Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Hello Heater won't fire up
  • 640 Answers
There are a few things that you will need to check on these pool heaters if your unit is ignited, but your burners wont fire. First, and this probably seems obvious, make sure that the knob is set to the on position. Next, cycle the ignition sequence until the air is out of the gas line. If it will still not fire, replace the gas valve.
Posted on Aug 12, 2010
Karcher hds750 pressure washer. The heater won’t fire. heater won't fire.
ok ok the heater won't fire. ya burnt the element out that why it won't fire, get used to cold washes or get it fixed.
Jan 06, 2018 | Karcher Garden
Heater fires up but won't keep heating water
Sounds like the sensor is not working shutting down too early
Jan 06, 2018 | RTO Atwood Water Heater - 6 Gal LP
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
Electrical - won't start. Hooked up fan to heater, smoke came out from under the hood, car won't start. Lights work, any key related electrical functions won't work
Your fan or heater likely shorted out and burned up, causing your one of the main fuses to blow due to the spike in current. You will need to determine what burnt up and replace it before replacing the fuse, or you may create a fire hazard or cause further equipment damage. Also double check any changes to wiring to make sure that everything is hooked up properly.
Nov 01, 2011 | 1991 Chevrolet Cavalier
Gvc code heater won't fire
gas valve closed check gas pressure
May 28, 2011 | Raypak RP2100 DIGITAL POOL HEATER R265
1993 gmc 1500 350cid - engine turns over but will not start. Fuel is good
Hello and welcome to FixYa!
If it's not turning over then the problem will be on the firing. If there's no current to the plugs, the engine won't fire up. Few things to look at to resolve the issue... First, the ignition coil can be faulty. Second, The ignition switch can be faulty. Third will be the starter. If it's faulty, it won't kick the flywheel. One good reason why it won't turn over.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 28, 2011 | 1991 GMC C1500
My car wont star the dash lights and every thing comes on but wont start
If the car won't fire then it can be a faulty coil pack. If the coil pack is faulty there will be no current to the plugs, one good reason why it won't fire up the engine.
Apr 25, 2011 | 1995 Mercedes-Benz S-Class
Blower runs and have ignition and fuel but fire won,t stay on . all pro spc-85 construction heater.
Most likely the flame sensor. The sensor has only one wire to it and is L shaped. Unplug the heater and take some steal wool and gently clean the the sensor.
Jan 02, 2010 | Heating & Cooling
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
130 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
