Question about Whirlpool AD40DSL Dehumidifier
My whirlpool AD50USS2 keeps freezing up and then runs into the bucket. It is connected to a drain hose. What causes it to freeze up?
  • Whirlpool Master
  • 43,501 Answers
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifiermy whirlpool AD50USS2 keeps freezing up and then - 2_bing.gif is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Posted on May 04, 2010
HI HAVE GOT A SWAN SH3010 DEHUMIDIFIER BUT THE COIL KEEPS FREEZING OVER WHAT AM I DOING WRONG?
Nothing.That's how it works. The coil gets cold. The moisture(water) in the air freezes to the coil. The coil then gets warm and the ice melts, dripping into the bucket or out the drain hose.
Jan 04, 2015 | Dehumidifiers
Whirlpool AD50USS Dehumidifier WILL NOT DRAIN THROUGH HOSE
I have a similar model. There are two drains, one for the hose and one directly into the bucket. The hose one is supposed to be lower, but I had to put a 3/8 inch block under the right side of the unit to get the water to favor the hose instead of the bucket. Another possibility is that the far end of the hose is higher than the near end. If you can't lower it, you can put the whole dehumidifier up on blocks. One other thing to check is that the hose has a rubber washer in it where it connects to the unit. Use a tissue to see if this connection is dry. If it leaks, it will just drip into the bucket.
Jun 04, 2012 | Whirlpool AD50USS Dehumidifier
It keeps running, but no condensation. Model AD50USS2
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 10, 2011 | Whirlpool AD50USS Dehumidifier
How do I install a hose so this humidifier drains automatically?
Look at the drain pan, it might have a garden hose connection that you might have to knock out, mine is not the same model but it may be similiar, and then run it to a floor drain or such. Good Luck
Jun 30, 2011 | Whirlpool AD50USS Dehumidifier
I own a Whirlpool Dehumidifer Model Number AD 70USS1. I have a drain hose connected to the unit, however, recently the unit's internal collection bucket fills with water to the point that the...
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
The unit is freezing up on the filter screen. Approximately half the screen is coated in about a 1/4" of ice after 24 hours of operation. The water that is removed falls into the bucket instead of...
could be a couple of areas to check temperature set to low filter plugged unit low on charge fan motor needs to be replaced or fuse or breaker blown or off
Jun 08, 2011 | Whirlpool AD50USS Dehumidifier
I have an LHD6594EBL dehumidifier that won't run and it keeps saying the bucket is full but the bucket is empty, we have a hose attached and don't use the bucket,
Sue, if you haven't noticed any water draining from the hose recently, it may be that the hose connection and tubing of the unit are clogged and the drained water pressure is causing the unit to show "Bucket Full." Also, if the bucket is not properly in place, whether you use the drain hose or not, it will cause the unit to stop functioning. You know how to correct that, so I won't go into detail on that issue.
To unclog the drain, you will need an 18" long, plastic Zip Tie or something similar (NO wire coat hangers though) that will fit into the hose connection. TURN THE UNIT OFF AND UNPLUG IT. Then carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. You will have to carefully work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, while rotating it, slowly pull it out and be prepared for some water to follow.
Hope this helped you troubleshoot and solve the problem.
Jun 01, 2011 | LG LHD659EBL Dehumidifier
Will not drain out of the hose i have to keep emptying the pan i thought it was suppose to drain out of the hose to keep running
If the hose is connected to the tap on the drain pan/bucket, did you knock out the center of the hose connection on the bucket? If you didn't that's the problem. If that's not where your hose connection is located, do not put the bucket back in. It triggers the unit to fill the bucket and not use the hose drain. Keep in mind the hose must remain lower than the connection on the dehumidifier to drain properly.
Mar 21, 2011 | Whirlpool AD35USS Dehumidifier
Ad50uss2 coil iced up
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Dec 30, 2010 | Whirlpool AD50USS Dehumidifier
Whirlpool AD40DSL Dehumidifier Logo
709 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
