Question about GE JVM2070 Microwave Oven
GE JVM2070 issue
Hi, i got home a little bit ago to find that my microwave wasn't working. checked the breakers on house and were fine. electrical outlet also works fine. my girlfriend had used the microwave to cook something while i was gone, then apparently after she was done cooking the food, is when it shut off. it seems to be extra warm-hot around the top of the microwave(near the automatic opening vent. wonder if it overheated? is there a fuse i can replace? thanks for your help.
  • 1 more comment
  • warrobi May 10, 2008
    I have the same problem. I took my unit down of the wall and opened it up. Checked both the High Voltage fuse and the regular 120V fuse and both are good. I also checked the output from the 120V input board (where the fuses are located) and still had 120V AC coming out. Suggestions? I would definately not want to have to spend $400 to repair a $500 microwave.
  • vasi1 Jan 31, 2009
    I have a GE Profile Microwave Spacemaker 2.0 model -JVM2070SK02.
    This morning i burned some food in it. When i realized that,i allready had small flames and smoke coming out of the food tray. I stopped and clean everything.
    The microwave is totally dead now, like no electricity goes in it..i don't know if i should try to repair it or to buy a new one...i don't know what part may have failed and if is worth repairing it..
    If anybody has any sugestion i will be very greatful...
    thank you
  • adams678 Feb 23, 2009
    I have the GE JVM2070 and my neighbor who is a Sears appliance repairman says it's the magneto overheating. When it gets hot (about 5 minutes or more of ON time), it loses all power as if the circuit breaker kicked. After it cools down, it works fine until the next time it overheats.
The same thing just happened to us..... there is no fuse on the microwave but we check our fuse box and tried another plug and it still did not work. GE sent us a new smartboard and now I trying to figure out how to get the thing apart.
Posted on Apr 05, 2008
  • 185 Answers
What is the make and model number
Posted on Mar 26, 2008
GE Microwave JVM2070 runs but does not heat food? What is the likely problem?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';';
Jun 14, 2011 | GE JVM2070 Microwave Oven
Heats slow, and then somtimes alarm eee shuts oven off
I'd check the electrical requirements and maybe test it out on a 20A circuit with nothing else connected. it may be an electrical issue at the house where not enough power is getting through.
I've also seen issues where the wires are loose in the breaker box that cause issues.
if you can take the microwave to a friend's house for testing that'll tell you if it's the microwave or your electric that's the issue. If it works fine there then you have to track down your power issue. If it has the same issues there, take it back or replace it.
Mar 10, 2011 | Microwave Ovens
Oven keeps turning off frequently. Will reset by turning off Breakers and resetting.GE Microwave JVM2070.
My answer is get rid of it. Microwave ovens are hazardous to your health! Any food microwaved is not food anymore except for cancer cells and giving you diabetes. This is one of the main reasons these problems are on the rise in the US. US has never tested MW ovens except for 'leakage'. Not worth fixing or having one. Save yourself! Do some research. Microwaves riddle the cells rupturing them rendering them unfit.
Jan 03, 2011 | GE JVM2070 Microwave Oven
Shorted Touch Screen on GE Spacemaker JVM2070? How do I fix it?
These ovens are nightmares when they fail out of warranty...
The touch screen assembly is not meant to be be taken apart for repairs, only replaced. And the assembly runs about $455 (just part cost!), depending on your full model number suffix.
Add to that the $79 to visit the home, plus $75-90 to actually do the work, plus whatever parts markup, and you'd be better off replacing the microwave.
If you insist on the same model, you might try eBay. They appear there often.
Good luck.
Apr 27, 2010 | GE JVM2070 Microwave Oven
Fuse blown
most have a resistor in parallel with the hi voltage capacitor,but always use an insulated screw driver to double check and discharge the cap to be on the safe side,but normally with in 30 minutes
Apr 24, 2010 | GE JVM2070 Microwave Oven
Ge over the renge microwave runs but no heat
heatman101
hjdhjd
Feb 13, 2010 | GE JVM2070 Microwave Oven
Touch pad does not work, clocke does, nothing else works
Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
simply replacing the touch pad will fix this issue.
May 30, 2009 | GE JVM2070 Microwave Oven
Jvm2070
I ended up replacing it with a whirlpool one. It is not a good microwave and I have decided that until GE gets their act together and stop cheating people with planned obsolesce, I will not buy their products.
Sep 24, 2008 | GE JVM2070 Microwave Oven
2 year old ge profile spacemaker Microwave lost all power
Inside unit is a cylinder fuse which can blow for a number of reasons. External cover needs to be removed to access. If you are confident in doing this and can find & check the fuse then it would be my first guess. If fuse is OK then you will need to have repaired. If fuse isblown & you replace then it blows again,you will need to have repaired. regards
Jul 25, 2007 | GE JVM2070 Microwave Oven
GE JVM2070 Microwave Oven Logo
491 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
