Question about Nikon D3000 Digital Camera
Nikon D3000. Exposure lock with focus problem.
Nikon D3000. So I put the camera on aperture priority. test the light on my blue jeans and press exposure lock and hold it in. Problem is my camera does not want to focus then when pointing towards subject. Camera setting is on autofocus. Any settings I should check?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 238 Answers
Probably your lens causes this I think. Please check these.
1. Your lens may cause this. Change it and try again.If you do not have another lens then go on to check the next instrutions.
2. Check your lens AF button. It should be switched to AF.
3. Turn off and on the camera and try again.
4. Check your battery charging.
5. Your lens should be cleaned complitely. Please check its clearity.
I think it will work. But if it does not work properly again then your camera should be checked.
Clean your camera mirror. For this:
1. Turn off your camera.
2. Remove your lens.
3. Clean your mirror without using water or any other liquid or any other chemicals. Use only special cleaning liquid that is made for lens cleaning.
4. If it does not work then your camera body should be checked electronically and mechanically. This check can only be done with an authorized service tecnician. So you should send your camera to your service dealer.
Posted on May 03, 2010
How do I switch to an aperture higher than f/32 on my nikon d3000?
Yes. Just lock the lens aperture ring at its smallest setting (largest f/number). If you need to change the aperture, change it from the camera body by turning the command dial, the same way as with a lens without an aperture ring.
Jul 18, 2014 | Sigma 50mm F2.8 EX DG Macro Lens For Nikon
How could use vivtar 500mm in D40x. the seller asked me to put the camera in Manaul mode and set off to the shutter priorty to off. I could not find how to set the shutter priority to off in the setting.
A 500 mm mirror lens is a fully manual lens (manual focus no aperture change) using a T mount adapter to your specific camera. The T mount costs some $15. It depends on your camera how to turn off the auto focus and go to aperture priority mode. The aperture on a mirror lens is set, usually at F8, so the shutter is the only item that can be adjusted to get a correct exposure. A digital camera (set in adjustable ASA setting) can change it's ASA to help with getting a correct exposure. Manual for digital camera are usually on the companies' web site.
Feb 22, 2014 | Vivitar 500mm 8.0 Lens Nikon D3000 D5000...
I have a 500mm telephoto w/ 2X adapter get ms. 'no lens attached'
You need to shoot in the Manual mode by turning the mode dial to "M". You have to set the shutter speed and aperture yourself, without any help from the camera's light meter. You can review the photo afterward and adjust the exposure accordingly. The histogram will help in this.
Oh, and you also have to focus manually.
Dec 17, 2013 | Nikon D3000 Digital Camera
Installing the Rokinon 500mm/1000mm f/8.0 Mirror Lens for Nikon
This lens does not have the electronics to communicate with the camera. You have to use the camera on the Manual exposure mode (turn the mode dial to M) and set the aperture and shutter speed yourself. You will not get any metering help from the camera's light meter, but you can use the histogram to fine-tune your exposure. You also have to focus the camera manually.
You'll want to use a tripod or other support, as the lens will magnify every bit of camera shake.
Jul 20, 2012 | Rokinon 500mm 1000mm Telephoto Lens Nikon...
Does anyone knows how a Vivitar 75-260mm lens will works on nikon d3000?
Vivitar makes lenses with a variety of mounts. Assuming the lens in question has a Nikon mount then it will fit perfectly well on a D3000. If the lens has a Canon mount, for example, then it will not fit at all.The lens is a manual focus lens, so autofocus will not work. You'll have to focus by yourself.The lens also lacks the electronics to communicate with the camera. You will have to shoot in the Manual exposure mode, setting the shutter speed and aperture yourself, without any help from the camera's light meter.
Apr 11, 2012 | Nikon D300 Digital Camera
I'm doing a project for school and i need to change the aperture for different photos. But my camera refuses to take the photo on any other aperture. Why is there an aperture adjuster if you can't use it....
It depends on the lens.
If you're using a lens with an aperture ring, simply set the exposure mode to Manual or Aperture priority and change the aperture by turning the aperture ring on the lens. In Aperture priority the camera will set the shutter speed appropriately, in Manual you have to determine the appropriate shutter speed. If you want to use such a lens in Shutter priority or one of the Program modes, you must set the aperture to its smallest setting (largest f/number) and lock it.
If you're using a lens without an aperture ring then it's a bit harder. You can only use the camera in Shutter priority or one of the Program modes. You turn the command dial on the camera to change the exposure, and the aperture will change. If you want to use an exposure different than what the meter suggests, you can adjust it by using either exposure compensation or changing the ISO setting (or both).
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n6006af/nikon_n6006af.htm
Mar 08, 2011 | Nikon N6006 35mm SLR Camera
What type of exposure system does it have?
The N2000 has Program, Program Hi, Aperture-priority, and Manual exposure modes, with exposure lock and exposure compensation capabilities. It can TTL auto and manual with flash. The meter is full-aperture and center-weighted.
The Program mode sets both the shutter speed and aperture for optimum exposure. You can adjust the exposure if you want to emphasize shutter speed or aperture. The Program Hi mode tries to set a higher shutter speed for action and/or long lenses.
You can download a copy of the manual here if you want to know more about this camera.
Feb 14, 2011 | Nikon N2000 35mm SLR Camera
My nikon d3000 is giving me a subject too dark message
This means your exposure is too low. Ensure your lens cap is off and make adjustments to compensate for your lighting with: using flash, lowering your aperture value, lowering your shutter speed or increasing your iso. Play with these values until you find the proper balance or switch to Auto mode. If it is still to dark, find more adequate light.
Jan 16, 2011 | Nikon D3000 Digital Camera
How do I adjust the aperture on the Nikon D5000 DSLR camera?
It depends on the exposure mode.
In Program mode (P), turn the command dial and the camera will shift the exposure by changing both the aperture and the shutter speed.
In Aperture-priority mode (A), turn the command dial and the camera will adjust the shutter speed to suit.
In Manual mode (M), hold the aperture button and turn the command dial.
If you're using a lens with an aperture ring, turn it to its smallest aperture (largest f/number) and lock it.
Feb 17, 2010 | Nikon D5000 Digital Camera
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
Nikon D3000 Digital Camera Logo
483 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
