Question about Maytag Performa PAV2200
Motor cuts out after spin cycle engages
The spin cycle begins with the tub fill of water. Is this normal? At the beginning of the spin cycle, water begins to be pumped out but the spin cycle goes straight to high speed and water starts to spray out of the top of the tub as the pump isn't draining the water fast enough. It is at this point the motor is overloaded and cuts out due to too much weight in the tub (water). All pulleys are functioning normally, water pump was recently replaced, no clogs were found in the drain hoses and the house drain is not backing up. The belt is worn though. Could it be slipping on the water pump pulley? Also, I had to replace a C-clip/snap ring recently that was holding the agitator pulley onto the shaft as the old clip broke and the pulley fell off. Could this have anything to do with it?
  • aj-fisher Mar 27, 2008
    Your suggestion was bang on, Thanks. Found a parts diagram of the thrust bearing assembly and sure enough, I had mis-assembled the spring/washer/bearing order when replacing the C-clip. Works great now.
    Sergeant:
  • 351 Answers
Yes the pulley system needs replacing theres a kit available that has all the washers etc you may have refitted in the wrong order.hope this helps.
Posted on Mar 26, 2008
SOURCE:
Kenmore 80 series washer model 110 doesn't fully drain when cycle complete
With the lid open, try to turn tub by hand. If you can you may have a bad clutch. If you hear the washer agitating at the begining of the cycle without any water and filling at the end of the cycle, replace the ATC switch. Try spin cycle and open the lid, if you don't see the tub turning, but hear the motor, check motor coupler, or if it never spins after you close lid, check lid switch. These are the most common solutions to this complaint.
Sep 02, 2014 | Washing Machines
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
My all in one washer dryer by kenmore is direct drive. the spin rinse spin functions work on all three cycles ie. delicate, permanent press and regular. the fill and agitate functions at the beginning of...
can you get it to start by moving the timer one more click past the beginning of the cycle? Sometimes that is all that is wrong. Other than that, it's more than likely the timer has fused some of the points together and you will need a new timer in that case
Aug 24, 2009 | Kenmore Washing Machines
Washing machine will not fill with water just aggitates
Check the float bulb in the bottom of the tub and the switch below the tub. It may be stuck in the up position telling the computor that the water has filled. The timer is not supposed to advance to another process engagement until the water floats the bulb and changes the bottom switch position.
Jun 21, 2009 | GE WBSR3140DW Top Load Washer
Tub spins while in wash cycle
suspect what ge call a mode shifter pull front panel off by sliding putty knife along edge at each side and pressing clips front comes right off look on motor for a flashing green light (washer must be in operation) there are 2 wires in a single plug on motor these run back to transmission area with a volt/ohm meyer unplug and ck between the wires for continuity should be roughly 90 ohms if bad will not show any continuity
Oct 08, 2008 | GE WWSR3090TWW
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Water fill problem
did you clean the screens in back of water valve? normally a fault code appears if it's a fill issue also the tub will spin at beginning of fill to soak clothes first before beginning to agitate
Jul 17, 2008 | Whirlpool WTW6600SW Top Load
Washing Machines Logo
168 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
