Question about Comfort-Aire HD-651 Dehumidifier
My Comfort-Aire BHD-501-B is running. However, none of the control panel buttons work. I cannot turn it off with the on/off button. I cannot change the humidity set point using the up or down arrows. I cannot change the fan speed or the timer with their respective buttons. I have turned it off - unplugged it - for minute or two and plugged it back in, but the control panel still does not work.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 3 Answers
I don't think it's a thermistor problem, as previous respondents have suggested. I have one of these units. The control panel has been nothing but trouble. The Power button works, but the Fan Speed button is stuck on High. The Humidity Up/Down buttons only work sporadically. Sometimes they work if I keep punching them. There doesn't seem to be any rhyme or reason as to when they work and when they don't. I think they're just cheap parts that have failed prematurely.
Posted on Nov 02, 2015
  • Bill Nov 07, 2015
    Follow-up to my previous post:
    I replaced my PCB (circuit board) p/n 6871A20600B, about $15-25 online, and my display panel buttons work fine now. Remove the bucket. Remove 2 brown screws under the front grille, and gently lift the grille up and out. It's still attached to the unit with a wire bundle, but turn it over and remove the 6 small screws holding the PCB. Gently pull the wiring harness, rocking it from end to end. (Caution: Take your time with this step. Do not bend the connector pins.) Reconnect the harness to the new PCB and refasten the screws.
    I don't know why these boards fail. The small "clickers" on my nonworking board sound and feel like they're working, but they didn't work. A new board solved the nonworking button problem, and is a fairly easy solution at a tenth of the cost of a new unit. Hope this helps.
22yooper
  • 828 Answers
SOURCE: Comfort-aire dehumidifier 501 cycles on and off
It is possible that the humidity is below the set point of the dehumidifier. They will run for a short time until they get a true fix on the actual humidity then shut down.
Posted on Jun 29, 2008
  • 3 Answers
SOURCE: Fault Codes
This is more of a tip since I have not actually fixed anything yet. As a test, remove the upper front cover where the buttons and displays are. (2 screws on the bottom then pull off a the plastic snaps) Inside the case on the far left, there is a piece of crimped copper tubing, open on the top end, welded to the refrigerant line, with a black sleeve covering 2 wires out the bottom end. This is a thermistor. I CAREFULLY applied heat with a butane lighter (the mini torch kind, not the "candle flame" kind), taking care not to burn anything. I applied ONLY enough to make it slightly warm to the touch. Do not think of melting anything, as this is not the purpose. Applying too much heat could damage the thermistor. With the bucket in place, the unit started right up. After I did this, it failed again in a few minutes, so I heated it again, and thus verifying it as the source. I have done it a third time, never getting it much over room temperature, and it is still running after almost an hour after doing nothing else. Since this temperature sensing is an analog function to the microcontroller that runs everything, the fault could be any bad connection or solder joint along the way from this thermister to the controller. But is sure appears something in thermistor. I hope my description is complete and clear. Good luck.
Posted on Sep 16, 2008
SOURCE: motor
Your problem may be the thermistor that causes the CH01 trouble code.
Posted on Sep 20, 2008
heatman101
  • 43501 Answers
SOURCE: My comfort-aire dehumidifier #BHD-301 just stopped
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a Comfort-Aire BHD-301 dehumidifier that
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Posted on Aug 17, 2010
Hi my comfort aire dehumidifier is brand new. It was working fine controlling the humidity and the reservoir was filing with water. All at once, it acts like it is contolling the humidity, but there is...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Apr 10, 2011 | Comfort-Aire BHD-501 Dehumidifier
The fan on my dehumidifier is no turning when I turn it on.
heatman101
Jan 01, 2011 | Comfort-Aire BHD-501 Dehumidifier
My dehumidifier model bhd-501 won't shut off& is very hot. What might be the problem? Thanks
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Jun 18, 2010 | Comfort-Aire BHD-501 Dehumidifier
Dehumidifier is on but nothing happens
air filter clean.
water level switch problem.
control card problem
start at these points first........
if fan is working may be compressor.
Apr 20, 2010 | Comfort-Aire BHD-501 Dehumidifier
Comfort aire overtemperature switch part no. 47-21900-01 I am looking for this part. thanks stew
Call Heat Controller in Tennesse they distribute this although it is made by LG
Jan 22, 2010 | Comfort-Aire BHD-501 Dehumidifier
Good morning--my Comfort Aire dehumidifier will no longer run & is still under warranty. When I turn it on the red light just comes on.
May be power supply failure, faulty control panel or other problem. It may just need to be left unplugged overnight for reset.
Aug 27, 2009 | Comfort-Aire BHD-301 Dehumidifier
Motor
Aug 21, 2008 | Comfort-Aire BHD-501 Dehumidifier
Comfort-Aire HD-651 Dehumidifier Logo
361 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
J.D. Browning
J.D. Browning
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
