Question about Intertherm P3RA-048K Air Conditioner
Hi contractor replace air handler motor now 4 months later pop
I have a old unit, AHS won't replace it, had a new compressor,acumaltor,defrost board,outside unit fan motor and just 4 months ago attic air handler motor.. When my unit comes on it makes a pop sound like a door is opening somewhere, then a slight small pop sound a few seconds later.. It does the same thing when cutting off.. What is the proble... thanks George
P.S. before the new fan wheel was replaced I had a mildew smell coming out of the vent, the wheel was weighted down with crusty funky dust build up, now it doesn't smell that bad, just wondering if when my main line was clogged 2 years ago for 2 weeks the wetness penetrated areas up in my handler or flex duct and that's what I smell on occasion. thanks
  • 674 Answers
The popping sound could be the sound of the metal in the air handler flexing when the blower motor comes on and reduces the air pressure in the air handler. If your drain line was clogged then it is very likely that it over flowed into the flex duct.
Posted on May 03, 2010
    Guru:
  • 415 Answers
The mildew smell could have been created by the clog, but it also could have been created by low airflow and/or refrigerants leaks that can cause your evaporator coil to ice up and melt inside your air handler.
The "Popping" sound sounds like it is either your ductwork or the casing or access panel of your air handler.
If you still have the original ductwork, it should be thoroughly inspected for air leaks and/or degradation insulation (insulated will degradate in time). Re-seal and Re-insulate if necessary.
Without being onsite, with toolbox in hand, I hope you find this information to be very helpful to you, moving forward. :-)
  • laura Newman May 03, 2010
    Hello Graham,
    I hope you can reconsider the two-thumbs rating.........or please offer feedback why only two thumbs. Two thumbs indicates I failed to provide you with what you needed. Please explain what you more you need and I will gladly offer more assistance or help. :-)
Ruud UAKA-030JAZ fan spins, not blowing cold air
there are 3 things to be considered,first,if the compressor motor `s connectors are having loose,it gives a hi ampere to your RELAY that can cause to its contacts being fried,second,the compressor motor itself is gaining a hi ampere already i.e. having unusual sound that can cause heavy friction inside the turning mechanism and third the last but not the least,maybe this time,the tubes or the compressor itself having very small holes that causes to the refrigerant to escape and it doesn`t gives off cold air.
Apr 17, 2014 | Ruud Heating & Cooling
The condenser unit will not kick on...it is a concord unit,10=12 years old,13 seer,3 ton. The air handler works fine. I thought it was the capacitor. The old one was bad,I verified that with multimeter....
It could be a low refrigerant cut-out (switch), grounded or shorted motor windings, open internal winding overload protector (check at the common winding), a broken conductor, or no power at condensing unit from blown fuses or open/tripped breaker.
Aug 22, 2013 | Intertherm Heating & Cooling
Unit exactly one year old. Was interruped by lightning strike last night. Afterwards air handler blowing, but not cooling? Turned unit of at temostat, waited a few minutes, turned back on and unit (both...
Marion, if there was a lightning strike and then a power surge when the power came back ON, I don't doubt what the servicemen had to say. The age of the unit plays no role in it, when something like this happens. Power surges can be killers to electrical appliances. That's why it always wise to turn the unit off during a power outage. Just ask anyone who was in Irene's path a couple of weeks ago. Power went out for days & weeks for some, when it came back ON, electrical appliances were damaged or ruined or started house fires.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | Amana Heating & Cooling
4 year old goodman 3 ton residential air conditioner is not working properly. Air handler is running, evap fan is running but compressor is not coming on. Had similar problem a month or so ago and it...
If the fan is running and the compressor is not running then you should be getting power to the compressor...
Often the dual capacitor will go bad and then the compressor will not start.
I usually change the cap to make sure that is not the problem.
If the compressor still does not start then check the start amps and you will find that you are probably getting locked rotor amps. or no amps... (open windings)
Either way you will have to replace the compressor...
heatman101
Jul 07, 2011 | Heating & Cooling
Were is the reset button on the unit?
Hi, here is the theory on the reset button on Air Conditioners. They reset via the breaker panel box in your house. Check that first before anything else. However if your unit is popping breakers, it is because the rating for the breaker is incorrect, or there is something that needs servicing usually in the outside unit called the condenser. That piece contains the compressor. A faulty compressor and pop the breaker. Or If the condenser fan that blows over the coils of the outside unit stops (common failure) The compressor will overheat and shut down. That may not trip the breaker but the house will get hot anyway. Usual action for this is to replace the condenser fan motor and starting capacitor. Make sure the speed rating and directional rotation for the replacement motor is the same as the motor removed.
There are other reasons why the system won't come one fully. If the wall thermostat is digital and does nothing. including turning on the fan. There will be a small fuse located on the circuit board of the air handler (part of Air Conditioner mounted inside the house. It houses the circulation fan). That fuse could be blown. That one shuts down just about everything.
On air handlers mounted up into the attic crawl space there is an overflow pan. This pan is mounted directly below the air handler. This pan can fill with water when the drain pain contained inside the air handler starts to overflow because the drain system to that is clogged.
There is a "float switch" mounted in the overflow pan wired to the system in such as way as to shut down the entire AC system if that pan fills.
The handling is to clear the obstruction in the Drip Pan inside the air handler. Then remove enough water from the overflow pan and the AC will run as though nothing has happened.
If you have more questions, write to me on this site.
One thing more. The capacitor alone in the Outside condenser unit can fail and that will stop the condenser completely if it is of a "split" design and used for both the compressor and fan. When replacing this unit alone, ALWAYS find the same specification part.
I hope this helps,
Have a Happy New Year,
Mark
Jan 02, 2011 | Goodman CLJ30AR32 Air Conditioner
Are these still under warranty
Hi, the only part on your unit that they will put a warranty on when it is new is the compressor for 1 year only. You can buy an extended warranty on the compressor for 4 years. If you loose a part now, and have to call out a tech to replace it, they will give you a 6 month warranty on parts alone. Doesn't seem right, but that's the way its done. Some contractors try and not give you any!! That's wrong and will come back on them. I hope I have been of help to you on this when you rate me. I know you will be kind.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jun 22, 2010 | Goodman GMS90703BXA Heater
Is it ok to replace outside unit of central air and heat and not the inside air handler ? The upstairs A/C( over 10 yrs old) is not keeping up with South Texas heat. The temp upstairs climbs to 84-86...
I'm assuming you have had a competent Air Conditioning contractor look your unit over.if you trust your A/C contractor, why don't you work with them towards an answer? I would get an air flow and sizing analysis, a full equipment service/performance check, and see if there is something simple causing this dilemma. Possibly low refrigerant charge,or you have a filter or coil restriction on the indoor unit. I've seen mold plug a coil solidly before. And due to new federal regulations on air conditioning efficiency and the phase-out of R-22, I would recommend that any replacement equipment be done in full, not part and parcel. The newer two stage energy star rated cooling and/or heat pump offerings are a fantastic solution for premium indoor comfort, and the government is offering powerful incentives right now if you're in the market.
Aug 18, 2009 | Heating & Cooling
Five year old goodman unit compressor gone bad. Should I just replace the compressor or should I get new air handler and condensing unit. Really don't want to spend the money, can really use it somewhere...
Depends on if your going to stay with the old refrigerent system of R 22 ro upgrade to the new R410A system. I have been upgreading my customers to 410A if the compressor has failed. Replacement of all components recomended on a compressor burn out.
Greg. B
Sunsetmechanical
Jun 30, 2009 | Goodman CKL42AR42 Air Conditioner
Fan blower overheating
Sounds like your motor is bad check when it was installed all the units have a 5 yr warranty on parts but a HVAC contractor has to change it for the warranty
Dec 09, 2008 | Ruud Handler Air Conditioner
Carrier air handler tonnage?
That is a fairly large difference. It is usually ok to have the inside evap. coil and blower up to 1 ton larger than the outside condenser. That will make the unit slightly more efficient as well as less likely to freeze up on low airflow situations. It is not recommended to install a new condenser on an old evap coil. There has been a lot of changes to the design of the coils in the last little while. For example a 10 year old 2 ton coil may only have 3 cubic feet of volume but a new 2 ton coil may have 4 cubit feet of volume.
There are many factors that may have infulenced the decision on what size condenser to install. Many of which can only be done by visiting the home and doing alot of work, checking the duct sizing bioth supply and return, inspecting the insulation and windows of the home etc. etc. Most of the time that never gets done. You can blame the contractor for not doing a complete check, but at the same time you can blame the customer because many contractors that are that good loose the job to a cheaper bid that did not no any of the research. It is a catch 22 for everyone involved.
There is ALOT more to sizing equipment that many people think, sadly that also includes many HVAC contractors. Way too many people use "rule of thumbs" or flat out "guess".
Sorry for the rant but your queston can only be answered by a good well educated HVAC contractor visiting your home. That type of a contractor is getting hard to find these days in such a price competetive world.
Oct 14, 2008 | Carrier Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
215 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
