Question about Kenmore 94702 Front Load Stacked Washer / Dryer
Just bought the washer and dryer. Dryer works washer does not how do i hook up washer
    Guru:
  • 351 Answers
Hi .. There should be a seo\parate power cord for each unit. If there is not a separate cord , then look for a cord the interconnects the two uniots .
Posted on May 03, 2010
How do i replace a stack washer dryer dryer door switch?
when you open washer door you hit a stopper pin that holds the door open. there are 2 screws located around that area on both sides of panel. remove them and you'll see vent hook up and water line hook up and power cord. Now at the backside of washer door panel there are two screws remove them and pull washer door panel towards you. under the door panel connected to panel is where you will find door switch. if you jump out door switch and it works then you need new door switch.
Apr 30, 2014 | Whirlpool Thin Twin Washer and Electric...
Washer filled with water then stopped working, still full of water. Drier works just fine. Happened durring an electrical short in my house, but the fuse that was blown was not linked to the same part of...
You state you had a short in the home. Since the washer is on 110V system, you can try a different outlet and see if the machine works. Although you state that it isn't on the same part of the panel as the washer/dryer, and the dryer works, the dryer is on a different breaker, and it may indeed have had some effect on the panel that hooks to the washer. Try my first option, and let me know how you make out. I believe you'll find that to be the trouble
Joe
Sep 07, 2011 | Frigidaire FEX831CS Top Load Stacked...
I bought a used stacked washer /dryer. I hooked it up likea standard 220 dryer. Has the standard dryer plug in. Would not run start or hum in 20 mode. Checked the wiring. looks like it was wired for 110,...
All standard dryer motors run on 120V. Its the heater that uses 240. Its possible to wire a dryer for 120V operation and it will appear to run ok but it won't heat efficiently and it will take several cycles to get the clothes dry. Sounds like you have a mechanical problem with the motor.
Jul 14, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
We have a Oasis Washer and Dryer with 4 hoses 1 is a Y trying to figure out how it all hooks up as we have only had 2 hoses in the past 1 for hot and one for cold???
If you purchased a steam dryer then the one hot hose hooks to the dryer. The cold hose goes to the washer. The hot hose from the valve goes to the Y then one hose to your washer and one hose to your dryer
Jul 11, 2011 | Kenmore Washing Machines
Dryer wont work
I'm assuming that the dryer is gas, since both the washer and dryer are on the "same" breaker. I'd try replacing the wall plug before replacing the dryer. If you have a voltage tester, you should see if you are getting an honest 110 volts coming off the circuit. Since the circuit was a problem before, I would test it first and then more on.
Jun 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
This is our 2nd new Maytag Performance Series 5000 gas dryer. Bought at Home Depot. Originally bought w/d and they just dumped the pair off. Had to hire a plumber to come and hook the gas up. Washer works...
No solution. In fact we just bought a new 5000 dryer and it did 4 loads before DYING. Will not dry at all and machine definitely is turned on. Currently struggling to get it replaced.
Apr 10, 2009 | Maytag MGDE500V Dryer
Missing adapter to stackable whirlpool washer dryer front load
unclear as to the exact part your looking for, the dryer, should have a 4" hole out the back of the unit in which you install a standard 4"venting which is available a any large hardware/ home improvement store
Nov 15, 2008 | Whirlpool Washing Machines
Front load dryer
Read the instruction manual carefully. If you are certain it isn't working as it should then don't hesitate and tell the supplier it is faulty and to send a replacement or give a refund.
Sep 24, 2017 | Kenmore 94802 Front Load Stacked Washer /...
Washer doesn't work, dryer does- HELP!
  • check your breaker, one side of the 220v circuit breaker may have tripped causing only one of the units to work.
  •  turn your breaker off then back on.
Jun 28, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
Won't Start
do you have the power cord correctly hooked up and have the correct voltage ? is the white wire in the middle? you should have 120 volt with red-white . 120 black- white and 240 black-red... careful with electricity it can hurt and kill you. let me know if you fix this one...krazytech
Sep 16, 2007 | Frigidaire AEQ6000ES Electric Dryer
Kenmore 94702 Front Load Stacked Washer / Dryer Logo
44 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
