Question about Invicta Subaqua Noma Iii S
How do i remove a invicta noma III watch band, the screws just turn
SOURCE: Invicta 2875 wrist watch band too large
take it to a jeweler and they will do it for a small cost. Usually less than $10
Posted on Dec 12, 2007
VOTIT
  • 2071 Answers
SOURCE: how to remove links on invicta russian diver watch
Hi Pate the only thing i can advice you is go to a service center near to your place.All watch technician like me have the knowledge to remove the links with no impaired damage or scratch.We know how to detach the links.So if want to know more of your watch i will give you a site that can help you and ask more information about your watch. www.invictawatch.com
Posted on Jun 17, 2008
escapement
  • 2334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
SOURCE: Adjusting band on Invicta 4901
I was having the same problem with mine. Even though the band has arrows, those really are screws in the band. Two really small screwdrivers and you can take out the unneeded links. They are in there really tight, so expect some resistance until they pop loose, after that its easy.
Posted on Dec 03, 2009
Testimonial: "Thanks, I'll try that. I tried 2 screwdriver before but I was afraid of breaking something. This gives me the confidence to keep going."
escapement
  • 2334 Answers
SOURCE: invicta 6480. band is rubber and stainless. screws
2 screwdrivers at once- one for each screw. Rate me, plz.
Posted on Mar 09, 2010
Testimonial: "thank you!"
Where can i get a replacement band?
watch shops and jewelers sell wrist bands
Feb 14, 2016 | Invicta Subaqua Noma Iii S
How to set date and day on INVICTA SUBAQUA NOMA III
Pull the stem out 2 clicks sets the time, pull the stem out just 1 click
turn it forward sets the day and turning the stem backwards sets the
date. I hope this helps
Jul 12, 2014 | Invicta Subaqua Noma Iii S
Watch ******** my invicta 5511 has snapped how do i get a new one
you can find what you need at Invicta Web-site http://invictawatch.com I had order straps from them for my Sabaqua NOMA III and russan diver here is also the link for the service http://www.invictawatch.com/support_files/service_center/ServiceCenter.htm
Nov 16, 2012 | Invicta Subaqua Noma Iii S
I need screws for invicta subaqua noma 3 band model # 6510
Good day I had purchase parts direct from Invicta and found that is easier then looking around for the parts here is the info;
Message Invicta Customer Service . Mon - Fri . 9am - 5pm EST
Email service@invictawatch.com
Call 800-327-7682 . Mon - Fri . 9am - 5pm EST
Fax 954-921-2508 or 954-862-5461
Write Invicta Watch Group
Attn: Customer Service
One Invicta Way (3069 Taft St.)
Hollywood, Florida 33021
U.S.A.
#PS
or you can also check them at their web-site http://invictawatch.com most parts are really low cost with the exeption of the mechanic parts
Apr 17, 2012 | Invicta Subaqua Noma Iii S
INVICTA SUBAQUA NOMA 3 SCREWS LOOSEN I have had five screws fall out of my watch in the last 9 months. Initially they fell out 3 months after purchase. Conveniently outside of the 30 day return policy. At...
I have an invicta subaqua noma 3 model no.0736 that I am trying to replace the bracelet/band and would like to know how to change it , how many screws do I remove and what screws do I remove, can you help me?
Dec 21, 2010 | Invicta Subaqua Noma Iii S
What powers my subaqua noma iii gmt limited edition model # foo27
It has an automatic movement powered by the movement of your arm.
Nov 07, 2010 | Invicta Subaqua Noma Iii S
Hello, I hope that you can tell me some true info about this watch. It is the Invicta Subaqua Noma III (above). Watch descriptions say that the watch has a unidirectional rotating bezel. Is this true??...
<P>Thank you for contacting FixYa.</P><P>I dont know much about Invicta, however they have a wonderful website where you can download instructions or contact them.</P><P><A href="http://www.invictawatch.com/welcome/manuals/">http://www.invictawatch.com/welcome/manuals/</A></P><P>Best regards.</P>
Aug 27, 2010 | Invicta Subaqua Noma Iii Chronograph men...
How do you pull the crown out on and invicta watch
mcdevito75 here, Your invicta may have a screw down crown that adds water proof protection to your watch, try to un-=screw the crown when un- screwed then pull up to set time.
Jun 26, 2010 | Invicta Subaqua Noma Iii S
SUBAQUA NOMA 3 SCREWS LOOSEN AND THE BRACELET OPENS ANYBODY ELSE
What 3 screws? Give me: Make, model, all the numbers on case back. Explain in detail what 's wrong. Where screws are/were located and so on.
Feb 05, 2010 | Invicta Subaqua Noma Iii S
Removing links
Watches either have screws in the links that you can remove to remove a link. Or they have a pin in each link that you must push out to remove a link. Some have a "hairpin" looking keeper that you remove. Hope one of these will work for you. Good Luck
Dec 14, 2009 | Invicta Subaqua Noma Iii S
Invicta Subaqua Noma Iii S Logo
240 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
