Question about Kodak Digital Science 1500D Path-Through Scanner
F60 Call service 50FFA200,error on display
This shows on display of Kodak Scanner 1500d!
Can u please give more details
Posted on May 04, 2010
Kodak scanner i3400 error e73
e73 is A USB command failure. Check to see if the scanner is connected to a USB 3 port. A USB 3 port can be identified by the port being Blue in color or have the letters "SS" (Super Speed) near the port. Kodak scanners behave strangely with USB 3. With the unit turned off, please connect the scanner to a USB 2.0 port. Additionally, download and install (as an administrator) the most current drivers from Kodak.com which alleviates 9 out of 10 issues.
Apr 04, 2014 | Kodak Office Equipment & Supplies
"cycle error" - scanner powers up ok but will not scan due to this error ID=055
Error 55: "Lamp I2C error reading from DAC". Operator log message: "Cycle power, if problem persists, call service.". This error is involves communication errors between the LED AY and the DAC. A couple things can be done to alleviate this issue but unfortunately, as a user, you can only perform the first step. The other steps require a Kodak Field Engineer to complete. First step, upgrade your Firmware. Firmware updates can be found at the following web page: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Production/i5200_Scanner/Support/Drivers_And_Downloads/i5000_Series_Scanner_Firmware/index.htm. If you still experience issues following the firmware upgrade, call Kodak Service & Support to schedule a field engineer to be dispatched to your site.
Mar 03, 2014 | Kodak i5200 Document Scanner
Tengo un error 50FFB800 call Service y no se que pasa
Yo tengo el mismo error, alguien sabe que puede ser? Gracias.
Jan 24, 2014 | Kodak Digital Science 1500D Path-Through...
Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Nov 07, 2009 | Kodak ESP 5 Printer
Error F60 call service 50FFB200 on Kodak 1500d scanner
Usuall cause of the problem is that the optics are in need of a very good clean. May also need a new lamp if cleaning does not solve the problem
Jun 17, 2009 | Kodak Office Equipment & Supplies
Have Kodak 1500d. Import with photoshop turns off computer.
I have library of photos with HP. How do I import them to Kodak. It just comes up with Snapfish.
Apr 14, 2009 | Kodak Digital Science 1500D Path-Through...
Looking to purchase the Kodak Digital Science 1500D service manual
You can either buy it from kodak Kodak Customer Support: (800) 235-6325
or you can go to this site as well KODAK
and register
pls dont forget to rate solution
May 02, 2008 | Kodak Digital Science 1500D Path-Through...
Panasonic DMR-ES46V shows F60 Error
I have same problem with es40v - f60 error with no response to troubleshooting protocol. This machine also was used very little & also has a history of turning itself on. Panasonic used to make high quality products. A shame that their products are no longer trustworthy. I can understand that machines break - i'm very frustrated to learn replacement parts are not available. Guess i need to re- think brand loyalty.
Sep 02, 2007 | Panasonic DMR-ES46VS DVD Recorder/VCR
Kodak Digital Science 1500D Path-Through Scanner Logo
241 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
