Question about MidiLand MLi 691H Computer Speakers
Remote Speaker Not Working.
Hi. I have a set of speakers where the remote speaker does not produce any sound. I think the problem is in the circuit board. I made a connection from each lug of one speaker to the corresponding lug on the other speaker and the speaker produced sound. I completed an Ohms check of the wire between the remote speaker and circuit board and it was ok. Without the schematic, I trace any further. Any suggestions? Thank you for your time. Andrew Lynn (818) 394-4329
4 Suggested Answers
jaranya8
  • 238 Answers
SOURCE: i have no sound
Try downloading the audio codecs for that matter. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
*Drop me a comment and i will assist you.
Best regards
Posted on Jan 04, 2009
respect137
  • 157 Answers
SOURCE: Speaker's universal remote code
If you don't have a code book for the remote then you will not be able to establish a link to your unit.
Posted on Jun 18, 2009
SOURCE: I cannot locate AC adapter for speakers MIL 699 remote speakers
I found the AC adapter for the speakers 120 Volts AC in and output 7volts 500Ma
Posted on Dec 16, 2009
How do I remove the decoder off from the tuner? I can not get audio.
Hi, Not sure what exactly you mean.
Try turning input knob on Receiver or press equipment button like Sat/cable or DVD on remote.
If still no sound look for a button "Input mode" or "6 Channel" eg on receiver and select analogue, digital etc or disable 6 channel mode.
Make sure speaker wires are connected and not short circuit. Also look for speaker button, On some receivers you can disable speakers.or select A & B
If sound was working before you probably just press or disable sound settings on receiver.
Sep 24, 2014 | Yamaha RXV367 5.1-Channel Black Digital...
Only two front speakers are working
http://safemanuals.com/user-guide-instructions-owner-manual/AKAI/CD3000XL-_E owners maual ......... you need to change the settings on it for suround sound
Oct 21, 2008 | Akai DHT300 System
I have a 2010 cobalt lt. Today both my feont speakers quit working. And now my turn signals make no noise. Or the door chime or the seatbelt indicator does not work. What causes this and how do I fix it?...
The chimes an turn signal noise come out driver door speaker . Both front speakers not working could be a blown circuit fuse inside the radio or just blown front speaker channel . Your best bet , take it to a GM dealer or someother qualified repair shop . You have no idea of the complexity of this . The radio can set DTC'S - diagnostic trouble codes , believe it or not !
DTC B1025, B1035, B1045, or B1055
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3V AC and slightly higher.
DTC B1287 01: Amplifier Control Signal Circuit Short to Battery
DTC B1287 02: Amplifier Control Signal Circuit Short to Ground
DTC B1287 04: Amplifier Control Signal Circuit Open
The radio provides a remote amplifier mute output circuit to control overall muting of the remote amplifier. The amplifier receives pulse width modulated (PWM) signals on the control circuit at varying duty cycle percentages for controlling muted and unmuted functions of the amplifier. Circuitry internal to the radio monitors the remote amplifier mute circuit for faults and sets the appropriate DTC when faults are detected.
Feb 16, 2018 | 2010 Chevrolet Cobalt
Volume working
Code for NEO 1451 TV?(universal remote control)
Aug 14, 2013 | Samsung TV Remote Control
My onkyo reciever working very well but last 2 days subwoofer out put off from receiver .... subwoofer is ok
Hi, If you have remote to receiver try hitting the speaker setup selection. I am thinking perhaps a speaker setting was inadvertantly taqmpered with. In speaker settings you will have such things as distance setting-speaker size-delay etc..then you should come to a selection for whether or not a subwoofer is used ie: subwoofer : on, off.. I hope this has been of some use and thank you for choosing FixYa,Good luck, Prodzilla
Apr 13, 2011 | Onkyo Audio Players & Recorders
My logitech z 2300 subwoofer is not producing sound
Since this set is hardwired together and the other speakers are working, the only easy fix would be the subwoofer got turned down on the remote volume control. Anything more would mean its broken. If its under warranty take it back. If its not and you know somebody capable, you might have them check for the obvious,bad solder connections on speaker, or and open voice coil on the speaker it self.
Aug 26, 2009 | Logitech Z-2300 Computer Speakers
MY REMOTE IS NOT WORKING FOR MY ONKYO TX-SV525,
Hello, I am sorry for your issue. Please go to replacementremotes.com and search txsv525. They do sell a replacement. If you email me at askonkyo@us.onkyo.com and I will send you a copy of the manual. Thank you. Onkyo USA
Mar 14, 2017 | Onkyo TX-SV545 Receiver
Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Jan 23, 2009 | Philips HTS3544/37 Theater System
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
May 29, 2007 | Onkyo TX-DS555 Receiver
Right speaker out in all modes
your sound system has a faulty audio circuit have a tech repair your set.good luck
Apr 24, 2007 | Harman Kardon AVR 7000
MidiLand MLi 691H Computer Speakers Logo
37 people viewed this question
Top MidiLand Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
