Question about Epson Stylus Pro 9800 InkJet Printer
Maintenance request 0040 - Epson Stylus Pro 9800 InkJet Printer
    Sergeant:
  • 166 Answers
Maintenance request code:
The pump counter is near end of life, replace the cleaner kit ASAP.
This is what 0040 means.
Posted on May 03, 2010
    New Friend:
I have Epson Stylus Pro 9880 and the following fix work perfectly without wasting any ink:
THE ERROR IS A CLEANING UNIT END OF LIFE WHICH HAS BEEN FOUND TO NOT BE A NECESSARY REPLACEMENT. YOU CAN RESET IT AND CONTINUE TO USE IT.Step 1 Turn off the Epson printer
Step 2 Press and hold the Down, Right, and Enter (CENTER) buttons and turn on the Printer.
Step 3 Release the Down, Right, and Enter (CENTER) buttons once the screen says "SELF TESTING" .
SELF TESTING /Test
now press up arrow twice to
SELF TESTING/Parameter
Press right arrow 2 times for Initialize / All
Press up arrow 1 time for Initialize Cleaner Record
Press the center button 2 times, it will say initialize/ OK?
Turn printer off and then back on
Posted on Jun 28, 2015
  • Anna Ryzhova
    Anna Ryzhova Aug 30, 2016
    very very helpful, thank you!
  • Anonymous Sep 20, 2016
    Very very helpful from me too! Thank you
3 Suggested Answers
rcw1962
  • 2571 Answers
SOURCE: Maintenance request 0040 is showing
If you ring epson, they will charge $456.15, i found this forum that may be of help http://www.minilabhelp.com/forum/Blah.pl?v-print/m-1119948275/
one answer posted is this
Please follow the following instructions precisely?.
1) POWER OFF
2) Hold down the ?Paper Source? button + ?Cut Eject? button + 1 paper feed button (Down arrow)
3) POWER ON, whilst holding the buttons.
4) ?View Counters? should appear on the display, so press ?Paper feed? button down until ?Clear Counters? is displayed.
5) Press ?Select type? button + Paper Feed button + wait until ?Cleaner? is displayed.
6) Press ?ENTER? button TWICE
7) Switch machine OFF
8) Switch machine ON
Outcome
The error display should then have disappeared, and should read READY
IMPORTANT
This process can ONLY be followed ONCE before an engineer is required.
Hope this is of help
Posted on Oct 27, 2010
  • 7 Answers
SOURCE: What is maintenance request 0040?
cleaning unit near end of life
Posted on Dec 20, 2008
How to Reset Maintenance request 0040, Epson 9890
Did you replace the low ink cartridges? The 0040 request code is from the ink dispenser pump saying it has reached the specific number of pumps for that particular ink cartridge. Once you change out the low ink cartridge the pump will automatically reset.
Oct 15, 2016 | Epson Office Equipment & Supplies
Service call error 00010040
Common Error Codes
00000101 The CR Motor reached it's end of life. 00010000 PF Encoder Check Error. 00010005 CR Motor is out of step. 00010014 Pressurising failure. 00010027 Pressure pump micro air-leak error. 00010040 Printing position error. 0001002D The cleaning unit reached it's end of life. 0001003F The Pressure Motor reached it's end of life.
Servicing Levels
Three levels of servicing are available and detailed below:
  1. Basic 0040 or 0001002D maintenance procedure: This will return your printer from either the 0040 or 0001002D error to a working state by replacing only the relevant maintenance items.
  2. Advanced 0040 / 0001002D maintenance procedure: As well as replacing the parts relating to the maintenance error additional adjustments such as bidirectional/unidirectional alignment, 980mm feed adjustment, firmware updating and a general clean will be performed.
  3. Overhaul: All maintenance items as well as the PF, CR motor and belt, cutter cap, pressure assembly and cutter solenoid will be replaced. A check for any design defects such as a defective cutter cap and a defective pressure lever will be performed and any parts will be replaced if necessary. All head and feed alignments will be performed as well as any required software updates and sensor verifications. A thorough clean will also be performed on the carriage area and the print head. When the procedures are complete a survey will be performed to better understand your requirements and any recommendations will be brought forward.
info.gifIt is recommended that if you have recently come into ownership of a second user Epson Stylus Pro 9800 then you should assume that the counter values or service life levels are incorrect and choose the most thorough procedure detailed above. The reason for this is an increasing number of printers being "reset" without the actual parts being replaced or inexperienced owners trying to repair or replace parts incorrectly. In one such case a part was removed and replaced incorrectly causing a serious ink leak which was luckily caught early due to the undertaking of an thorough maintenance procedure, but unfortunately extensive damage had already been caused to the chassis and maintenance tank area.
I copied the error code and put it in the search bar in a web browser and came up with the answer. In the future just google the codes and see what comes up. Also you can download a Field Repair Guide PDF and a Manual PDF from Epson's website too.
Jan 25, 2013 | Epson Stylus Pro 9800 InkJet Printer
Epson 9800 Cleaning Unit Replacement
you don't need to replace any thing just before on your printer press and hold Down, Right and enter buttons on printer panel and than on the printer after on leave the pressed buttons its show a new menu on it press down on adjustments and than enter again press down on counter clear and than enter again reset it than restart printer. thanx
Jan 08, 2013 | Epson Stylus Pro 9800 InkJet Printer
No problem with player just need to know how to make it region free it is region 2 at the moment
    You'll need a Palm with OmniRemote software
  1. Type in (or transfer) the memo below to your PDA
    Import it into OmniRemote with this menu command:
    Advanced-->Databases-->Import category
  2. Point your PDA towards your player put OmniRemote in TV-mode and press 0 (Zero)
Memo (Name: Category-TV): Category-TV Button name-Enter 0000 0067 0000 0000 Button name-0 0000 0067 0000 0044 0155 00ac 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0404 0155 00ac 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0404 Button name-7 0000 0067 0000 0000 Button name-8 0000 0067 0000 0000 Button name-9 0000 0067 0000 0000 Button name-4 0000 0067 0000 0000 Button name-5 0000 0067 0000 0000 Button name-6 0000 0067 0000 0000 Button name-1 0000 0067 0000 0000 Button name-2 0000 0067 0000 0000 Button name-3 0000 0067 0000 0000 Button name-Channel up 0000 0067 0000 0000 Button name-Channel dn 0000 0067 0000 0000 Button name-Last 0000 0067 0000 0000 Button name-Volume up 0000 0067 0000 0000 Button name-Volume dn 0000 0067 0000 0000 Button name-Mute 0000 0067 0000 0000 Button name-Power 0000 0067 0000 0000 Button name-Favorite 0000 0067 0000 0000
Nov 15, 2010 | Pioneer DV-350 DVD Player
Creative vf-0040
You can find the drivers here.
Dec 21, 2008 | Computers & Internet
Epson 9800 printer
cleaning unit near end of life.
Sep 11, 2008 | Epson Stylus Pro 9800 InkJet Printer
Need multi region code for bdp 51fd
This is the only Blu-ray player that can be made region-free.You will need a professional and fully programmable service remote, like Harmony or a Palm or PDA that can support Omniremote software. The procedure may look complicate if you have not done anything similar before. You will have to reprogram the remote using a PDA or a computer.
Print this out and follow instructions here.
For example using OmniRemote™ Pro V2.01 and a Palm
1. Install the OmniRemote on the Palm, or PDA.
2. Copy the current Category to the Palm memo pad
3. Modify the "Button name-0" data with the following code:
4. Import the database in omniremote
5. Turn on the DVD Player. Press newly programmed 0 button on the palm. The Palm will control the DVD, and the DVD Player will turn off and on again. On restart it will be region free.
Sep 01, 2008 | Pioneer Televison & Video
Epson Stylus Pro 9800 InkJet Printer Logo
7,190 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
