Question about Hotpoint NVL333EY Electric Dryer
DOES NOT POWER ON. IT IS PLUGGED IN AND BREAKER
DOES NOT POWER ON. IT IS PLUGGED IN AND BREAKER IS OK
  • Hotpoint Master
  • 8,220 Answers
Look for air flow problems first and correct that. DOES NOT POWER ON.  IT IS PLUGGED IN AND BREAKER - c538a49.jpgThen check the fusee854bb7.jpgto get to the fuse you needs ta unpluDOES NOT POWER ON. IT IS PLUGGED IN AND BREAKER - 64a705e.jpg and pop the top. Start here:then get DOES NOT POWER ON. IT IS PLUGGED IN AND BREAKER - b0e39ec.jpgff0cc56f7.jpg4cb80a4.jpgb0e39ec.jpgCheck the non resetable limit we4x800 babes. Nothing to it.
Posted on May 03, 2010
Testimonial: "That was the problem and is now fixed. Great pictures to follow. Thanks a million. 5 thumbs up!"
  • 1 more comment
  • Dan Webster
    Dan Webster May 03, 2010
    Broken belt might kill power to the motor on some models and check the door switch for continuity.
  • Dan Webster
    Let me know.
  • Dan Webster
    Dan Webster May 04, 2010
    Thanks
6500 power train I think my ignitor box is bad don't understand how it works or how to test
Stove top? Are you sure the power supply is plugged into 120vac socket? Are you sure the receptical has power? Check with another appliance or light. If no power. Check your circuit breaker box. If circuit breaker is ok, Check for ground fault recepticals. Check test button. Reset. Check stove receptical above again. Hopefully you have solved the problem. If breakers or GFI will not reset, you have a major electrical problem. Call electrician.
Mar 08, 2015 | Kitchen Ranges
I have a crazy fit massage machine that comes on ok and you can program it but as soon as you press the start button it trips the electric anyone any ideas ?
You have it plugged into teh wrong breaker possibly, see what breaker in you power box controls the washer, and plug it into an outlet that uses a bigger breaker, possibly 35AMP or so.
Sep 27, 2012 | Washing Machines
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
Getting no power
Try push down on power button, until it turns on. If not, sell the good lcd as a parts TV on ebay?
Feb 09, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
Every tme I plug in an extenson cord the circuit breaker trips.
Try a different cord and see if it works ok. If the circuit breaker trips without anything plugged into the extension cord then the chances are that there is a short in the socket of the cord or it is wired incorrectly.
Apr 27, 2011 | Briggs & Stratton Briggs and Stratton...
Our GE Dishwasher just stopped all together. No power..nothing. All the fuses seem ok. Not sure why it just died. WIRES seem to be in tact..etc.
Ia the fuse blown? or the breaker tripped off? Must know if these are the problem. Plug in other small appliances in outlets in the kitchen to see if power is there. If not go to breaker box(usually in garage) check your sticker label and reset horizontal switch(curcuit breaker)back to on position. Note; sometimes these breakers can look like there on, if not sure switch off and on again. If you have power to outlets( INCLUDING WERE WASHER IS PLUGGED IN) you'r all set. Check the outlet where washer is plugged in, you may find a breaker built-in to it. The reset will be between upper & lower outlet, if so this needs to be pushed in.(most have tiny red button) Keep in mind the outlet might be defective. Never work on electrical untill you are sure that you have the right breaker OFF! If not sure call a professional! Good luck, best regards.
Feb 01, 2011 | Dishwashers
My craftsman conpressor is a 5 gal type oil free. problem is when I plugged it in to operate it the moment I turn on the switch, it would run a few seconds and tripped my circuit breaker in the house for...
First, the simple answer - check the AMP draw on the compressor. It should be on the motor or compressor nameplate/tag. Even a small compressor can use alot of power, and blow the breaker if there are other things on a circuit.
Does it seem to run OK for as long as it runs?
Oct 26, 2009 | Craftsman Air Tools & Compressors
I have a clarke en135 no power, fuse checks ok,
There may be a circuit breaker reset on the Clarke if not I would say you may have fried the power supply
Sep 02, 2009 | Welding Tools
No power to fridge. power to house ok, circuit breaker to fridge not tripped. what to do?
plug something else into outlet and see if it works your outlet/ wiring maybe bad if it works your power cord for fridge maybe bad have a short in it if outlet or cord is bad call eletrictian
Jul 07, 2009 | Sub-Zero Refrigerators
Triping breaker as soon as it is plugged in. can anyone tell me what usually is the cause of this problem when as soon as i plug the power cable in to the outlet, it would trip the breaker? no power to the...
try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
Mar 31, 2009 | KitchenAid KCMC155J Convection/Microwave...
Hotpoint NVL333EY Electric Dryer Logo
274 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
