Question about Karcher 2500 PSI Pressure Washer
Very low pressure after a few seconds
I have been told that it might be the unloader valve but i am not sure how to clean the valve and maybe replace o-rings
  • mickeywalker May 14, 2010
    thank you Kelly I Got both pumps working great without tearing them apart your tip worked great thanks again. I will be sure to add winterizing fluid from now on.
  • 3,740 Answers
These pumps are notorious for seasonal problems.
Tip the unit to the point you can pour engine oil into the water inlet connection. What your attempting to do is free up the ball seats in the pump. They get corroded when they sit and lock in place. Adding the oil or a vast amount of WD 40 to the water inlet often does the trick for loosening up the seat balls and springs.
After you add the oil (3 - 4 ounces) or WD 40 to the water inlet line just slowly pull the engine through with the ignition switch off. As the water inlet cavitates add more oil.
Let it sit over night and then take a block of wood and a hammer and tap on the power head. Don't over do it and do it in such a manner your not going to shear off any bolts or break anything. But... be serious with the hammer and block of wood.
Then connect inlet water hose, the pressure hose and test the unit. You may want to purge the oil lubricant into a bucket before you start the engine.
Give it a try and see what happens. This works more often than you would think.
Thanks for using FixYa,
Kelly
Posted on May 04, 2010
Testimonial: "thanks I will try that it makes since because when I start it up I hold the trigger to relieve the pressure and have good pressure until I let go and the next I pull the trigger nothing but regular house pressure"
  • Kelly
    Kelly May 13, 2010
    One more note: If you again have to get into the unloader valve, lubricate generously everything with No. 105 Lubriplate "white" grease. (Plastic tube available at auto parts stores)
    Kelly
Pressure washer has low pressure
from experience , pressure regulator valves seldom cause a problem
mostly it can be attributed to a blocked or partially blocked jet at the end of the wand
make sure that that is cleaned and that the pressure hose is not failing internally KInked , run over etc
Mar 13, 2017 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
I have a vt631401aj campbell hausfeld compressor. when it builds pressure to 135 psi, the compressor shuts down and immediatly starts dumping air until it goes down to 90 psi. It then stops dumping the...
John: I had a similar problem with a brand new CH-made compressor. The problem was not with the unloader valve, but with the check valve located where the air from the pump enters the tank. The check valve was not seating correctly due to brass filings from manufacture. The defective check valve was allowing air to escape back the wrong way from the tank to the pressure switch and through the unloader valve. This backflow from the tank would start to happen when the pump stopped after reaching high pressure. The back flow would continue until the pump restarted at the low pressure point. This cycling would continue as you described. Once I cleaned the check valve, everything (including the unloader valve) started working correctly. I hope this helps. And remember, don't work on these when they are under pressure and always wear safety glasses.
Sep 18, 2011 | Campbell Hausfeld Air Tools & Compressors
Pressure off and on every few seconds with my karcher 3000BH
hi there rjcomer2
here is web site for parts
http://www.ereplacementparts.com/karcher-2500-11944010-pressure-washer-parts-c-33388_33389_33973.html
sounds like you have a unloader valve problem or a crack in the pressure manifold housing between pressure outlet and unloader valve assy allowing unloader to cycle on/ off
or some dirt trapped in the unloader valve seat , make sure you have good supply of water - ie good flow from tap to pump
try cleaning unloader 1st and fitting in line tap filter
hope it helps
pauly46
May 20, 2011 | Karcher 2500 PSI Pressure Washer
Devibliss 60gal hp.runs to 120psi and cuts off, on restart it stalls and kicks reset on motor. Ive replaced pressure switch unload valve and pressure valve.stiill run. On second run at start you dont hear...
Some air compressors have 1 or 2 pistons one the piston sleeves could have a crack or a small hole what i would do is clean every thing and make sure the inlet valve is open and the unloader valve is clear of debris but if it doesn't help then you propably have a cracked piston sleeve I hope i was helpful ( tell me the model of it and i could get you more information)
Apr 07, 2011 | Campbell Hausfeld Air Tools & Compressors
No pressure coming out of hose when motor is going hard I can put my finger on the end of the spray wond and there is hardly anything Karcher 5.0hp GC160 K2400HH
First thing is remove the water supply house and check the water screen for clogs. Remove the hose washer and pull the screen out. Wash and clean the screen then re-install. Make sure your using a 5/8" hose as a supply hose and that the water faucett is turned all the way on.
If after all of the above it still has low pressure the unloader valve is most likely corroded or has debris in the seals.
Download this parts manual The unloader / thermal valve that is supposed to reset is Item(s) 9 {Valve 60 GND} and 12 {Spill Valve} of detail A on page 11. The spring, seals and housing need a good thorough cleaning to get high pressure. If the seals are damaged they will have to be replaced. Lubricate the seals with lubriplate white grease No. 105 before you reassemble the unloader valve. Grease link: http://www.lubriplate.com/webstore/default.aspx This grease is at any automotive store.
Thanks for using FixYa.
Kelly
May 10, 2010 | Karcher 2500 PSI Pressure Washer
Air compressor leaking air
you have a bad check valve ,the little brass valve is working normal
Apr 18, 2010 | Clarke Power Products AC2002A 2 Hp Air...
Clean and unloader valve on Karcher hd3500 pressure washer -intermittent pressure on and off. Cleaned inlet screen. Think unloader valve is is under pressure knob? Will cleaning help?
Hi:
Cleaning it is not enough. You need to make sure the o-rings are in good shape and grease it with a very very good waterproof grease. Here is a schematic of the pump. The unloader is parts 7 to 13 on D-2
Sep 08, 2009 | Karcher Garden
How to clean unloader valve..
The Karcher K2400HH and G2400HH do not have an unloader valve, they have a spill valve which is located under the black cap on top of the pump.
The spill valve needs to be removed and the side walls of the hole it sits in need to be wire brushed to remove deposits. then you can put it back in and put the pump back together.
Jul 03, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
809 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
