Television
Poor screen resolution and unable to get channel guide.
The channel guide is a service just like closed caption. Rumer has it that it's not going to be around for much longer. The only fix is to unplug set ..wait awhile till memory loss occurs...plug back up and do a setup. Nothing in the TV will cause partial guide. Weak signal could and cause fuzzy picture too. Complain to cable company. But brightness problem is something else.
Dec 27, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Fuzzy white lines
YOUR tv DEVELOP a problem in the video ocillator or the tunner section have this set check by a qualified tech.to solve your problem good luck.any more contact nicodhem@yahoo.com i hope by now you have gotten your set fixed the repairs will cost you about between $50.00.to $200.00 good luck.
Feb 25, 2007 | Sharp 32U-S60 32" TV
Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
