Question about Garden
The cub cadet lawn mower right blade broke and i need to know which way to turn the bolt to loosen it
    President:
  • 1,033 Answers
It will loosen as a normal bolt, left to loosen. but sometimes you will have to use a better force to break the tightness, such as a rubber mallet. Use something to lock the blade down from moving while taking the bolt off. Just don't lock it down against the mandrel or blade pulley.
Posted on May 03, 2010
I have a Cub Cadet 1800 (13AK608H101) - Cub Cadet Lawn Tractor. Seems like the pulleys must be removed to changed the blades is that right?
You should be able to change the blades by loosening a bolt in the center of the blade on the underside of the deck.
Mar 03, 2017 | Cub Cadet Garden
I can't get the blade off my cub cadet sc500hw mower. Bolt just spins.
I might need to lock blade with a piece of 2x4 jammed in between blade and deck that should help be careful not to hold blade with ur hand ..
Nov 07, 2016 | Cub Cadet Garden
Bolt broke off of adapter and blade. I replaced bolt and it broke again. So i replaced the bolt and adapter and now making a loud knocking sound this is on my cub cadet walk behind sc500z
Hi Diana:
I'd suggest that you pull the spark plug lead so it does not accidently start, and then try this.
Place the mower at a height where you can easily see under it. I use the tailgate of my pickup trucl.
If you put the handle inside the bed of the truck you can put a weight on the handle so the deck is tipped up. With the spark plug disconnected (or even removed) rotate the blade. Chances are that the knocking sound will be from the blade hitting the deck. It is possible that the bolts keep breaking because the blade is not seating properly.
I'm guessing that once you can see under the mower you will find the problem.
Aug 11, 2016 | Cub Cadet Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
54" Cub Cadet deck leaves strip of grass since I replaced the spindal
all three blades have to be lined up the same way when you put the belt back on.
Sep 09, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub Cadet zero turn. Cannot get the blades to turn when PTO switch is pulled. Belts are fine and attached. Please help. John
i had the same problem. there was a short in the relay just before the wire gets to to back pulley assembly.
Apr 28, 2011 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
I have a used Cub Cadet Model #144-664-100 that I purchased last year and used half of the summer and ran great but towards the end it wasn't cutting very cleanly. So I took off a mower blade, which was...
Have you tried running it with the blade back on? It may be ok as there is a braking system built into the pto clutch that makes the blades hard to turn by hand. Regards Phil
Apr 15, 2011 | Cub Cadet Lawn Mower Deck Drive Belt...
I have a cub cedet commercial tank 60 zero turn lawn mower, and i need to change lawn mower blades. Which way should i turn the nut to take the blades off.
As viewed from the bottom, if the blade turns clockwise, then the bolt should have a left-hand thread. A possible exception would be if the blade cannot slip relative to the shaft. This could be the case if the blade (not the washer) has a D shaped hole in it.
Good luck, Al K
Aug 26, 2010 | Cub Cadet Street Sign- tractor lawn riding...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
How to remove deck on 1045 cub cadet to remove and sharpen blades
You should be able to remove the blades without removing the deck
They bolt on from underneath with either a single or double bolt set up
90% + are single bolt
Mar 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
