Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer that water pools in the
I have a Whirlpool duet washer that water pools in the bottom of the tub when not in use.
  • 15,935 Answers
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Duet washer does not drain all the way. clothes left in sitting water
sounds like pump not working fully.at the bottom fo machine theres a round plug.,that sounds blocked.open and unblock.alot of water will come out so get plent towels down.
Jun 04, 2016 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is...
empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.f94b104.jpg
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Monthly Cleaning Protocol
  1. Hello. here it is: Use only the proper amount of HE (high-efficiency) detergent in your Duet. Whirlpool has stated that using too much detergent or fabric softener in the Duet can ruin a high-speed spin bearing responsible for spinning the basket. The replacement part is approximately $600. Whirlpool also claims that using too much detergent or softener can cause fungus growth.
  2. If you have mold and mildew problems with your Duet, check the filter trap. Unplug the washer and remove the three screws in the seam between the door and the bottom panel to remove the bottom panel. The Duet drain pump has a design flaw that leaves about a cup of water in the filter trap under the tub. Clean out that filter with bleach every month or two to eliminate mold problems.
  3. Put small items in a mesh bag before washing. There is a good chance they will get lodged in the Duet's filter trap, if you don't. Check the filter trap mentioned in Step 2 monthly to make sure there aren't any small items blocking the filter.
  4. Remove your detergent dispenser every month and wash with warm water and bleach to prevent mold buildup. Remove the fungus smell from your washer with Affresh washer cleaner. Always keep the washer door open when not in use.
Apr 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool duet sport front load washer is fairly new (2008) now it has started dripping water during the cycle under the front of the machine. any suggestions would be helpfull.thank you
check tub boot for any tears in lip that seals to door zippers etc. can tear this.also sometimes water can leak from pump cleanout.you would need to remove bottom panel to check this
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water is leaking from the bottom of the door while in the wash and or rinse cycle
  • Check the pump & all of the hoses first.
  • If you see water leaking from the bottom of the tub this could indicate a bad tub seal.
Jan 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet will not drain or spin
Hi
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting fixya.com
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water is pooling in the wash tub even after the cycle has completed. the next day, the tub is full of water and leaking out the front
Your Mixing Valve (water valve) is not shutting properly.
Replace it to solve your problem.
Thanks for using FixYa!!
Jul 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Problem with whirlpool duet
you can access the drain pump assy by removing the 3 screws across the bottom of front panel, after that youll see the drain pump directly in front of you, youll need to unscrew t he filter cap form the "button trap"assmebly, this is what catches all the junk left in pockets, or the baby socks, so they dont make itr into the puppmp itself. be warned there will be water wanting to come out after unscrewing the cap. ALOT depending on amount of water in machine!!!!!!
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front end Washer
you have a bad water inlet valve. its not seating properly allowing water to trickle in when not in use. youll need to replae the water valve. in mean time turn water off between uses.
Mar 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
151 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
