Buffalo Technology WHR-G54S Wireless Router (WHR2G54S) Logo
Anonymous Posted on May 03, 2010
I can not get connected. Woke up this morning and no internet conection, local only and the conection is refered to as Network.
  • 2 more comments
  • Anonymous May 03, 2010
    I'm able to get internet connecetion if I plug a cable into the modem or the router.
  • Anonymous May 04, 2010
    No I mean router or modem. the router has ports to plug in an ethernet cable. I am not sure where to go to releas and renew the settings for the WAN config tab. Thanks for the help I need all i can get.
    Thank you so much for all of your help, problem solved. I really appreciate your patience and persistence.
Anonymous
Level 2:
Sergeant:
  • Expert 172 Answers
  • Posted on May 03, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
172
Questions
0
Helped
52873
Points
544
Hello, the local only means you have connection to the router but the router does not have connection to either the modem. Did you try resetting the modem?
Turn off both devices (router and modem) turn the router on first. Then turn the modem. Wait a minute or so and the router should get the IP from the modem and it should work.
If you still have no luck, it means there's something wrong with either the modem or the actual connection from the ISP.
I hope this helps.
Testimonial: "I hav enever had such top notch help with out having to pay an arm and a leg. If ever you are in need of advice on how to get and stay connected, you came to the right spot."
  • 1 more comment
    "I'm able to get internet connecetion if I plug a cable into the modem or
    the router." I'm assuming you meant into the modem not the router. OK, then you have to login to your router 192.168.1.1 (that's the default ip) and under WAN configuration tab, release and renew the connection. Let me know if it worked.
    Ok, let's try this. First, make sure that this switch is in the normal (AUTO) position (at the bottom of the router).
    On the bottom hold down the “INIT” button for three seconds.
    This will reset them to factory defaults. They
    will take 30-60 seconds to reboot afterwards.
    - You can also log in to your router and under advance configuration you will se the Initialize button - that will also reset your settings.
    1. Power down the Cable or DSL modem and the computer which will be used to
    configure the AirStation router.
    2. Plug the Cable or DSL modem’s Ethernet cable into the AirStation’s WAN port.
    Initially, you may need to unplug this cable from your computer, hub or other router.
    3. Plug the provided Ethernet cable into one of the four LAN ports on the AirStation and
    plug the other end into your computer’s Ethernet adapter (NIC).
    4. Important: turn everything on in the correct order!! Power on your cable or DSL modem
    and wait one full minute, then power on the AirStation and wait one full minute, and
    finally power on the computer which will be used to configure the AirStation.
    Log in to 192.168.11.1 (default router ip) the username is root and just click connect.(password is blank).
    Under WAN Configuration tab Normally, the
    internet connection wizard will set this for
    you if you have a cablemodem or DSL. If
    you’re not sure what to choose, perform
    Easy Setup. Or click on Aquirer an IP adress automatically from a DHCP server. (this should be your modem)
    And once you are sure you can get online. Then log in and configure your wireless/security settings, admin password, etc.
    This is as basic we can get. If you followed this correctly and still no luck with your router, please let me know.
  • Anonymous May 05, 2010
    Hello elijah. I REALLY appreciate your commentt! Thank you. :D
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 19, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
299
Points
I am having this problem on my Buffallo router, it automatically gets reset and we need to configure this again. Seems like some firmware issue.
2answers
What does the LAN do on the modem
There are two halves to a router. The internet (WAN) side a local network (LAN) side.
The term WAN means Wide Area Network and generally refers to the internet.
The term LAN means Local Area Network. That would be for the computers that are in your office or home.
The LAN connects your computer to your printers or to other computers.
I hope that answers your question!
Laptop wont connect to internet
Your laptop has a manual IP on it you will have to dis able the IP and make it automatic for it to browse the net would have been more detailed if I knew the operating system u are using
1helpful
When trying to connect to the internet via cord, my laptop will say limited or no connectivity. I have restarted it and started all the applications that were disabled. i also have the wireless chip for...
On the right below task bar find network conection >>> open network conection
On Local Area Conection ( cord ) right click >> properties rolls down to Internet protocol (XP) or IPv4(WIN7) click properties >>> on general tab choose Obtain an IP address automatically >>> click OK >> OK
[email protected]
Acciring network address but wont conect cant get ip address
try to disable the LAN by clicking Start > Control Panel and then click Network Connections . Then right click Local Area Network connection then click disable. Restart the pc and do the same thing except you will enable the Local Area Network. Check if you will have internet connection..
Internet connection
Dear Sir,
plz folow this step
For XP-> go to your control panel -> click under network connection -> right click on Local Area Connection and disable it -> right click again to enable it back.
For Vista-> go to your network and sharing center-> click under manage network connection located on the left hand side -> right click on Local Area Connection and disable it -> right click again to enable it back
if the probelm not solved then give IP address manualy for internet above same processdure
HOW CAN I GET INTERNET CONECTION IN MY LAPTOP
I assume that you have loaded all the drivers for you laptop from
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D410&os=WW1&osl=en&catid=&impid=
If you need the manual,
http://support.dell.com/support/edocs/systems/latd410/en/index.htm
The instructions for connecting to a wireless network is under the "wireless local area network" instructions.
1helpful
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
Although the internet connects on my PC my laptop won't connect via the router
check that your router is working that lan cable is working, and right click on network places in your laptop screen go to the properties and check there local area conection is enable if disable enable it and check your ip, if there is no local area conection you have to install the network adapter driver
2answers
Cannot connect to router wirelessly.
Yes that's it.. try changing some wireless settings on your router like the ssid or wireless network name channel use channel 1, 6 or 11 then try to connect to your wireless network.
Network
hii you conect net server pc . all pc conect in switch ..then your name all pc diffence .. and net conect server pc then go net conection dailbox properties ..networking ....enabil network conection then so server pc auto ip address....apply ok  done
Top Buffalo Technology Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
