Question about SanDisk Sansa m240 MP3 Player
Need my mp3 player back!!
It turns on but it is frozen.
Don't know what to do
  • Anonymous Mar 26, 2008
    My SANSA m240 just locked up while I was playing the radio. I have replaced the battery and left the battery out over night and the thing still doesn't work. The thing is not on hold. When I push the power it now says initializing but doesn't do anything else. The only way I can turn it off is by removing the battery. When I plug it in to the computer it doesn't load.
    What should I do? David.W.Bloom@gmail.com
My SANSA m240 opens but not working , I have replaced the battery and the thing still doesn't work. The thing is not on hold. When I plug it in to the computer it appears in my computer window but does not open & it hangs up .
What should I do? kamilsticky@gmail.com
Posted on Mar 27, 2008
SOURCE: frozen mp3
hold the power button until the mp3 goes off!
Posted on Jan 03, 2008
  • 758 Answers
SOURCE: FROZEN SCREEN
Attention: Resetting the device will delete all the songs...!
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Jun 17, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: sync a infitek mp3
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
Posted on Jul 05, 2008
  • 758 Answers
SOURCE: frozen mp3 player on pause
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Thank you
Computerrep
Posted on Jan 29, 2009
jazzyboy11
  • 728 Answers
The reset hole should be at the bottom right side of the player depending on which model type you have. If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Posted on May 24, 2009
I have the 4204-A and it is stuck on one song. I can't change it it's frozen in this spot. What is happen and what do I do now? No it is not locked on the back. Just want it working again. Thanks...
Thier should be two small holes on the player probably on the back one is the microphone the Other is the reset switch. Mic should be labled. Take a straightened paperclip and gently press it
in the hole and the paperclip shoud press a switch on the inside of the player to reset it.
May 11, 2011 | RCA M4204 MP3 Player
Frozen?
try turning off the battery switch on the bottom of the player. Use a pen point slide it to the left for about 15 seconds, then back to the right.
Aug 11, 2009 | Toshiba Gigabeat S30 MP3 Player
Malfunctioned, is now frozen
open the back pop out the battery and put it back in, this should just restart it. if this doesnt work i dont know what to say
Jul 30, 2009 | SanDisk Sansa e260 MP3 Player
PocketStudio 5 Error - encDSP Init Err
I turned off the unit, then while holding down rew and record buttons at same time, turned on unit. I don't know why, but it worked.
Feb 07, 2009 | Tascam Pocketstudio 5 MP3 Player
Frozen mp3 player
Jan 28, 2009 | Microsoft Zune 2nd Generation Digital...
Frozen screen/
Try turning it off waiting 20 seconds and turning it back on. Sometimes that helps. If it doesn't, try looking in the users manual to troubleshoot the problem. Good luck.
Jan 27, 2009 | RCA M4204 MP3 Player
I need my mp3 player back!!
just hold on the power button 20 seconds, its works for me.
Mar 26, 2008 | SanDisk Sansa m240 MP3 Player
Insignia Mp3 player frozen
If you hold the power button for 20 seconds it will shut off. I had the similar problem where I unplugged my Insignia NS4V17B frozed on the bluetooth initializing screen. I turned it off then back on and it is now working fine.
Jan 09, 2008 | Insignia NS-DV2G MP3 Player
I won´t turn on/off
hi, i'm from chile and i don`t speak much english, but i'll try to help you, because i think i've the aswer by my experince. when i was listening some song, and press for the next song, my MP4256FM frozen and i can't turn it off or nothing like that. after many times that i put play again the same song and frozen again, i understand that the MP4256FM will not read any song that in his name have a X,?,?,?,?, or ? (example axel.mp3 or introduci?n.mp3). So you have to change the name of the song on your pc and the ploblem will solved. I hope that this help you. bye! =) Jonathan Zu?iga el.zunhiga@hotmail.com
Jan 10, 2007 | Audiovox MP4256FM (256 MB) MP3 Player
Frozen SanDisk c140 MP3 Player
make a prgram can enter to the mp3 player then make a new program for format all things in it.
Oct 16, 2006 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
