Question about JVC Everio Share Station DVD Burner Burner
JVC Everio Share Station DVD burner
What lens do you clean? How do you change the drives?
  • 2,427 Answers
There is a cd / dvd lens cleaner avilable that you can purchase and it does the work for you.. its just like a cd inquire in your local shops..
If you want to do it manually ,, take the burner apart, and using a qtip and strong liquor or rubbing alcohol gently clean the lens and let dry.. The lens is a small thing attached between a bar.. it fits in a slot and can move along the length of the cd.. it has a small glass like thing on it so you should be able to recgnise it easily.. I am not sure if i described it ok enough but if you need i can upload a piuc for you.
Posted on Jul 09, 2008
My dvd player does not playing the movie if a lens failure.
This could be for two reasons....most likely a dirty/scratched lens ....or because of malfunction of disc drive motor....cleaning the lens gently may help...if lens is scratched....then the entire read head would need change...
Clean lens first ....if no improvement, try changing drive motor....and lastly the read assembly....which requires expertise and being adept at repairing...
Jul 10, 2016 | Televison & Video
Why does it keep saying disc error
Probably you have a problem with optic reader.
Try to use an
Optical Drive Lens Cleaner kit.
iF CAN'T SOLVE THE PROBLEM, YOU SHOULD TAKE YOUR DEVICE TO SERVICE
How To Clean Slim DVD Drive Lens and Laser From Dust
or you can try to do it yourself it you have some technical knowledge
how to chang the dvd writer lens
Jun 08, 2015 | Video Game Consoles & Games
My ASUS DRW 2014S1 which reading dvd but not cd. what's the reason
Reason:
Drive optical Lens is getting Weak either by dust and dirt or Wear and Tear degradation. First it stops CD reading and then DVD reading as well its normal behaviour
Solution:
If the drive is Internal type for Desktop you have the option to clean the Lens through CD lens cleaner with Brushes installed over the surface of CD.
If the drive is Tray type for Laptops then you have a better option to clean the Lens Physically open the Tray take a Micro Fiber cloth or you can take a Tissue Paper see the Eye like Crystal round thing that moves when you load CD this is Lens , please just take the Tissue paper and clean the lens with your finger Gently in Circular Motion do not use extreme force.
If it helps then ok otherwise you have to change the Drive now its about time
Please Rate me if i helped
Oct 03, 2011 | ASUS DRW 2014S1T - Disk drive - DVDRW /...
My cd drive not working
Hi, when the lens of the CD player is weak, it can still keep on spinning and not and will not play. what you will need to do is to get a lens cleaner and clean the lens(instructions are on the lens cleaner.
If after cleaning and it still did not work, that means the lens is to weak to perform well. It will need to be changed to a new lens.
Take care.
May 27, 2010 | Audio Players & Recorders
Blu-ray movies wont play
This problem is usually associated with the Bluray drive or more specifically the optical laser on the drive which is failing to read the disk. Sony charge $150 for this repair if the console is outside warranty.
You could try cleaning the lens on the laser as this can work sometimes but this requires you to open the console and most often the lens is faulty and needs to be changed. For more information on the lens and how to access it either to change it or clean it please see this FixYa Tip.
Thanks for using FixYa
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
PS3 won't play any type of disk
i believe you should have a lens replacement i.e change the lens
Apr 06, 2010 | Sony Playstation 3 (PS3) Console
Hello i just cleaned my lens and its still not reading the disc i was just on this morning
u should not clean the lens through any materials
just bolw ur air into the lens
it better to change dvd drive, there are different kinds of drive for xbox360,
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
Cd drive does not recognize cd's or dvds
cd lens problem please change it.before that try to clean the cd rom drive lens with a lens cleaner cd
Sep 19, 2009 | Computers & Internet
Aspire 5315 cd drive wont work. i unistalled and reinstalled still wont work
If it is just not reading discs then the drive lens most likely just needs to be cleaned. Clean the lens using a lens cleaning kit and then test it again.
Sep 07, 2009 | Acer Aspire 5315 Notebook
Cd/dvd drive not working
pls try to clean the lens thru following procedure see if it helps otherwise u have to get ur drive changed
open the dvd tray u can see that shiny eye like thing try cleaning th lens gently in round movement with a tissue paper or very soft cloth used to clean lcd screens see if it works , other wise ur DVD drive lens got weak from use now adays service centers are getting tons of them everyday for replacements
pls do rate me fixya if u like
Mar 13, 2009 | HP Pavilion dv9700t Notebook PC
JVC Everio Share Station DVD Burner Burner Logo
89 people viewed this question
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Kim Halliwell
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
