Question about Moen & Villeta Two Handle Lavatory Faucet
I have a loose handle on my Moen two hanlde lavatory faucet and i can't find any set screw to tighten it . How to tighten the handle to the faucet stem?
  • 349 Answers
Take handle off and check out the inside to make sure it not striped out and on the top of the handle it may have a plastic cap to pop of to access the screw holding in in place you amy have to use a knive to get it off .
If you can't see a set screw it may have a screw in handle on top.
Posted on May 03, 2010
Moen Kleo faucet. Handle loose, removed set screw to tighten but now no water pressure. (it worked fine before inspector came for house sale)
Something always seems to happen when an inspection is due. The handle tightening operation may have affected the cartridge inside. Back off the screw and water may return. If not, the cartridge may have to be replaced.
Jun 30, 2016 | Moen Plumbing
How do I remove the handle on a Moen Brantford doule handle lavatory faucet
there has to be a small setscrew hole on either handle .otherwise they could not be repaired
Feb 11, 2015 | Moen 6610 Brantford Two Handle Lavatory...
How do I get the handle off so I can tighten it up to eliminate wobble
look for a small hole in the bottom of the faucet handle,, it holds a allen type or a slotted screw for retaining the handle,, ( more than likely on a moen or Kohler its going to be a allen head,) ,, remove that and your handle should come off
Sep 16, 2011 | KOHLER Forte Widespread Lavatory Faucet...
I have a handle that came off a Moen Villeta 2 handle bathroom faucet. It is not obvious, no set screw etc., of how to attach the handle. Also, the stem that the handle attaches to, seems to have dropped...
Sorry to read about your problem, I hope this helps you out.
under the moen symbol is a set screw
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Moen & Villeta Two Handle Lavatory Faucet
I have a single lever Moen faucet where the handle is very loose and there is no button on the back side that would reveal an allen key, so I cannot tell how to tighten it back up. What should I do?
On almost all moen single handle faucets there is no allen set screw to hold handle on. They are secured by a screw located under Moen emblem in the center of the faucet on the top. You usually can get to the handle screw by prying cover off with small blade screwdriver or point of knife blade.. Tighten screw and hopefully this will fix your problem. Thank you.
Nov 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
Faucet is dropping it is a one handle
First turn water supply to faucet off and remove handle. Remove cartridge from inside faucet and replace with new cartridge. Make sure you tighten cartridge to snug. Don't over tighten.
Aug 10, 2010 | Moen & Villeta Two Handle Lavatory Faucet
How do you remove the handle to gain access to the cartridge. the handle is loose at the cartridge.
There is a set screw on the base of each handle, on the backside, which needs to be loosened with an allen wrench (hex-head) lossen the set screw and remove handle.
Please rate this answer for me. Thank you
Mar 25, 2010 | Moen & Monticello& Two Handle Lavatory...
Need to replace handle adapter kit on a Moen monticello two handle lavatory faucet
Lowes might carry them but i know a plumbing supply house does for sure. Take center caps off hot and cold handls, then screws everything else should pull right off.
Sep 10, 2009 | Moen & Monticello& Two Handle Lavatory...
Mini wide spread vanity tap handles ( mostly left ) are loose.
if there is a cap on top, remove with a sharp object(razor knife) and tighten phillips head screw Just guessing but this is a common setup
Jan 14, 2009 | Moen T4945/9300 Castelby Two Handle Mini...
Moen & Villeta Two Handle Lavatory Faucet  Logo
737 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
