Question about Maytag PAV2300 Top Load Washer
Timer sticks and therefore the washing cycle stops. To restart i either move the dial another notch or two OR bang on the machine top lightly.
  • 1,998 Answers
Replace the timer you can have it sent to you by mail from either allbrands appliance of marcone
Posted on May 04, 2010
My washing machine washes and then stops at the rinse cycle...but you can hear tick, tick, tick...and then the dial moves but the clothes don't get washed! Same for the spin cycle. If I push in the dial...
if it keeps sticking in the same place and then if you advance the timer past that point and it runs again the points are burnt out in the timer and it needs to be peplaced.a new timer is around 90 dollars and the part number is 8546165.when you call your parts store give them the full model number off of the machine to make sure it's the correct part number,you're missing a number and letter at the end,the number i looked up was LSQ9549Lg3
Apr 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Hoover 700LB - fills as per normal and washes but cycle knob does not move, click or progress towards the next cycle therefore washes forever...timer perhaps and if so is it worth fixing?
Hi just read your posting.Does the timer move at all from the original position that you started it from?If it does not move at all then you need a new or reconditioned timer.If it does move but stops at a specific spot,What position does it stop at?Are you in Australia? If so I can give you the contacts on where to purchase a timer.Please reply and I can guide you on how to get the correct timer number for your machine.Looking forward to your reply.
Jul 24, 2010 | Hoover HTC243 Top Load Washer
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
Maytag top load washing machine model LAT9306AGE.. the timer doesn't spring back out when needed to during cycles
the timer on all maytag's ( top load turn clock wise/ push in to stop/ pull to start . the spring back ??? the timer shaft may be sticking and is hard to turn . remove face cap and clip pull dial and lube with a light oil or spray lube / reinstall and this moy help .. mm
Dec 02, 2009 | Washing Machines
STICKS on cycle, wash, etc. If manually moved
Do you mean the timer or control dial sticks. If so then it may be the timer mechanism itself.
Make sure that when you are skipping a turn on the timer that the machine is actually performing that particular task of the cycle. For example if the timer gets stuck before the drain cycle, and you manually skip forward to it, that it actually drains the water out.
If so then it is most likely a worn timer mechanism which sticks.
Ash
Oct 23, 2009 | Frigidaire Dishwashers
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
Whirlpool washer shuts off during cycle
Replace the timer - it is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Maytag PAV2300 Top Load Washer Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
