Question about Audiovox NVX225 Car GPS Receiver
SD card my NVX 225 has slot for a SD card but I can't read any data from the card
  • Jacques Pouliot May 30, 2008
    Thanks David.
    Have you been using this 256MB card with the NVX 225 Receiver?
I use a 4GB SD card in my NVX225. One thing to remember, the SD card's only function in the NVX225 is backup your settings from within the navigation advanced tab.
However, I did find a nice HACK for the NVX225 that permitted me to install a media player. I can now play MP3 audio and compressed movies (.mov .avi etc.) on my unit. Sure comes in handy when flying cross country.
Posted on Oct 24, 2008
I called Audiovox and it IS 2GB
Posted on May 30, 2008
Not a solution I'm afraid, but an observation. I tried a 4Gb card to no avail. Formatted it with:FAT, FAT32 and NTFS and it still was not visible. My feeling is it will not read larger cards, perhaps topping out at 1 or 2Gb as I am currently using a 256Mb card with no problems.
Just an FYI.
Good Luck,
David
Posted on May 27, 2008
SOURCE:
Phone says sd card is blank
I'd try it in a laptop or PC SD card reader. If the card still reads blank it is likely the data is corrupted. There are software recovery softwares many of them free that attempt and quite often successfully restore data from the card. If you can do this then save a copy on a PC and immediately format the SD card (FAT32).
Copy the saved data back to the SD card and reload in your phone to see if the phone can read it. If not, either the SD slot on your cell is damaged or the card may be damaged. A full phone reset should be your next port of call and then try the card again.
Apr 04, 2014 | Computers & Internet
HOW DO I TRANSFER FILES FROM PHONE SD CARD TO COMPUTER?
You can use memory card reader with SD card slot to be able your computer read it. Or you can use data cable for HTC cellular phones to connect to computer
Sep 17, 2011 | HTC Cell Phones
How do I use the Micro SD port?
hi.
sd port is use for read yr sd card.. put yr sd card in sd port then yr can read it from clisk my computer icon and ten yr card will be locaten in g/h/f or try click 1 by 1 memory stick drive
regards
Feb 21, 2011 | eMachines Desktop / AMD Athlon Processor /...
Have an HP L7680 all-in-one Just received a Panasonic Limuix camera and cannot read the SDHC memory cards in the SD slot - Printer posts an error
No, it's not possible, it'll never read SDHC in the SD slot. SD slot will only read SD, Mini SD (with adaptor) and Micro SD (with Adaptor). If there's no SDHC card slot, then it doesn't support SDHC Card. The lists of supported memory card are listed below:
CompactFlash™ Type I and II,
Secure Digital/MultiMediaCard/Secure MultiMediaCard (SD),
xD-Picture Card,
Sony Memory Stick®,
MagicGate Memory Stick,
Memory Stick Duo,
Memory Stick Pro
I hope this clears your doubt.
Note: SDHC and SD are different Memory Card types.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
I have a pure digital camcorder model # 225 and I see a slot on top of the camera and I'am wondering if this is for any sd card ? can you let me know about this , please thankyou , Rafael
I have a pure digital camcorder2_bing.gif model # 225 and I see a slot on top of the camera and I'am wondering if this is for any sd card2_bing.gif ? can you let me know about this , please thankyou , Rafael
Feb 05, 2010 | Pure Digital Flip Video Camcorder
My SD card reader on my Sony Vaio will not read the card...it seems to know its in the slot, but won't read any data and says 'insert the SD card' if I go to computer and try to read it. Any thoughts?
Take a can of air and blow some into the slot to make sure dust or dirt isn't getting the way of that reader trying to read the sd cards.
If you still get the same message try another SD card in that reader or try to see if another computer will read your SD card, if another computer will read the SD card and the slot still won't recognize the sd cards properly, then you know at that point the reader is bad. If the reader is bad, thats integrated into the motherboard so the motherboard would need to be replaced.
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
My mini sd card is in raw format and my computer can't read it - how do i change it back to fat file system ?
  1. Place the mini-SD card within the mini-to-SD card adapter. Make sure the tab on the mini-SD is facing the upper side of the adapter. Slide it in slowly, being careful not to damage the pins.
  2. Slide the adapter in an SD slot on your computer. If you do not have an SD slot, place the adapter in a USB card reader, and plug that into a USB slot on your computer. Give the computer time to read the card.
  3. Open "My Computer" (usually located in your start menu) and navigate to your mini-SD card. It will usually be recognized as a drive such as "E:" or "H:."
  4. Right-click on the drive and select the "Format" option. A menu window will open.
  5. Make sure that the drive size is set correctly, and that it is set to the file system you wish to use (usually FAT32 on an SD card). If you don't know what file system you should use, just leave it at the default setting.
  6. Enter a volume label, which is the name for the drive, then press start. This process should only take a few minutes.
WARNING
  • Do not use the "Quick Format" option unless you have just recently formatted the mini-SD card. "Quick Format" doesn't completely erase all data and is not effective unless used after a full format.
  • When you format your mini-SD card, all of the data on it will be erased. Make sure to back up your files on the card before formatting
Sep 25, 2009 | Electronics - Others
Why cant I download my waypoint data to a 2 GB SD card. My Global map 5000c does not recognise the 2GB SD card. Do I need MMC/SD. Can I place the sd card in the slot beside the chart card ?. Thanks
You can place the SD card into the slot beside the chart card.
With the SD card in the GlobalMap unit by itself (take the chart card out), press MENU twice and choose BROWSE FILES. Does the unit indicate that an SD card is present? If yes, the card is working fine in that slot. Try the same thing in the other slot. If it only recognizes the SD card in one of the slots, the other slot is bad and probably won't work with any card. If the card is recognized in the BROWSE FILES menu, but the data that is on the card is not working, there could be compatibility issues with the data and the GlobalMap 5000.
Make sure the GlobalMap 5000 has the latest software update from http://www.lowrance.com/en/Products/Legacy-Products/GlobalMap-5000C/Downloads/GlobalMap-5000C-Software-Update-180/. You might need to get a different, smaller capacity card since your 2GB is not working.
If the 2GB SD card still isn't recognized in the BROWSE FILES menu after the update, the GlobalMap 5000 is not going to work with that 2GB card. You will want to get a different card. I suggest 1GB and smaller.
If this doesn't help, please let me know some more details. Is the 2GB SD card recognized in the BROWSE FILES menu. What are you seeing that makes you determine it does not recognize this card? What files are currently on this card? What kind of card is it (brand, model).
Jul 11, 2009 | Lowrance GPS
Ricoh aficio 2090 gives sc866 when i put sd card in the slot &how i give up the license data
The error showing is for programme error on the sd card either the card is currupted or the wrond data is on the card my advise would be to download the newest driver/programme and try again you can try this with a new sd card also the original might have some other drivers installed and this is causing teh miss read..Good luck A
Jun 28, 2009 | Ricoh Office Equipment & Supplies
Kodak EasyShare SV811 won't read SD / HD card
Compatible Card-Slots : SD/MMC; xD; CF;Memory Stick; Microdrive; USB
You might have too much data on the SD card. Try with less pics onto the card.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jun 25, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Audiovox NVX225 Car GPS Receiver Logo
301 people viewed this question
Top Audiovox GPS Experts
Marvin
Marvin
doughboy0486
Level 1 Expert
Are you an Audiovox GPS Expert? Answer questions, earn points and help others
