Question about Acer Computers & Internet
Acer aspire x1700 64 bit system powers up, but no display on monitor. I've connected monitor to mb display with no success. I installed a new DVI display adaptor, with no luck. I am apparently not getting a successful post. What do I do next?
  • 52 Answers
Check your ram. put out all ram from pc and start your computer. than put one ram in pc and start the pc if it is work than the problem is in one of you rams.
Posted on May 04, 2010
Testimonial: "I followed this solution and it worked. I've been trying to get the Acer working for months. Thank you so much. "
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
I am using acer P205H monitor ,when i plug in it will start and shows acer symbol on the screen but goes blank as computer starts ,i checked all power cables they are OK ,and some switches are provided on...
that switches r made basically changing dvi to vga r vga dvi,if that switches r malfunctionig display goes to blank that means if u connect vga system will have dvi
Jan 30, 2011 | Acer AL1916W 19" LCD Monitor
My Acer Aspire 5520G will not play a Blu Ray disk. It keeps telling me that I need a critical update to the Acer Archade DVD playing software. When I click on the update button it comes back with a message...
from these derived specs You do not have a blue ray drive installed in this you have a DVD drive so of course a blue ray would not play in this unit. Specs are below from acer
CPU: AMD Turion 64 X2 TL-58, 1900 MHz [(9.5 x 200), L1 cache 64 KB/core, L2 cache 512 KB/core - dual-core, 64 bit support]
Motherboard Chipset: nVidia nForce 7000M-610M (southbridge), AMD Hammer DDR 2 IMC (northbridge)
BIOS Type: Phoenix
RAM: 2048 MB [667 MHz DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)]
Video adapter: nVidia GeForce 8600M GS, 512 MB GDDR2 [128 bit, core clock 600 MHz, shader clock 1200 MHz, memory clock 700 MHz - support for DirectX 10]
Monitor: Acer CrystalBrite 15.4" LCD (LG Philips), WXGA [8 ms/220-nit, currently running at 1280x800@60Hz] - HDTV capable
Audio: Realtek ALC268 @ nVidia MCP67/68 - High Definition Audio controller; Dolby Sound; audio jacks (on the front side): headphones, microphone, S/PDIF
Networking: nVidia MCP67/68; (wireless) Atheros AR5007EG - 802.11 b/g
Storage: Hitachi - 160 GB [8 MB cache, SATA, 5400 RPM]
Optical drive: Mats hita - 2 MB cache, DVD +/- R/RW/RAM/ROM, dual layer support, CD R/RW/ROM
Card reader: Ricoh - 5-in-1: SD, MMC, MS, MS PRO, xD
Webcam: Acer Crystal Eye (Bison) - 0.3 Mpixels
Connectivity:
4 x USB 2.0,
Broadcom Bluetooth adapter,
CXT Fax/Modem - 56K, V.92,
DVI,
ExpressCard,
IEEE 1394 (FireWire),
VGA,
RJ-11 (modem),
RJ-45 (Ethernet),
CIR (Consumer Infrared),
S-video/TV-out (NTSC/PAL)
Battery: Lithium Ion, 6 cells; (initially) discharge time ~3 hours
let me know
please do leave feedback and ratings for your free answer today.
May 08, 2010 | Acer Aspire 5520-5908 Notebook
My screen doesnt get a signal from the computer what could be wrong?
There could be three reasons for the same .
1. Loose signal cable: Check and reseat the VGA or DVI cable from the back of the system tower to the monitor.
2. Bad monitor : Disconnect the monitor cable from the back of the monitor check if the monitor displays anthing .
3. Bad video card : Try connecting an alternate monitor to check if the same is displaying anything on the screen.
Thanks for using Fixya
Proton
Jan 07, 2010 | Acer Aspire T310 PC Desktop
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
Monitor only works with DVI/VGA adaptor.
if your monitor came with a disk try installing the drivers again you might still have the drivers for the previous monitor you had with your system if not try going to the manufacturers website and getting the drivers and install them
Aug 13, 2009 | Acer AL2016W 20" LCD Monitor
Acer monitor cable/ accessory
the best way to do what you are describing it to have 2 display adapters installed...and use your 1st display for your monitor and the second for the digital receiver..... then you would optimal performance and have more video memory for each display allowing faster productivity
Jan 07, 2009 | Acer AL1916W 19" LCD Monitor
Trying to connect Acer X213W monitor to Acer 3613 laptop. First Q-My laptop does not support 1680 x 1050 resolution, can I still use the monitor?Second Q- I can't seem to locate where to connect (hardwire)...
1. Yes, the monitor will just display the resolution set by your laptop.
2. There should be a VGA port on your laptop, it's a trapezoid shape with 3 rows of 5 holes and usually blue. Since your monitor only has a DVI cable, you need to get a DVI to VGA adapter to be able to plug your monitor into this spot.
Dec 27, 2008 | Acer Aspire 3613WLMi Notebook
Radeon x1550
get a dvi capable monitor
Feb 24, 2008 | Power Color RADEON X1550, (256 MB)...
Dual monitor problem
I think you may have to use tv out as the secondary monitor
Oct 31, 2006 | Gigabyte GV-NX62TC256 GeForce 6200, (256...
Computers & Internet Logo
487 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
