Question about Ruud Central System Air Conditioner
The outside air unit at my house just replaced contact switch but inside unit wont come on and the red and green light on outside unit r flashing whats my problem
  • laura Newman May 11, 2010
    Try turning the system off and putting the fan switch in ON position. Will the indoor fan start running?
  • 674 Answers
There should be a legend close to the flashing lights to let you know what the sequence of lights mean. Make sure your circuit breakers are on and if you have one of the pull out type disconnects make sure it was put back in. Let me know what you find.
Posted on May 03, 2010
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
I need a list of codes for my lennox hp26-036-7p the red and green lights on the outside unit are flashing continuously. the outside unit acts like it wants to come on and i can her it running but it is...
LED Flash list should be located on the inside of the unit's electrical panel by the wiring schematic, and by counting the flashes in between the longer pauses should give you the diagnostic code. A continuous steady flash can also mean normal operation, and something else on the inside could be holding you out like a float switch tripped (located on emergency pan underneath Air Handler Unit If Applicable) etc.
Jul 05, 2011 | Heating & Cooling
I have a mitsubishi air conditioning unit model MUH-12v. The fan on the machine outside has stopped and of course inside the air is not cold. Could this be a problem with replacing the gas or could it be a...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Aug 30, 2010 | Heating & Cooling
I need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
Oct 08, 2009 | Heating & Cooling
I have a RUUD AC Model UPFA 060JAS, Serial # 3687 F4787 3195. My dog ripped the wires apart on the outdoor unit. Wire coming out of the house (6) are colored red, blue, white, green brown, and yellow. ...
Paul, you will need to look at the indoor unit and determine which wires from outside are connected inside. let me know. more then likley they color coded it but better to be safe. also does the fan inside still run if you switch thermostat to fan ON. if not the transformer may have blown, if yes you need to make sure you shut the breaker controlling the inoor unit off while your messing with the wires, or you will blow the transformer in the furnace
Mac
Sep 26, 2009 | Heating & Cooling
My goodman air unit wont turn on but has power to the relay and can be manually overridden at the relay but doesnt sound like the air handler comes on. I changed the batteries in the thermostat and even...
Check the transformer. There could be a chance that the transformer is out. If you mean you can manually turn on the unit by pushing in the contactor switch in then theres your problem The thermostat engages the low voltage side of the transformer sending 24 volts to the contactor switch engaging the system if this transformer is out it will not engage the contactor to turn on the system.. Also on the air handler at the door on the bottom of the airhandler there should be a small circle of clear plastic by looking inside of this circle you should see a green led . If you see a red led it will be flashing count the flashes as they are emmited and once you see the pattern they have then remove the bottom door of the airhandler and on the bnack of this door is a code that corresponds with the flashes i.e. 3 red flashes, pause, three red flashes. The code will tell you what is occuring within the system. However, If your system is not a newer model it may not have the leds as I have described. If that is the case the first part of this solution may correct the problem.
Good Luck on your repair
Dave
Aug 31, 2009 | Goodman CLT24AER24 Air Conditioner
Unit wont start, flashing lights on indoor unit, fuse may be gone
How old is it? Can you justify spending lots of money on an older system? Sounds like a transformer issue. Sometimes if the low voltage wiring gets shorted outside via dog or weed eater it will short the transformer. But if transformer is on control. Controls are cheap at supply houses maybe not from technicians
May 28, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Ruud Central System Air Conditioner Logo
130 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
