Question about SanDisk Sansa Clip MP3 Player
Dropped sandisk won't turn on
My daughter was taking her headphones off and dropped her Sandisk Sansa. It shut off and will not come back on. When I plug it into the computer, I can get to all of her files. It comes on and says connected, writing. The battery is always at 80% and it never says charging. do you know how to get it to turn back on?
Thanks
JP63
  • 8,596 Answers
Sounds like a hardware damage issue, but:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 07, 2008
SOURCE:
My sandisk when you put in headphones only one
Verify that you've pushed the headphone jack all the way in. Sansas tend to have very tight headphone ports.
If not, try other headphones. If the others do the same thing, it's likely that your Sansa is damaged.
Jan 29, 2010 | SanDisk Sansa e250 MP3 Player
Sansa repair
Contact sandisk to check to see if your device is under warranty...the number for sandisk is 1-866-726-3475
I hope that helps
Please rate accordingly
Thank you
Computerrep
Mar 23, 2008 | SanDisk Sansa e250 MP3 Player
Mp3
Have you tried holding the power button down for about 30-60 seconds? It should power off itself off. You should be able to then power it back on and it work normally.
You might try a firmware update on your daughter's. Look at solution 4 here: http://www.fixya.com/support/t131894-format_sansa_e250
I works for any Sansa e series.
Feb 26, 2008 | SanDisk Sansa e260 MP3 Player
Headphone jack shot
did you try different headphones?
Jan 04, 2008 | SanDisk Sansa e250 MP3 Player
Self Panning Headphones
I recently purchased a Sansa e280 and in three weeks of regular use it developed a similar problem, with music cutting out from playing in stereo to mono, coming out of one headphone speaker. Sandisk tech support told me to reformat the device and install the latest firmware, which I did, but the problem continued and occured more frequently. I have returned the player back to the seller and I shall not be getting another one. A nice Ipod alternative from Sandisk, but from what I have seen written about in forums, the Sansa e200 series appears to be buggey with problems.
Apr 24, 2007 | SanDisk Sansa e260 MP3 Player
My headphone jack may be messed up
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
Mar 28, 2007 | SanDisk Sansa c140 MP3 Player
Help with sansa e250
Call Sandisk and tell them about your problem. I had the same exact problem. The headphone jack inside is loose. Talk to Sandisk and don't worry about the box, the customer is always right. But after they send you a new sansa e250, sell it on ebay and buy a durable mp3 player like the iriver t10 series. My old iriver dropped on the floor plenty of times and it's still working after 3 years.
Aug 25, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
109 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
