I've got Nero 4.0 and it freezes during transcoding. The files are about 400 MB each and I'm trying to figure out how to put 6 of them on one 4.0 gb dvd...I've done it before with the same program, but now it will only let me put 2 of those videos per dvd.
    Problem Solver:
  • 32 Answers
I think there are something wrong with your programme, I edit dvds before for my PC with Daniusoft DVD Ripper, but not to put all on one dvd, there are about 600MB and works smoothly.
you can contact with the Nero support to update the programme.
Posted on Mar 26, 2008
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Below are the specs you requested on these 2 systems.
Optiplex GX280
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
Maxtor OneTouch 4 Plus 750gb temporary fix / refrigerator
I could not recover any files and the drive would not id on my desktop. I kept plugging in and out the power chord to see if it would ID. It did briefly (3 minutes) and then started clicking again. My whole system would freeze until I unplugged it. Even with SeaTools. Then I thought it was trying to recalibrate to find track 0 so I put it into the refrigerator for 6 hours (42deg F), took it out and powered it up. I was able to back up all my files to my DVD burner and now it is back in the fridge. Go figure......Greg R.
on Aug 01, 2010 | Maxtor OneTouch 4 Plus 750GB External USB...
Nero 7 Ultra Advance-to-Time Index Problem Work-around
Posted under Nero 6 Ultra because there is no Nero 7 Ultra listing here on Fixya...
OK, I am going to tell you how I managed to work around this problem. I am posting this in the hopes it will save someone else the aggravation I had in stumbling around trying to find a procedure that would fix the problem. I found a work-around I can live with, so here's the problem and the solution follows. If it applies to you, I hope it makes your DVD-burning life livable again! Oh yeah, looks like Nero 8 is ready to come out soon. Just when you though it was safe.... anyway, here goes:
The Problem:
Burning DVDs using Nero 6.2 on Win ME was successful, and it allowed for advancing via time index. For example, I would burn a DVD and be able to go to any time point in the scene. However using Vista and Nero 7 Ultra, while DVDs burn successfully, the advance-by-time index is no longer available in DVDs burned under Vista with Nero 7. Details:
DVD burner: Buslink DBW1647-U2
O/S: Vista Home Basic
S/w: Nero, Ver. 7 Ultra, registered
DVD media: 16X Starlogic DVD-R
DVD player: Goldstar VM681M
The scenario is this:
1. Begin playing a chapter on the DVD
2. Click the chapter menu button on the remote.
3. Use up-down arrow keys on remote to try to get to timed index setting (ie, the one where if you select it and type "10:00" it will jump the scene to the 10:00 mark).
4. Can't select that option.
The Work-around:
1. Open Nero Vision and choose to create a DVD.
2. Access the Options by clicking More>> and make sure Nero SmartEncode is set to 'Disabled'. I think since Nero wants to convert everything to MPEG-4 that that might be a factor. Also, you may need to get some codecs, too. I am using the K-lite full pack available here: (Note that K-lite doesn't like other codec packs being on the same PC as it-- it nagged me to uninstall the DivX and Vista Codec Packs, and I did. I have discovered no problems so far since.)
3. Add your video files and step through the rest of the process. Settings to look out for: Automatically create chapters: NOT checked, Enable Forward/Backward Jumping: checked.
4. On the last screen, choose to Write to Disk instead of burning to the CD drive-- select a place to save the DVD-compatible files. Click "Burn" and off you go.
5. After your DVD files are written to disk (they will be in a folder called TS_VIDEO in the place you chose to save them to), fire up a copy of ImgBurn ( [Maybe Nero's image burner will work too, I just haven't tried it. In any case this is known to work so I am using it here.]
6. Switch Mode to Build -- you need to build an .iso image file in order to burn it to DVD -- and select the TS_VIDEO folder holding your Nero-ed files. Indicate a name for the output file and run it. This should not take nearly as long as Nero took in creating the raw DVD files. The .iso file you created will be close to the same size as the raw DVD files are in the TS_VIDEO folder Nero created.
7. Now switch mode to Write and indicate the .iso file you built as the input and select the target DVD drive you are using, then run it. The burn process should not take long, either, compared with the other steps.
8. Test it in your DVD player-- you should be able to jump to time indexes now.
I have no idea why this works as opposed to the transcode-then-burn process that worked for me under Nero 6.2. There may well be other ways to deal with this problem, I just don't know what they are. Downside to this approach of course is that you need about 33% more disk space as compared with that required for transcode-and-burn (t-and-b: need space for the original files and Nero temp files; the .iso approach: need space for the original files, the DVD-compatible files Nero creates, and the .iso file created from that). However this is an alternate procedure, not a fix, and the only approach so far I have found.
Plenty of good DVD discs gave their lives to discover this process. I hope I can save you some misery and trips to the store for more blank DVDs by posting it here.
on Feb 22, 2008 | Ahead Software Nero 6 Ultra Edition...
Hi , my motherboard is k7n2 delta 2 platinum ms-6570e , i've had a problem to install windows xp , but finally i did it . Now i've got problem to install some programs like office , nero itp....
Hi, you can download the drivers manualy from here:
The drivers or the bios file needs to be unziped before installation.
Install first the system and chipset drivers.
Try also to run windows update.
You will need the updates to install office and etc.
Try also to add more memory ( ram ) to your system.
Supports DDR200/266/333/400
Aug 24, 2011 | MSI K7N2 Delta2 Platinum Motherboard
I don't know how to download my files to the Iomega 500gb portable hard drive. Then, if I want to bring back my files, how do I do that? I sound like an idiot. I've had this thing for about 6...
When you plug the drive into the computer does windows alert you that a new device was detected? If you open my computer you should see and hard drive listed that will only be there when your external drive is connected.
Aug 21, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
Desktop Freezes and lockups..... I've changed out ram, I've tried new hard drive and trying to do a reinstall and it locks up during reinstall.... Opened and cleaned fan and residue underneath fan...
remove power cable, remove ram, remove small battery from motherboard, , paper put in small water, and with it clear ram contacts /only ram contacts/, then put all in teir place, turn on, if it will be lock again, you need chnage power suplay.
Jun 07, 2011 | HP Pavilion a6347c Desktop /Athlon 64 X2...
Sony Driver
Without the model number the above is meaningless.
Jul 30, 2009 | Sony Computers & Internet
You dont need any driver since your PC is configured as x64 bit processor so all you got to do is get hold of the XP OS which is meant for x64 compatible PC's. The one normally used is 32 bit named as x86. I hope u wont face any difficulty in getting hold of x64 based OS(XP)......sodeep
Jul 30, 2009 | Computers & Internet
Memorex DVD+R DL 8.5 GO 8X compatibility
If all you are looking to do is write a DVD (ie, burn ordinary OS-managed files onto DVD, without transcoding, etc.), or write transcoded DVD-structured files, or an .iso image file, then don't even try to use Nero. Use ImgBurn, it is 500% better for those kinds of tasks, and it's freeware. I use it to burn DVDs but use Nero to transcode files and create the VIDEO_TS folder files. I then use ImgBurn to convert them to an .iso file, then burn it to DVD, also using ImgBurn. URL:
Mar 30, 2008 | Ahead Software Ahead Nero 6.3 Suite 1...
Mp4 player
You can try Nero 8 ( which has a cool player (Nero Showtime) and a user friendly transcoding/DVD authoring tool (Nero Vision) to offer. You may also consider Videolan VLC ( which is free, open source, less user-friendly but it supports batch file conversion -- a realloy cool features when you have a dozen+ video files to convert.
Jan 11, 2008 | Sanyo Xacti HD1 Memory Card Camcorder
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
