Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Will not stay running act like it runnig out gas? and in back the motor real wet too. it a 450cxl poulan
    President:
  • 1,033 Answers
The wetness, does it smell like the gas mixture. If so, one of the gas lines most likely has a crack keeping the gas from flowing to the carb which makes it quit running. When you prime the blower, this is when it will run for only a few seconds? This is because the primer bulb is taking gas and shooting it straight to the carb.
Posted on May 03, 2010
Acts like it's not picking up gas. will run as you spray into carb.
Dirty carb. If it has a fuel bowl take it off and clean it out and clean the fuel jet that has little holes in it. I use an air compressor or a real fine wire.Try this before tearing it apart.
Mar 15, 2015 | Poulan Pro PR625T22RP 22inch 190cc Briggs ...
After the chainsaw starts up it will idle the min. you disengauge the high idle on the choke it runs for about 3 seconds and then dies like it ran out of gas
When it dies pull out the spark plug. If it is dry it is getting not enough fuel,wet is too much .Adjust the L needle till it stays running.
Jan 26, 2014 | Poulan Garden
Motor skipps during acceleration on 1998 s10 pick up 4.3 v6
a bad plug wire will break down when accelerating but act ok when idling change plugs and wires
Dec 27, 2012 | 1998 Chevrolet S-10 Pickup
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Poulan weed eater stalls if you give it throttle
check the spark plug to see if its wet when it dies also air filter if thats all good i would bet its your gas with todays ethanol it reaks havok on smaller engins find a station with real gas or auto store for additives
Dec 24, 2011 | Poulan Garden
Poulan 21cc weedeater - starts but won't stay running. I've cleaned all fuel lines, cleaned plug and has plenty of gas - but still won't start. runs for 2 or 3 seconds and dies. appears to not be getting...
On these types of motors that could be the problem, another thing to check is the primer bulb. I have had a primer bulb that had a small crack in it which went undetected for a while. These types of motors do not have a fuel pump and they work on a siphon type mechanism, if there is an air leak dealing with the gas tank anywhere, that is your problem.
Aug 11, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Was working fine, then started to work at half force then just quit. Good fuel supply.
Try checking the fuel filter and try the air cleaner, if this is a mixed gas rig you may have the gas mix wrong. Pull out the spark plug and look to see if it's wet. if it's wet you have to much oil, if it's a 4 stroke you have a air problem, after cleaning out the air cleaner and drying the plug ans lightly sand the tip of the spark plug and wash off, try starting it, if it starts and runs your good to go, be sure the governor control arm has not fallen off the governor control arm. If you need more help just post a reply back.
Nov 22, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Nov 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My poulin chain saw wont run
Can you get it to run at all? if not pull it a few times and check if the plug is wet. Let me know
Feb 23, 2009 | Poulan Garden
I have poulan 2075oc that floods out as soon as u pull started rope.you pull it one time and spark plugs is real wet with gas.Saw set for long time with gas in tank and i had to replace all the fuel lines...
you need to open the carb up and take the old fuel line out of the carb filter.....if it is left.the needle is probaly stuck in the open possition letting to much fuel to go to cylinder
Jan 23, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
740 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
