Question about Kenmore 53701 Dehumidifier
The bucket drain hole will not hold a hose. The threads are stripped. I would like to order a new bucket. Model#580.53509300 Serial number 308TA14498
    Guru:
  • 415 Answers
Fortunately Kenmore products are normally better at offering replacement parts than many other brands out there.
Here is a Link to SearPartsDirect specific to your humidifier. You will need to look at the "cut sheet" and determine which part you are looking for. Based on your description, it sounds like you need a tank?
I do hope you find this information to be very helpful to you moving forward. Please offer feedback on how I did. :-) If you have further questions, problems, concerns, please let us know. :-)
Posted on May 03, 2010
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
The water doesn't drain through the site to which I attached the hose. Instead it drains through a quarter inch hole (which appears to be a manufaactured hole, not a crack or break)to the right of...
It sounds like the unit should have came with a plug for the hole. You can probably obtain a plug from a home improvement or hardware store or even improvise one yourself. Also, make sure the unit is pitched so that the water actually runs towards the hose.
Jun 26, 2011 | Soleus Dehumidifiers
How do you hook up drain hose to model HDN455 RB
Remove the bucket and remove the plastic cap on the bottom of the bucket. Then take the rubber insert out of the cap and save it. You will use it later. Using the hose that came with the unit, thread it through the cap opening and add the washer to the cap. Screw the cap to the mating connector on the bucket. Be sure to use the washer or the connection will leak. Now, thread the hose through the round hole and extend the hose to the back of the unit. And finally, replace the bucket in it's original position in the unit.
Hope this helped you. Please let me know. Thanks.
May 27, 2011 | Haier HDN455 Dehumidifier
How is the external tube for draining outside connected to the dehumidifier. Does the tube insert into the right angle nipple, then the threded end conected to a drain hose?
No. The tube inserts straight into the drain hole. Follow the 4 sets below.
1. Connect a garden hose to the threaded drain hose connector.
2. Remove the drain-hole cover.
3. Push hose connector tightly into the drain-hole on Rear Grille.
4. Press the hose down and make sure the "Arrow" on the tab is pointing upward.
NOTE:
The hose attachment will accept a standard garden hose fitting. Do not over tighten the hose when
connecting it to the hose connector, use a rubber washer and tighten by hand firmly without stripping the plastic threads. Be sure the hose lays flat and has no kinks, as it will not drain properly.
Apr 12, 2011 | LG DH404E Dehumidifier
I would like to SEE a picture of how to hook up a hose from the DH to a drain.( no manual & cant find one for this DH 304) TO lift the bucket off & drain has become to heavy for me. Thanks,...
My DH 304 is a hand-me-down so I don't have a manual but it did come with a hose attachment which is plastic tube with a threaded end to which you attach a hose. The other end of the tube goes through a hole in the back of the unit and then through a foam screen inside the unit to slip over the drain plug. Aligning the tube and the drain plug can be tricky; it is helpful to remove the bucket to see if you're getting the tube onto the drain plug. Once you have the tube attached to the drain plug, align the tube in the hole in the rear of the unit so that the tab on the tube is inserted into the slot at the hole in the back of the unit.
Aug 26, 2010 | Goldstar DH304 Dehumidifier
My dehumidifier runs over or leaks is there a way to plug into a hose to see if that takes care of the problem
If you purchased the dehumidifier new, it would have come with a part called a connector drain hose. This part is a long plastic tube with threads on one end to accept a hose. The part simply slides into the rear of the machine (with the threads of the part facing the rear). If you dont have the connector drain hose, it's part number is 5214A20027B and you can easily order it online for less than $10.
Jan 18, 2010 | Kenmore 54351 Dehumidifier
I have the hose hooked up to the back but it keeps filling the tank and shuts off when it's full ,how do you just use the hose to drain
I believe you have to put a plug to drain that drains into the tank ,then it can only drain out the hose.
Jul 14, 2009 | Maytag M7DH65B2A Dehumidifier
I purchased a LG Dehumidifier MODEL LHD45EL and I followed instructions to attach a hose to it for the drain. I removed the drain hole cover and I don't see a drain hole connector or a hole to install it...
Remove the drain bucket. on the top there are two pieces that can be removed just by taking them out. they are just laying in there. 1 is the brush the other is the "drain tube insert" it is a plastic tube and has a threaded fitting on one end. take your garden hose with a female connector on one end just like you were going to install on your spicket outside of your house and connect it to the threaded end of the "drain tube insert" make sure you knockout the round plastic drain plug cover hole located in the back of the unit (it is behind where your power cord was stored) it has three tabs to break. remove drain bucket. take the drain tube with hose attatched and insert it into the drain plug hole in the back and attach it onto the drain outlet (the drain outlet is inside the drain bucket side at the top it looks like an elbow fitting) push the tube so that the flap with the arrow is flush with the back. once you get the "drain tube insert" almost all the way flush with the back -->if you look inside the drain bucket side you will see where it fits over the drain outlet
Jul 22, 2008 | Maytag M7DH45B2A Dehumidifier
Drain hose attachment
Checkout this website...they have an owners manual you can download: http://us.lgservice.com/ A little hard to find, but it's there. In short, there is a small hole in the back of the dehumidifier between the cord handles. There will be a cap held in place over the hole by three small connectors. With some pliers, remove the hole cover. Take your hose connector and place it in the hole until it won't go any further (you can feel it hit the front of the water bucket). The instructions will show pressing the tab of your hose connector into the bottom of the hole to hold it in place. Don't know about yours, but mine is too long to do that. Connect a short length of garden hose to the threaded end of the connector and you've got it. Instructions say hose has to be flat leading straight from the dehumidifier to a drain, so don't place the draining end of the hose up in a sink or anything, use a floor drain. Hope this helps!
Jul 31, 2007 | Goldstar DH304 Dehumidifier
Drain problem
I have the same problem and after talking (mostly waiting) with Fedders repair, I have been told how to solve the problem. Plug up the drain hole on the right side (the one not connected to the drain hose). The drain hole extends down about 5mm, outside measures 10mm and interior measures 7mm. They do come with a drain hold cover. Not a replaceable part with a number. Off to the hardware store.
Apr 03, 2007 | Maytag M7DH65B2A Dehumidifier
Kenmore 53701 Dehumidifier Logo
94 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
