Question about Bosch Axxis WFL 2060 Front Load Washer
I have an Axxis+ washer/dryer. The washer is giving me an F:34 error, any ideas?
  • 1,998 Answers
You can try this I had one of these the other day. On the bottom front of the washer you will find a round access cover, rotate it to the right to remove it, inside you will find a green cord to manually unluck the door, pull it down. Door should now be unlocked. Chances are the door won't unluck because the wash water is not draining from the washer due to a clogged drain pump. Right behind that round access cover is the water pump. Before you open the pump cleanout, soak up all the remaining water inside the wash basket of the machine, or use a wet dry vacuum to vacuum up the water. Have a shallow pan and lots of bath towels to catch the water when you open up the drain pump cleanout. Check the drain pump cleanout for lint, small socks, coins and whatever gets left in pockets of clothes.http://servicetechhelp.com/discus/messages/2801/65423.html?1241057606
Posted on May 04, 2010
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: I just got a Bosch
Welcome to FixYa.
i'll start with the most obvious, but still quite common oversight, have you remove the shipping bolts from the rear of the washer ?
i.e.
The next thing to pay close attention to is detergent usage. Regardless of what one may have been told, "He" detergent has to be used, and even then not too much.
Look for this symbol when buying/using detergents...
These are the most common things that can (and DO ) contribute to the machine acting in the manner you've described.
If neither of these things apply to your situation, please let me know and I'll be glad to assist you further.
Thank you for choosing FixYa and Good luck.
Regards,
Macmarkus :)
Posted on Oct 07, 2010
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTE8600 F:09 error
That's a classical error which is connected to the software of the device, you have the whole error list together with the troubleshooter in this manual here, you can find it below the article:
Bosch Axxis Washer Manual
Oct 22, 2013 | Bosch Axxis WTL 6508 Electric Dryer
Need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Dec 22, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Bosch AXXIS WTL 86300 condensation dryer leaking water
It's a classical error code, you can find all the error codes together with the troubleshooter within the manual under this article:
Nov 29, 2012 | Bosch Dryers
Bosch Axxis Fault code F18
Oct 02, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis Washer Detergent slot codes; what do they mean?
soap goes in far left
softner middle
liquid all fabric bleach or powder bleach in far right
May 31, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
184 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
