Have a bryston power amp model 3B for repair on the side with the output transistor there is 2 transistor (TO-220) F718 and F649 these are short but I can't find what transistor it is anyone know a sub for it thank you
  • audioshop May 03, 2010
    yes, do you have the schematic?
    thank you
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Would a schematic diagram help?
Good luck and thank you for asking FixYa.
Posted on May 03, 2010
  • Louie  Role
    Louie Role May 03, 2010
    Please reference below schematic diagram.
  • Louie  Role
    It appears that the image was greatly reduced. I uploaded the amp schematic here.
Write your answer...Help nman jn may ginagawa kc akong tv tcl 2027u standby power what problem this tv, txn
Posted on Oct 06, 2016
My Bryston 4B amp was working fine and now only one light turns on and then it shuts itself off, i have unplugged all the cables that go to and from it and it still does the same thing, it's like
Your Bryston has a 20 year factory warranty. start by contacting Bryston, have your serial number handy, and go from there. I have repaired /rebuilt many Brystons, these are most definitely NOT do it yourself amps. A repair tech with some serious skills is needed. Best I can tell you without seeing the amp...Good Luck !!!...Rob
May 26, 2012 | Bryston 4B SST 2-Channel Amplifier
The left side cooling fins overheat in a minute or two
Is there sound coming from the amplifer?
It could be that the biasing has gone or the output transistors are going into thermal runaway.
Which Bryston amplifier do you have?
Let me know.
Regards - Anthony
Feb 07, 2010 | Bryston Audio Players & Recorders
Protection light stays on even when everything is disconnected.the output transistors are turning red hot instantly and it has a 20 amp draw on it.while it is hooked up to a power supply with no sound...
there is a short somewhere one your board that is putting all the load on your output transistors follow the traces on the board both ways to find the short
Jul 05, 2009 | Power Acoustik GOTHIC OV2-1800 Car Amp
Bryston 4b amp, left channel blows the back panel
I would check out whatever drives the left channel first. If it is a transistor, you can put a ohm meter on the terminals and see if it shows a short (amp turned off). If there are two transistors for the left channel, and you find a short on one only, replace the other to be on the safe side.
Mar 16, 2009 | Bryston 4B SST 2-Channel Amplifier
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
Jan 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
401s Rockford Fosgate Amp. Not turning on. No power light. Pos+ and GR- are solid. Thought it may be remote, so tried running a wire from the POS+ to REM to test it, no luck
Amp Failure:
These repairs are best left to a repair tech familiar with car audio amplifiers. Check with your local shop to get a reccomendation. If the light isnt even coming on, chances are your input or power supply has been taken out.
Jan 01, 2009 | Rockford Fosgate Punch 401S Car Audio...
No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
Dec 31, 2008 | Blaupunkt PCA460 Car Audio Amplifier
I have an audiobahn A8000t amp with the protection light on
Note:
Dec 30, 2008 | AudioBahn A8000T Car Audio Amplifier
Amp turns on just fine but no sound comes out
Amp Failure:
Seems as you have blown an output. Seek repairs.
Dec 29, 2008 | Power Acoustik A3000DB Car Audio Amplifier
When I turn on the car all 8 transisters (#IRF3205) on the 12V side of the amp blow up is their a short in side the amp?
If the power supply transistors blew out, it's possible that the output transistors have failed (shorted).
If you're going to try to repair it, there are likely 2 blown driver transistors near the driver IC (TL494). You must check them. If they're blown, the new 3205s will blow out again.
May 11, 2008 | Kicker KX1200.1 Car Audio Amplifier
Televison & Video Logo
311 people viewed this question
Top Televison & Video Experts
Electro Med Services...
