Question about PC Concepts Wave TP5.0 (61585) Keyboard
PC Concepts SK-6000 keyboard suddenly loses
PC Concepts SK-6000 keyboard suddenly loses contact with computer and does not respond. I have to reboot computer to get keyboard to work again. I have not intsalled any drivers, but never thought that would be necessary as I have Win XP. I tried to pull a key off to see if it was dirty underneath, but these keys dont seem to want to come off without a hard pull, and I am not going to risk doing that. Is there a trick to doing that?
PC CONCEPT SK-6000, KEYBOARD WORKS WITH USB ADAPTER, BUT MOUSEPAD WONT. HELP
Install drivers should come with a disc install the software and all should work
Jan 04, 2014 | Maxi Switch Silitek SK 6000 Keyboard
Lite on keyboard sk-6000 USB conection windows xp
Make sure that all USB functionality is enabled in the BIOS, especially USB Legacy Mode. If Windows still does not recognize the keyboard, then it is not compatible with USB. USB keyboards can be found as low as $10 pretty easily if all you need is basic keyboard functions.
Feb 11, 2010 | Maxi Switch Silitek SK 6000 Keyboard
Keyboard wont connect i have windows vista home basic and a Sk-6000 keyboard
Make sure the computer is off, before you connect the keyboard. After you connect the Keyboard, go ahead and start it up.
Aug 28, 2009 | Maxi Switch Silitek SK 6000 Keyboard
I just bought 2 keyboards sk-3106 and no drivers
I just went through this as well, and found a (free) working driver here-
http://militarycac.com/keyboards.htm
Download the driver and install it, then reboot the computer. It will say "found new hardware". Manually install the driver by telling it to browse to the location of the *.inf file you just unzipped moments before. Even recognizes the smart/CAC card. ^_^
Jun 11, 2009 | Dell Smartcard USB Keyboard SK-3106
My PC Concepts Ergonomic Keyboard with Touchpad, SK-6000 model is wearing out on me. I want another one just like it and have searched the internet, etc. but to no avail. Any ideas where I can find one??
I have found them available (used) for sale by googling "PC Concepts SK-6000 keyboard" (without the quotes). Also try Ebay and Craigslist. The mfr went out of business years ago.
May 13, 2009 | PC Concepts Classic USB+2 (63142) Keyboard
Dell SK-8115 USB Keyboard on none Dell PC Issues
Have you gone in and removed the usb drivers by doing the following.
1.) right click on my computer
2.) select properties
3.) Select Hardware tab
4.)Select device manager
Then remove all instances of usb that you can.
You may have to try this using just the mouse for navigation. Right click on usb item then select uninstall. Remove all the ones you can then reboot the computer. You may have to reboot a couple times
Then try the keyboard it should work no problem
Jan 16, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Keyboard not responding
Boot in safe mode
>control panel
>Printers and other hardware
>Keyboard
>check to see if is has been disabled
??>does you mouse pad work
>If no plu a USB mouse in 1st before you boot into safe mode
Aug 28, 2008 | HP Compaq nx6110 PC Laptop
Sk-6000 keyboard
For the touchpad: if your keyboard equipped with standard COM connector try: http://www.acersupport.com/library/ti_note/2x0tpad.exe (older synaptics driver - working with COM port based touchpad perfectly) - or if you have converted it to PS2 connector (i converted my one from COM to PS2) you can use the latest generic touchpad driver from http://www.synaptics.com/support/drive.cfm . (sadly synaptics dropped support for comport based devices in the latest drivers...)
Dec 23, 2007 | Maxi Switch Silitek SK 6000 Keyboard
PC Concepts Wave TP5.0 (61585) Keyboard Logo
233 people viewed this question
Top PC Concepts Computers & Internet Experts
Computer Links
micky dee
Dilum Senarath
Dilum Senarath
Are you a PC Concepts Computer and Internet Expert? Answer questions, earn points and help others
