Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE profile TFX27PF side by side freezer and fridge not cold. Temperature setting to maximum on each, still not cold
  • 74 Answers
SOURCE: GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Posted on Aug 28, 2008
SOURCE: GE Profile Refrigerator PFS22SISBSS Bottom Freezer Temperature Indicators
I finally called GE about the non-working LED's and the temperature fluctuation. It's a known problem as many consumers have posted online. I called 800-386-1215 several times. What I found is I'd get different menu options nearly each time I called. The way I got to a 'helpful' human follows: Call above number; you will/may here a voice that states only 'for recalled appliances press 9' (may also have options for repair or parts) PRESS 0; next menu PRESS 5; you'll hear 'for less than 1 yr old press 1' and 'for more than 1 yr press 2'. In my case I pressed 2, then got a menu with 'for refrigerators PRESS 2'. Spoke to a woman who never denied that GE has a motherboard problem. She offered to provide a free motherboard but no labor. I asked (to be sure) if I would have to pay labor, she said yes or I could have $400 off a new crappy GE fridge. She said I would have to have a repairman come to diagnose the problem, then order the part and then come back to repair. I then said, 'You're telling me that I have to pay for TWO service calls to repair a known GE defect???? How much should I expect to pay for these TWO service calls???' She then asked me to hold, then came back on the line and told me that GE would pay the labor for the repair.
I also asked if GE was willing to do anything about the 25 cent door latch that cracked after 11 months (and is attached to the door gasket a $228.00 part) or the rusting wire freezer baskets and was told no. Hey, worth a try! The fact that they said no ensures that I will continue on my crusade to warn anyone who'll listen not to buy GE! Keep calling, after I got the right menu the wait was short the whole call was less than 15 minutes.
Posted on Sep 17, 2008
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
SOURCE: GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Posted on Mar 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: Fridge and Freezer Not getting Cold
Your defrost system is at fault.
With this brand it is most likely the defrost thermostat and defrost heater located behind the back freezer panel.
Remove the shelves and bin,then remove the freezer panel. Defrost the ice manually.
Replace the thermostat and heater assembly.
Posted on Apr 27, 2010
Testimonial: "Excellent Diagnosis. Lower Defrost Heater Failed."
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a ge profile psc23nhpa refriderator that the fridge side of the unit temperature shoot up to 135 over night. But the freezer side was still very cool. What could cause this?
Are you sure it is 135? If the freezer is cold but the fridge is warm, most likely is the damper door problem. (Basically, it's a door controlled by the main board, get cold air from freezer and close when the fridge is cold enough)
Oct 17, 2010 | GE Refrigerators
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Warm temp
u have a defrost problem if u shut it down 4 or 5 hrs with doors open then turn back on itll work tii u have it fixed
Mar 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX27PF refrigerator and freezer still not getting cold enough
the partial frost pattern is an indication of low refrigerant, restriction or bad compressor. if the unit is under 5 years old this repair will probably be under warranty thru GE. if out of warranty then you are looking in most cases between 200-500 dollars for repair. good luck Thanx peyton
Jan 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Sep 14, 2007 | GE PSS25NGM Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
143 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
