Question about Sharp MX-2300N Color Copier
Mx-2300n network error ce-00 when trying to scan to email?
Using Internet Browser access to the Printer/scanner, accessing Network settings, I noticed that the "Connection Test", (below the SMTP Settings), would not go through when SMTP Authentification was set to "ON". Turning it "OFF" allowed the connection test to succeed, but did not change the error code.
However, adding a secondary SMTP Server, allowed it to go through, (leaving SMTP Authentication set to "ON").
Good Luck
Posted on May 17, 2010
Keep getting a e-00 code on a sharp mx 2300n when trying to scan to file via network folder
The code is probably a CE-00 and it means that the copier doesn't detect a active network. Usually means the network cable is not plugged into the copier or the wall or the port in the wall is not active.
Nov 15, 2011 | Sharp Office Equipment & Supplies
Get network error ce-00 on the sharp mx-3501n when i try to scan to network.
CE-00 means ther is a bad destination entered or the copier is not seeing the server check the IP address
Jan 08, 2010 | Sharp Office Equipment & Supplies
Receiving a Communication Network Error on our Sharp MX 2300N only on the weekends. According to the tech this particular machine does not have a setting for work days only, which apparently is optional in...
Sounds like it's a network issue. If it's a CE-00 error, it's a definite communication error between the copier and the server.
To my best knowledge there are no optional work day on/off settings on this copier. There are power save settings, but nothing to shut them down or denote power save settings for weekends only.
It sounds like something in your server setup is shutting down or disconnecting during the weekends. I'd contact your IT department to find out if they have something set up that could be causing this error specifically for the weekends.
Aug 28, 2009 | Sharp MX-2300N Color Copier
CE00 Error code
CE-00 means the copier cannot find the computer or server it's directed to scan to.
The usual cause is that the IP address for the scan destination has been changed by DHCP and the connection info has not been updated in the copier.
To resolve, reboot the destination workstation or server. Or, right-click on the Network Scanner Tool icon in the tray, select Automatic Profile Update, and click on Update Now.
If the scan profiles were created in the webpage and not through Sharpdesk/NST, make sure that destination names and/or IPs have not changed in the profile.
If you are using DNS name resolution instead of direct IP addressing, you must be sure that the DNS server IPs are correctly entered into the web page.
Hope this helps!!
May 22, 2009 | Sharp MX-2700N Color Copier
Sharp MX-2300N trying to send image to email address gives error
The new fire wall was set up with a password, free the password on the server setup, that should eliminate block.
Nov 21, 2008 | Sharp MX-2300N Color Copier
Scan to computer
Your machine has Vista supported print drivers?
This is where you can go for the Print Drivers.
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Scanning: first your Machine needs network scanning enabled: (if you can scan with other PC's, dont worry about this) this a key you will get from your dealer..
as for scanning there are a few options:
Scan to email which you can scan through the network to your email using your email server..
Scan to desktop
you can use Sharpdesk a program that will come with the machine if Scanning is enabled? which now is available for vista, your local sharp dealer will have(not sold in stores)
or you can try the Twain Scan (LAN).. which you can find on the sharp web site listed above..
Nov 13, 2008 | Sharp MX-2300N Color Copier
Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp MX-2300N Color Copier Logo
3,990 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
