Question about Lands Phones
Crackling noise on Uniden digital 5.8 cordless phone have tried moving to another outlet but same problem
  • 790 Answers
Hello ,
Its a common problem in uniden phones ... try resetting ur phone once ...
Posted on Mar 26, 2008
  • Kanth raj
    Kanth raj Mar 26, 2008
    And also check ur main terminal connections ... clean and reconnect them !!!
  • Kanth raj
    The first thing that you want to ensure is that the phone is not near any
    major electronics or appliances. Make sure that the phone is not tied in with a
    computer, fax, remote answering machine, splitter or caller id box. Try pressing
    the channel button on the handset (if applicable to your product).
    On DCT models turn clarity boost on. Make sure base unit antenna is in an
    upright position (if applicable to your product). If your handset does not have
    an antenna then make sure you are not holding the phone to where you are
    covering the internal antenna. Try moving the phone to a different phone jack
    and outlet.
    If you have any other cordless phones in your home, try unplugging all of the
    phones except for the Uniden and see if there is a difference.
    Finally, if you have computer accessories such as DSL, Wireless Network or
    Router, they could interfere with the phone as well.
  • 99 Answers
Try the following:
1) Make sure there are no electronics close by that may cause interference such as computer, radio, microwave, wireless router, etc.
2) You can also try changing the channel on the phone to see if that helps clear up the signal
3)Reset the phone - if you want to try this and do not know how send the exact model # and I can get you the info.
Hope this helps!
    Brigadier General:
  • 6,966 Answers
To my knowledge, this is a design fault of most 5.8GHz phone. This is due to the relatively high frequency it uses which makes the range a little bit smaller compared to other phones. Thus said, (limited range) moving away from the base increases interference and hences the static/crackling noise. Most 900MHz phone are better with cleaner/clearer audio. Sorry.
The solution would be to operate the handset pretty near the base. Some other appliances/electrical/electronic devices can cause interference.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Mar 26, 2008
    Hi buddies, sorry to have doubled up. The usual excuse, did not refresh before posting. Cheers.
  • 871 Answers
Replace the mouthpiece speaker.
SOURCE:
What does New CID:30 mean on my Uniden DECT 6.0 phone?
you probably need to delete some of you calls and you may need to uplug all you phone jacks from the outlet and wait 3-5 min and plug them back up that seems to fix a lot of problems with cordless phones
Jun 18, 2014 | Uniden Cordless Phone
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Crackling noise on phone
If your phone is wireless this may help. Had my wireless voicebox set up near electrical equipment and controls for the airconditioning unit and had crackling noises on the phone. When I relocated the voicebox to the other side of the room and connected to the electricity without other equipment connected, it is now very clear.
Oct 16, 2010 | Uniden Cordless Phone
Crackling static noise on calls
Make sure that there is no fault inthe connection from the line terminals. If both the sets have the same noise connect a base phone and test the line as it can be from the telphone line itself producing the static from the nearest junction or cable line.
If not the base phone input section may have errors.
Sep 26, 2010 | Uniden Cordless Phone
Retrieve deleted messages from uniden cordless phone
After its deleted then its deleted forever. These are not like the old answering machines that all you did was pull the plug and plugged it back into the wall outlet to retrieve old messages was were deleted. When digital you can not do that....Sorry
Jan 03, 2010 | Uniden Cordless Phone exai398i
Uniden 3315 Frequency Problem
Your phone has Digital Enhanced Cordless Telecommunications (DECT), known as Digital European Cordless Telephone[1] until 1995, The digital filters will prevent interference from the bandwidths used by phones and wi-fi.
Your phone also incorporates dynamic channel allocation which switches frequencies when noise(static) is encountered.
Eventually your conversations take a wire route down the road. You are getting some "cross talk", an actual scientific term used to describe signal transmission from one line parallel to another by magnetic eddy currents. I would call the phone company and have them trace the problem.
May 13, 2009 | Uniden Lands Phones
Uniden base display does not work after chargin for 1st time.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
May 05, 2009 | Uniden DECT 6.0 Cordless Phone ID
Uniden 5.8 GHz Digital cordless w 3 handsets interference background noise no matter where we are in the house or which handset we use
This is possibly caused by the internet connection.
Try new ADSL filter.
You need one each per device.
Oct 06, 2008 | Uniden Cordless Phone
Lands Phones Logo
1,627 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
