Question about Kenwood KAC-7204 Car Audio Amplifier
My blue light on my Kenwood KAC-7204 amp comes on but the red light flashes off when i turn my car on. What could be the problem?
jhall1793
  • 60 Answers
SOURCE: how to hook up kenwood kac-7204 1000watt amp
I found the manual & have pasted the url here for you. some things to keep in mind. according to the instruction manual this unit is rated @ 500W, not 1000W. Also to maximize the output you should use 2ohm speakers for stereo applications. Also make sure if you need to extend the power wire, use 10 gauge copper & make sure it's connected to the car battery thru a 60 amp fuse. Also make sure the ground is attached to a clean metal frame or body part by using a bolt & nut not merely a screw. Good luck. If you need additional assistance let me know.
http://inform3.kenwoodusa.com/manuals%5Ckac7204.pdf
peace-out
Posted on Jan 06, 2009
etirbynnor
  • 655 Answers
SOURCE: kenwood 7204 car amplifier flashes the blue light
Hello rogman9570,
I'd begin by checking all of the wiring. The most probable causes of this type of failure indication are:
• Speaker wire may be short-circuited.
• Speaker output contacts ground.
• Head unit (cassette receiver, CD receiver, etc.) or the amp ground fails.
If all of your wiring checks out OK, then the amp itself probably has an internal fault.
Hope this helps.
Posted on May 18, 2009
  • 87 Answers
SOURCE: kenwood kac-7204 1000w amp with 12 in sub what
bigger the better my friend. Look at your Peak RMS output, and how long of wire you need. Then you could make the judgment call on how thick or what gauge you need. (2 involved factors power + distance). id say 10 gauge and you would be fine.
Posted on Jun 03, 2009
drsinister69
  • 2317 Answers
SOURCE: XM-2165GTX Car Audio Amplifier: i have a kenwood 1000watt amp model # kac-7204 i h...
I would try to remove the top cover of the amp and you might be able to push them out from the inside. Just a shot in the dark.
Posted on May 19, 2010
  • 14 Answers
SOURCE: I have a Kenwood Kac-7204
well if u dont have a meter and some soldering skills
is best u take it to a repair shop
if u want to learn check this site out
http://www.bcae1.com/
Posted on Sep 18, 2010
My amp lights up once blue then flashes red why
Your amplifier is going into protection mode. Did you purchase this amp brand new? Or did you buy it used?
Oct 31, 2013 | Kenwood KAC-7204 Car Audio Amplifier
Red and blue light stays on but it cuts on and off, what's the problem? It comes on and works but the red light stays on along with the blue light..when the speaker cuts out, it acts like its trying to...
hi there
The reason for this is the ground is weak to the amp make sure that the post that your ground wire is screwed down to is tight also make sure that is touching bare metal if there is paint on bottom side use wire brush to get the paint off so it is bare metal a weak ground can mess the amp up and make it not work at all hope this helps you have a wonderful day
Aug 23, 2011 | Kenwood KAC-7204 Car Audio Amplifier
When i turn the music up sub cut off blue light stay on red triangle cuts off
Hi, the amp is going into protect mode. You can either keep it turned down or possibly reconfigure the speaker connections for a higher impedance. If you tell be the model of your sub, I may be able to suggest a better arrangement.
There is a manual here if you don't have one: http://manual.kenwood.com/en_contents/attachDownload/6017/
May 08, 2011 | Kenwood KAC-7204 Car Audio Amplifier
May 16, 2010 | Sony XM-2165GTX Car Audio Amplifier
I bought a kenwood kac 7204 amp yesterday and i hooked it up to one 12 and one 10 and it sounds good but it gets really hot and it even shuts off do you know what might be my problem??
What is the impedance you are driving. If the load is too low then it will cause the amp to go into thermal shutdown. Look up the recommended impedance for this amp.
Dec 29, 2009 | Kenwood KAC-7204 Car Audio Amplifier
Kenwood 7204 car amplifier flashes the blue light on top then blows the fuse''
Hello rogman9570,
Hope this helps.
May 18, 2009 | Kenwood KAC-7204 Car Audio Amplifier
Kenwood KAC-7204 Car Audio Amplifier Logo
260 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
