Question about ASUS P5P800-VM Motherboard
How do I get into bios? None of the usual keys eg DEL work
  • 3,530 Answers
Keep on tapping F1 or F2 once you pressed the power button.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on May 03, 2010
Where are the bios settings located?
Depending on what make & model of computer you have, right after the first beep during boot-up you will need to hit the "DEL" key or a function key. Watch the screen closely during boot-up and you should see a message that says "Hit DEL during startup to access BIOS." Dell computers usually use the "F2" key. You may have to tap it a few times to get into the BIOS. BE CAREFUL when you change settings in the BIOS. You can make the computer stop working if you change the wrong settings.
Aug 30, 2015 | Computers & Internet
Function keys
Enter BIOS by pressing F2 or DEL or F10 (try all), and see if there is a Function key option. Change it, save and exit. If everything else is working fine, you can also try to push and hold Fn key and then press a function key.
Nov 19, 2012 | Dell Inspiron 1501 Notebook
Cannot access the bios on my brothers toshiba satellite l40-18z
On toshiba laptops you use the F10 key to get into your BIOS SETUP. The generally combinations of BIOS Setup is:
1) DEL (delete key)
2) F2 (F2 Key)
3) F10 (F10 Key)
4) Ctrl + F10 key
Oct 30, 2012 | Toshiba Computers & Internet
Booting problem
Restart your computer
have a close look at the screen it will be quick you will see which key to press to enter bios
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
others you might try
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Sep 27, 2012 | Sun Blade 2500 PC Desktop
How to access thr bios on reboot
Usually it's the Del key, if that is not working try F2 or F10. If none works, upon reboot look at the bottom of the screen you will see which key is associated with Setup or Bios Setup and press that.
Feb 11, 2011 | Computers & Internet
How to enetr bios set up of a com with mother
if you want to enter the bios set up of a mercury motherboard what you have to do is that from the begining of the system booting, system will give you the key to hit or press like some system may tell you to press Del key, some may resquest for F1 but you can try any one of this keys Del, F1, F2, F10, Ctrl+Alt+enter try any none of them. then go to booting sequence. to set the setup.
Jun 12, 2010 | Mercury P4VM800M7 Motherboard
I want to reformat my computer, my question was how to first boot my cd rom to install...
Start your computer.
When you see the 'Press DEL to enter BIOS SETUP mode", press the 'DEL' key.
Change the "boot-order" to put your CD-ROM as the "first" (highest-priority) boot-device.
Save-and-exit from BIOS setup.
Insert the disk into the CD-ROM.
Your computer should boot from the disk in the CD-ROM.
Apr 07, 2010 | EliteGroup P4VMM2 V7.3 (P4VMM273)...
I have a durabook R14K, i need access to bios, how do i do
Usually you can acces BIOS by pressing
"DEL" Key duing system startup.
But it also depend on the BIOS manufacturer and version on how to access BIOS
I'm giving you all the key which normally used to access BIOS.
1.DEL
2.ESC
3.F1
4.F2
5.F10
6.F11
7.F12
8.ESC+DEL
try them ,it will surely let you access BIOS.
Jan 02, 2010 | Twinhead Computers & Internet
ERROR IN STARTING
Hi, You have to configure your CMOS/BIOS. On powerup, press "Del" or whatever key is necessary to enter CMOS/BIOS Setup. Once inside, verify that 1.44 FDD is enabled/checked that is if your PC has got one and set to None if none, thereafter Save & Exit. Verify also that the FDD is connected to a power connector from the PC's power supply. Likewise check that the flat cable is securely connected. It the FDD shows a continuous light, it may be that the flat cable was wired/connected wrong, if this is the case, simply reverse the way it is connected to the rear of the FDD. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 30, 2007 | Computers & Internet
ASUS P5P800-VM Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
