Question about Samsung HLR5067WX 50" Rear Projection HDTV
Have to frequently replace lamps on Samsung 50% rear projection
I am having to replace the lamps on my television about every 3 or 4 months. Do you have any ideas why?
  • Samsung Master
  • 8,457 Answers
U hear many clicking atemp,before the tv even turn on or trying to turn on.Ur ballast it dying or dead.Replaced the Ballast to solved this.
Posted on May 05, 2010
Samsung HLN5065W will not start up. Goes through 3 cycles and then lights in center circle blink. A new lamp was installed 2 months ago and it worked fine. The first time it didn't start-up, I unpluged...
Ballast Board ,it connects to the Lamp which is what Powers Lamp on.
First check all fans Lamp fan,ballast fan,DMd Fan, if they are OK then replace the ballast Board.
Encompass Parts Distribution 1-800-638-3328 Go to their website they have Free Service Manual
that you can print out for this Model.
Jan 20, 2011 | Samsung HLN5065W 50" Rear Projection...
No picture
Check the lamp contacts, eventually remove lamp and fit back in, chack that you did not burnt new lamp when mounting it in, you need a multimeter to test lamp.
Aug 10, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
When i turned it on screen went black...3 lights started to blink on front of screen
The "LAMP"LED light indication flashes or stay lite?The projection lamp life is over.Replaced the projection lamp.Tv require a new projection lamp.
Oct 19, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung 50" r p tv switches off
Replace your Lamp BP96-01073A Fox has them $109.00 1-800-227-5369
Dec 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung 50" rear projection tv switches off after a few seconds
probably need to replace the Ballast and Power Supply Board. If lamp has not been replaced, I would replace that too. can call 1-800-samsung for nearest service center.
Sony grand wega-lose picture and sound then it returns after 1 minute. happening more frequently. now on for 3 minutes, off for 1.
Have you replaced your lamp since purchase, if it has been at least 2 or more years, replace the lamp first.
Oct 18, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Samsung DLP rear-projection TV has had a very dim picture for months. We have replaced the lamp once already.
How long ago was lamp replaced, also you can try cleaning dust off the lamp. Dust builds up on it and causes pre mature failure. Also moving the TV around can cause the bulb to fail after extended use. The bulb are only as good as any other regular bulb. They start taking longer to warm up then dont get as bright then fail totally. Some Tv's wont allow itself to turn on in some of those states.
Aug 18, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung hln507w no picture with sound
Sounds like lamp? Verify the air vents are clean and that the lamp is not over 8k hours
Jul 05, 2009 | Samsung HLN507 50" Rear Projection...
Sony Wega 50
Usually this is a classic lamp problem, but it could also relate to a defective lamp ballast (power supply).
Now if you are replacing lamps frequently, it's likely the lamp isn't getting enough airflow to keep it cool. If you don't get the airflow issue solved it will take out the thermal safety fuse near the lamp and your set won't come on and the power light will blink red 6 times repeating itself until you unplug it. Some lamp fans are so deeply nested it takes a trained tech to get them out. Dusty environments are bad for TV's with fans in them, especially projection types.
Nov 09, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung HLP5063W turns itself off
rither the lamp door cover switch, or the thermostat has become intermittent..neither one is very expensive but soldering skills are needed
Nov 25, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
160 people viewed this question
Henry  Thomas
Henry Thomas
