Question about Brother MFC-7440N Laser Printer
Paper jamming Paper does not feed from the tray without getting stuck.
    Problem Solver:
  • 12 Answers
I would clean the rollers on the tray and make sure you are using fresh/clean paper. You can clean the rollers with a air canister, simply pull the paper drawer out and look for the grey/tan rollers.
Posted on Aug 26, 2010
How to fix a paper Jam?
quality of paper and the paper thickness setting may have something to do with it.
Jun 28, 2015 | Brother MFC-7440n Laser Multifunction...
I have WC 7535 when I give print or copy from tray 2,3 & 4 printer showing paper jam in tray module
Look carefully on the left hand side. All the paper from those trays pass up the left. ( you probably know that) The last time I worked on one of those machines paper feeding up from those trays can get stuck you've got to investigate where the paper is stuck coming up from the trays. Open the left door and very carefully see how far the media has traveled, does the lead edge get damaged, dented or spoiled in any way. ( look closely there) don't just rip out the paper, investigate why. Just how far has the media moved from the tray selected. I suspect a torn bit of paper stuck inside. If your machine is difficult to get to you must make room to look properly with a torch if necessary. Pull out trays 1 & 2 fully so you can look without being hindered. Good look!
Jan 12, 2015 | Xerox Office Equipment & Supplies
The roller on the feed tray keeps feeding through eventhough there is no paper there and the panel keeps saying there is a jam
If it doesn't do this with paper in the tray, it's a stuck paper present sensor flag.
If the machine thinks there's paper there, it tries to feed. Since paper doesn't make it to the timing sensor, it shows a jam.
Check for a stuck flag above where the leading edge of paper would be with the cassette inserted.
Mar 04, 2011 | Xerox Office Equipment & Supplies
IBM 1332 printer error #241 Paper jam
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
  • Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Oct 04, 2010 | IBM Infoprint 1332 Laser Printer
MY DELL 968 ALL IN ONE PRINTER JAMS PAPER. WHAT TO DO ? TRIED FLUFFING PAPER, CHANGE SETTINGS, UNPLUG-REPLUG. NOTHING WORKS
Please post your feedback and Vote if the poblem resolved as per your satisfaction.
Aug 15, 2010 | Dell 962 Photo All-In-One InkJet Printer
Help i have a paper jam!
Jul 20, 2010 | Epson Stylus NX300 All-In-One InkJet...
Paper jamming in printer. Pulling one side before the other causing it to jam... Brand new, bought Sunday
Answer:
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair.
•If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
•Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
•Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
•Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
•Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Jun 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Resetting PaperPort after paper jam
I found the solution to this problem. Whenever the paper jammed in the feed tray, I was pulling the jammed paper out without opening the door of the feed tray. Apparently, PaperPort gets confused and does not know how to proceed. Now when I get a paper jam, I open the door of the feed tray, take out the paper, click on the paper jam error message in PaperPort, reset the paper in the feed tray, and then hit "scan." Works like a charm.
Sep 30, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Brother MFC-7440N Laser Printer Logo
127 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
