Is there an exploded view of the coupling area available? to suit a Whirlpool Commercial 7.5 kg (electronic temperture controll) wsahing machine.Ours seems to have broken the coupling.
    President:
  • 949 Answers
Here is a link to instructions I created to replace one. If you don't mind let me know if they were helpful.
Thanks!
http://www.fixya.com/support/r4670549-drive_coupling_replacment
Posted on May 03, 2010
Can you tell me are these machines ment to run 24/7. ours does and they only last about a year and half. what should I be buying instead?
Residential models are not built to run 24/7.
Try a commercial model.
If it were me, I would find a "Consumer's Reports" magazine and see what they say is the best commercial washer.
God bless your efforts.
Jan 27, 2017 | Washing Machines
Why does it display an 'out of order' message and code F28?
That means the motor control unit has failed and since this is a commercial machine, you may have to call because the part is not available. It lists for about 350 dollars.
Feb 06, 2016 | Whirlpool CHW8990BW CHW8990BW 27"...
I have dismantled my washing machine completely. I need an exploded view diagram to assemble my machine again please.
I can't find an exploded view but i found something even better:
http://britishjames.com/whirlpool_washer_repair_videos.htm
Let me know.
Jan 11, 2013 | Whirlpool Washing Machines
Dear Sir, Drier door Lid Switch (Whirlpool 6.2 kg Super soak model)pin broken, need replacement. Kindly inform whether is it available with Visakhapatnam distributor if not pls intimate the nearest...
Sorry. I doubt anyone on this forum could give you that information. It's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in telephone directories OR stay on line and search for the 'whirlpool washer service centre' or 'whirlpool washer spares' in you area and hope that you can find someone reasonably local.
Good luck,
John C
Mar 06, 2011 | Washing Machines
Dear sir, We want to buy 02 nos of whirlpool make 8.5 kg washer 02 nos and one nos of dryer. We need the same for our factry on contineous operation so we want the best...
Hi and welcome to FixYa, I am Kelly.
I understand you want a whirlpool washer. What are you washing? It does make a difference on what would be recommended. The other question is does it have to be a front load machine or is a top loading washer ok?
Right off the top of my head for an 8.5 kg washer I would recommend the top loading MAT Series by Maytag (owned by Whirpool) These manual timer machines can take a beating and over loading only causes belt wear that is inexpensive and easy to replace. The only drawback is that the top loading machines use more water per cycle than a front loading machine. My thought is this... water is cheap... smaller front loading commercial machines used in continuous manner end up costing you more in repairs than you would pay for the water.
Product info: http://www.maytagcommerciallaundry.com/on_premiseslaundry/top_load_washers/commercial_energy_advantage__8482__top_load_washer_mat15mnaww.pro?scr=category
Once you see the linked pages select "on premises lanudry"
What I will tell you about commercial laundry machines is this. Keep the controls simple such as the MAT series. Maintenance parts are available on line and your down time will be minimal. The Maytags have the best warranty also.
As for the dryer Gas or electric? I am going to assume electric since you said "Factory"
For this I would recommend the MDE17 series Dryers, The dryers are 4 roller drum type dryers so the weight is carried equally front and rear of the drum so that the drum seals have a very long life.
I have been a Maytag repairman since 1970 and started in a family owned business. These recommendations are from years of experience. You may pay more up front on the initial purchase but over the years the continued in service time and minimal maintenance required make these units extremely cost effective. If I were to start my own business with 8.5 Kg per cycle washing requirements The MAT Washers and MDE Dryers Maytags are exactly what I would use.
Remember Maytag was purchased by Whirlpool years ago.
All Maytag parts can be obtained through Whirlpool.
I do wish you the best, Thanks for choosing FixYa,
Kelly
Dec 12, 2010 | Whirlpool Washing Machines
We have a Whirlpool 7 KG fully Automatic washing and the display is showing FE and the water is not filling in the Machine
either your water supply is shut off or the water fill solenoid valve isnt working to let water past the fill valve or the solenoids are not getting power from the control unit to do so
Sep 29, 2010 | Whirlpool Washing Machines
Whirlpool microwave shows f-7
From the technical sheet hidden behind your control panel and online here:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Check resistance of the magnetron thermostat.
4. Check the magnetron.
5. Check wiring to the 1100W inverter and control system. See “Checking
Inverters.”
6. Check operation of all interlock switches. Check door, hinge and cavity front alignment. Adjust as needed.
7. If switches operate correctly, replace 1100W inverter.
8. If problem persists, replace electronic control.
9. Plug in microwave oven or reconnect power.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Sep 07, 2010 | Whirlpool GH6177XP Microwave Oven
Removed gear box and motor,cleaned and installed new oil and gasket,now need exploded view of assembly. Model 110. 20842 990. Can you provide?
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.+20842990
Then see the following Whirlpool PDF files.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The following is the parts list for their Commercial Washers although the Consumer models use the same transmission.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Jan 28, 2010 | Washing Machines
Electronics stuck. Unplugged and it seems to have
It will only work for a few more months. You'll have to reset it a few more times. Eventually, even keeping it unplugged for a couple of days won't work. Have had ours 7 years -- and have had more than a dozen service calls on it. In the beginning, all was covered. No longer. Piece of **** is going out to the sidewalk on junk day. Will never buy another whirlpool or maytag product again.
Our crappy whirlpool fridge freezes stuff in the back of the refrigerator, while stuff comes out of the freezer a bit soft.
Awful products. Even worse customer service.
Oct 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Washing Machine is going to explode(shakes and shimmies)
put your level on the machine Adjust the legs so when you push down on any corner there is no rocking - easy
Nov 07, 2007 | Whirlpool LSQ9600L Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
