Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Red streak going down the lcd screen - ViewSonic N2750w 27 in. HD-Ready LCD Television
Streak in LCD Screen
Strip down and remake the connection to the ribbon cable. It has to be inserted squarely and evenly and then locked down. Make sure any spacers or locators are in properly between the two screens. Any pressure will cause display anomalies.
Mar 01, 2017 | Dell Inspiron 1525 Notebook
I have three black circles, and some color streaking at he bottom inch of my RCA, LCD tv
that is usually caused by cleaning the screen with windex the windex runs down the screen bewteen the screen and plastic frame and actually seeps inside between the screen layers. Eventually it may go away by itself if the circles are not too bad but in most cases the damage is permanent.It can also be an issue called screen delamination which there is no fix for.
Mar 02, 2012 | RCA Televison & Video
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    My daughter's LCD TV has color vertical streaks
    I believe she had damage the screen TFT (Thin Film Transistors that drive each LCD Red, Blue, Green pixels, there are about a million of them on the screen). The sreen is very delicate. You can ask local repair shop for second opinion.
    http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
    http://s807.photobucket.com/home/budm/allalbums
    Jul 01, 2010 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
    Hi. I have a bright streak going down the front
    Ok, this is a classic LCD fault, unfortunately, your Screen "Element" has gone faulty. There is NO repair, replacement of said "Element" IE: The LCD Screen. This is an expensive repair. In my professional opinion, you need to take it to a Samsung, authorised, service venter, then ask for a "Quote" for repair, that way you can be appraised of costings and you can determine as to repair or replace.
    Apr 28, 2010 | Samsung LN-S4051D 40 in. LCD Television
    After approx 1-2mins the screen fades to black and white streaks and spots
    LCD is going bad and eventually it won't show any image. LCD is not able to regulate the voltage going into it so to much is going into the LCD and thats why the spots and streaks are showing up.
    Nov 28, 2009 | Toshiba Satellite 5105-S501 Notebook
    Rainbow colord streacks coming from the top of the screan going down
    i have a soyo lcd 32 in with a pinkish red line running from the top to the bottom of the screen what can i do
    Oct 11, 2009 | LG 42LG50 42 in. LCD HDTV
    I have a 37 with a black streak developing on screen.
    It can be problem of LCD panel of your TV. An image of TV screen would help to diagnose correctly, if you can post it here.
    Thanks.
    Sep 14, 2009 | Protron PLTV-37 37 in. LCD Television
    Powering up and warmup problems
    why does my lcd monitor change different colors no picture just turns to all sort of colors ViewSonic N2751W 27 in. LCD Television thanks 4 your help
    Dec 05, 2007 | ViewSonic N2751W 27 in. LCD Television
    ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
    137 people viewed this question
    Top ViewSonic Televison & Video Experts
    Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
