Question about Exercise & Fitness
Incline does'nt work anymore!
Looking for an owners manual for an Image 15.5s treadmill that we bought from somebody and it didn't come with one.
    President:
  • 832 Answers
Go to www.iconservice.com input manufacturer then Brand name their is manual for you.
Posted on May 06, 2010
Incline stuck
Run the software calibration for fix it.go under the HOOD motor and follow the steps or use the owner manual
God bless you
Jul 26, 2013 | ProForm 775 CT Treadmill
I have the Nordic 9i incline treadmill. I can't
see the owner manual.download free.www.fitness.manualsonline.comsee the video attached.God bless you
Mar 15, 2013 | Exercise & Fitness
Is there an online repair manual for the Golds Gym Advantage Treadmill? I'm trying to solve an incline problem. The incline does not go up when I push the incline button. I just get a series of beeps...
Your owners manual describes how to perform an incline calibration. Here are the instructions.
Start the machine running. Press and hold the incline up button. While the numbers are changing, remove the safety key. Reinstall the safety key. The treadmill should rise to maximum incline, then lower to minimum. After completing the cycle, the treadmill should function correctly.
If not, you may have a damaged wiring harness (caused during assembly) or a defective incline sensor.
If the sensor is defective, you will need to replace the incline motor.
Mar 01, 2011 | Exercise & Fitness
My incline doesn't work
Does it make any noise? You can always isolate the incline motor from the rest of the treadmill and use a 110v jumper cord from white to black or white to red and check to see if the incline motor works with the jumper cord. If so than you know the problem is in the electrical of the treadmill.
Aug 21, 2010 | RTO Image 15.0R Treadmill Walking Belt
My 17.0 R image incline stuck in the highest mode, how do I bring it down.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 14, 2010 | Icon Image 17.5 S Treadmill
I have a Image 15.5 Treadmill, it turn on, Incline...
First we need to do a calibration follow this procedure
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad call icon Fitness @ 800-999-3756, they may have the sensor or they tell you, you need to replace the incline motor
May 21, 2010 | Icon Image 17.5 S Treadmill
Image 17.0 Treadmill is stuck in incline position and will not go down. I do not plan to use the include at all, is there a manual way to move the incline to 0? Any suggestions?
Hello there, The first thing I would try is to calibrate the incline on the unit.
Do this using the following procedure.
With the safety key out, press the stop button along with the speed up button while inserting the safety key onto the unit.
remove your fingers from all buttons, Then press the stop button one time. Now press the incline up button one time.
The unit should go all the way to the top, then return to the bottom.
Remove the safety key and reinsert it to continue using the machine
If this does not work you can manually move the machine to the bottom using this procedure.
Remove the hood cover b removing 2 screws in the rear of the machine and removing the first 2 screws on the foot rails on each side.
You can now lift the cover out of the way.
At this point you will see the incline motor located in the center of the unit pointing in a downward direction.
On the top of the motor there will be a small fan encased inside of a metal cover. There will be a flat head screw located inside the metal frame where the fan is. Rotate this clockwise to lower the unit. (the motor is geared very high it may not seem as though it is moving but it is) be patient that procedure does take a little while.
Any questions please feel free to leave another message on this link.
Good Luck! Tim
Jan 10, 2010 | Icon Image 17.5 S Treadmill
Image 10.0 treadmill incline not working
You have a stripped drive gear on the lift motor, order a new incline motor, install it and then calibrate it and you should be fine.
Apr 26, 2009 | Icon Exercise & Fitness
Exercise & Fitness Logo
62 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
